Stumpy the yota
Old Dec 30, 2018 | 01:21 PM
  #61
stereoguy's Avatar
Some more pics of fun
Old Dec 30, 2018 | 01:25 PM
  #62
stereoguy's Avatar
I am now in the process of adding a pr of suck down winches to this fat beast. I have the front done. Working on the rear. Here are the controls The 12 volt guy did a great job on these.
Old Dec 30, 2018 | 03:48 PM
  #63
Discombobulated's Avatar
Excellent!!!! Looks just plain wonderful
Old Dec 29, 2019 | 03:11 PM
  #64
stereoguy's Avatar
I finally got my suck down winches done. They work great! It's nice to be able to pull the front or the rear down as I need. Here are the controls and the harbor freight 2500lb winches i used.
winch controls
front winch pull point
front winch It's tight
rear winch
Old Dec 29, 2019 | 03:17 PM
  #65
stereoguy's Avatar
I had some issues with the old 4.3 engine so i installed a crate GM 4.3 Wow! I cant believe the difference! The old on must have been on it's last leg.
new crate engine
Old Dec 31, 2019 | 06:41 AM
  #66
stereoguy's Avatar
I was tired of the a/c compressor crapping out all the time. I used my original Toyota a/c unit for a decade and never had an issue. the Chevy unit is not durable at all. i ended up installing a dual Viair 425c gen 2 system. I already had the 3 gallon tank so I found a great deal through Hornblasters.com I moved the units to the rear and made a plate to mount them to. These work incredible! I can fill my tires up just like a big air compressor can! They are super quiet too. Excellent design! I think they are 4.8cfm so air tools too if I want.
Old Dec 31, 2019 | 07:12 AM
  #67
stereoguy's Avatar
I got tired of having to tighten my steering arms all the time so i was either going to get the 6 shooters or try the 5th stud mod. i figured i will try the 5th stud mod 1st. I blew up a dirty 30 axle at the bell the last time out so I figured a new set of RCV 30 spline shafts would be the trick! I also went with the trunion eliminator kit at the same time. I had a not fun time getting the trunion elim. kit shimmed up on one side. Too tight or too loose. I used a belt sander to finally get it right. i sanded on of the shims down a bit.
yuck!
snapped at the bell
new rotors and bearings. All cleaned up.
mark for my 5th stud
trunion eliminators
all completed!
Old Dec 31, 2019 | 08:10 AM
  #68
rattlewagon's Avatar
Looks good! Is the 5th stud a bolt coming up from the bottom, or did you put a stud in?
Old Jan 1, 2020 | 07:28 AM
  #69
stereoguy's Avatar
I put a bolt in and tack welded it from the inside. No more loose steering arms!
Old Jan 1, 2020 | 12:25 PM
  #70
stereoguy's Avatar
After I did the 4.3 swap I decided to get rid of the old gauges. I made a plate and added some Autometer gauges. I added a sheet of carbon fiber for some bling! I love how these look and they are very accurate! No more tapping my dash so the gauges work! I even have turn signal indicators(small green indicators),high beam indicator(small blue light)
fun times The back side
it fits great
,check engine light(the yellow light)oil light(red light)4wd indicator(green light)
sweet
Old Jan 1, 2020 | 12:45 PM
  #71
stereoguy's Avatar
I sta
primed and white basecoat
taped up and red co;or shot on
more taping and red then more taping and the black lines then clearcoat
it turned out nice! I am going to add a few more black stripes with tape till it is the way I like it!
The wheels turned out nice!
I need a mullet now!
I even painted the door inserts
Now to beat on this again!
The truck is working great now!
good times
rted to get too many crushed panels and I was tired of the green. I thought I would change up the look. I decided the Eddie Van Halen guitar color scheme would look cool! WOW! This was a lot of work! I replaced some panels and pulled most of the dents and shot the white basecoat
Old Jan 2, 2020 | 10:40 AM
  #72
warmonger88's Avatar
Your 4Runner has been one of my favorite build on Yotatech, I love the new paint!
Old Jan 2, 2020 | 03:35 PM
  #73
stereoguy's Avatar
Thanks! It’s been a fun build. I think I’m almost done now. We will see! It’s hard to believe I’ve only had this 12 yrs.
Old Jan 10, 2021 | 07:33 AM
  #74
stereoguy's Avatar
So I decided to finally do the hardtop conversion to this truck. Here is the truck with the top back on https://www.flickr.com/photos/161937.../shares/vH81rK
Old Jan 10, 2021 | 07:51 AM
  #75
stereoguy's Avatar
Conversion
Top off
Old Jan 10, 2021 | 07:55 AM
  #76
stereoguy's Avatar
Now to make the mounting pads and rail for the front seal
Top rail
Capped end and location pin
Weatherstripping
Mounting base and pin hole
Old Jan 10, 2021 | 08:02 AM
  #77
stereoguy's Avatar
This turned out sweet! I was jealous of the back seat passengers having the sun. Now I can too! The top has L brackets in the 4corners to bolt back on if the weather isn’t so nice. I can put the hardtop on and off in about 5-10 minutes.
Finished and topless
All done
Old Jan 10, 2021 | 08:08 AM
  #78
stereoguy's Avatar
And ..... The top back on. 😁. A convertible 1st gen Toyota 4Runner!
Top back on!
Almost not noticeable.
Old Jan 10, 2021 | 08:17 AM
  #79
stereoguy's Avatar
I did have to tie in /weld the windshield pillars to the cage. It was bugging me seeing the body flex a bit going down the road. Also the rear mount is tied to the cage for rigidity too. No flex and I’ll probably never run the top much but if I want to wheel on a muddy day I can run the top and door /window inserts and stay dry. I couldn’t find anything when I was looking to do this so I figured I would post it and maybe give someone else a head start. The front rib is from a mini truck convertible top kit. I bought the whole kit but that’s all I could use. It still had to be cut in 1/2 and spliced together but it worked. Just some homemade L brackets and bolts and some flat steel to cap the rear ends and a welded bolt for a locating pin. It took a day to do but I love it!!!
F
California SoCal
Jul 10, 2016 06:46 PM
yotarover
Aug 1, 2010 06:25 PM
xman66
Engine Swaps
Mar 28, 2010 06:38 AM
89pickupsr5
Nov 26, 2007 07:02 PM
