RMP8080 89 4RUNNER Resurrection Buildup
Old Mar 30, 2012 | 09:30 PM
  #41
blakefogt's Avatar
did you buy your Factory Service Manual yet? You can download one for free if you dont need paper.
http://www.ncttora.com/fsm/index.html
Old Mar 30, 2012 | 09:43 PM
  #42
RMP8080's Avatar
Thanks, got an 88 runner manual in PDF file....
Old Apr 4, 2012 | 02:28 PM
  #43
RMP8080's Avatar
So, it looks like from the code G282, that my gears are 4.30, which is common with automatic transmission. Would it make the manual transmission run different?
Running 31 11.50 15's
Thanks..............Bill
Old Apr 4, 2012 | 02:49 PM
  #44
racerflea's Avatar
Means more torque and power!!! But all should be fine
Old Apr 4, 2012 | 06:07 PM
  #45
RMP8080's Avatar
Thanks, I was not sure,
Old Apr 6, 2012 | 06:15 AM
  #46
Terrys87's Avatar
What I have read, it shouldnt be an issue. Seems lie the ones that have done the same thing were happy with the results.
Old Apr 6, 2012 | 06:43 AM
  #47
Smeddy2's Avatar
Yeah I think when youre running 31's you'll be thankful for the extra push. Plus it will make your speedometer and odometer closer to being correct. I have 4.56's from a 93 and it is just about spot on with my 31's.
Old Apr 6, 2012 | 07:03 PM
  #48
RMP8080's Avatar
Good Friday and I'm off from work, working the weekend
so did some work on the 4runner
cap before
cap after (Bed Liner) with only one coat
with the cap off
some area of rust
Old Apr 6, 2012 | 07:26 PM
  #49
rustED's Avatar
Your making good progress! What kind of bedliner did you use? When I got my runner the first thing I did was paint the top, (it was the "faded pink" instead of red ,lol) I used Rustoleum satin black (in the can) and rolled it on. It turned out pretty good, but if it starts looking bad, I was thinking of using a roll on bedliner.
....Ed
Old Apr 7, 2012 | 06:28 AM
  #50
Zelephant's Avatar
Originally Posted by Nervo19
My rear fenders were as bad. One of these days I'm going to do a build thread. I wish I took more pictures. I used Eastwood products. I used naval jelly and a car wash to get a lot of rust off, then Eastwood Rust converter (turned the rust black) and then Eastwood Rust Encapsulator. Then I came in from inside the fender with fiberglass mat +epoxy. The final skin coat is Rage filler. The Bondo with fiberglass would probably work well too. You can get fiberglass mat (not the cloth) at Walmart for a small section. Try to keep the Rage or regular Bondo thinner than a dime.
There should be a tutorial thread for that! I know I could have used it when I did rust repair.
I'm interested to see what you end up doing with the rust, it's a solid looking truck otherwise!
Old Apr 8, 2012 | 12:28 AM
  #51
Terrys87's Avatar
The PO actually took good care of it. If it wasnt for the rust, you would have it easy. Top is looking good. Where Inclometer sets, what is that on yours, just above the double vents?
Zelephant..I havent looked for rust repair but on I am finding alot of things on Youtube, that is turning into a wealth of information.
Old Apr 8, 2012 | 11:30 AM
  #52
RMP8080's Avatar
Hey, Terry, I did not have a inclometer on the 89, what you are seeing is part of the center consle that I placed on the dash and the ECT box.
May add a iclometer...later..
Old Apr 14, 2012 | 06:01 PM
  #53
RMP8080's Avatar
had to do some work on the F350 and we changed the stocks on the Jetta and after that did a little to the 4runner..
remove the rear window wiper, not going to use it
2nd coat of bed liner on the cap
found more rust.....
Also did some work to driver's side rear fender
Old Apr 14, 2012 | 06:46 PM
  #54
Teuf's Avatar
Subscribed.......
Old Apr 15, 2012 | 11:45 AM
  #55
Terrys87's Avatar
Each step is one step closer to being done. Just keep at it and it will eventually happen.
Old Apr 16, 2012 | 01:52 PM
  #56
RMP8080's Avatar
Thanks Terry, I think so. Sunday was our Easter (Orthodox), so no working on trucks, just eating and eating, wow I sound like Mark. I'm off Friday and the weather looks good may get some work done....If not more other problem come up. Oh and my Jetta needs a vaccum pump....
another problem......
Old Apr 22, 2012 | 01:04 PM
  #57
Redeth005's Avatar
Nice dude. I see why you were telling me about the condition of my truck and it being rustfree for the most part. Lol mine looks pretty good as far as rust goes when compared to yours.
I, however, had the same problem with the camper window. My window was broken so i had to go to a junk yard to find a replacent. and i happened to find one(lucky me) but the whole "L" piece was rusted, so i threw that piece and re used the one that was origionally on my truck which didnt have any rust. But the main piece that holds the 2 small windows on the corner with the little tip had some pretty bad rust. Not as bad as yours but still had some.
I just took some sand paper to it and rubbed like crazy till i seen fresh metal. I re-repainted it and so far it looks ok.
My biggest problem with my 4runner is that the previous owner used some really cheap paint and to top it off did a crappy paint job on the camper so that is definitely something i wanna work on and make look a bit more "clean-cut." But dude you're getting there man. Nice runner. i agree with the rest of the guys here. the runner is in very good shape with rust aside. Good Job
- Richard
Old Apr 22, 2012 | 10:26 PM
  #58
RMP8080's Avatar
Thanks Redeth005, your 4runner looks great on the outside and the inside needs work, mine it's the other way around, best of luck and keep us posted.
I paint my camper top with bed liner, looks good and hopefully holds up.....Bill
Old Apr 23, 2012 | 05:46 AM
  #59
rattlewagon's Avatar
Man rust sucks. Good luck in the repair!
Old Apr 24, 2012 | 07:52 PM
  #60
jason in tn's Avatar
Good looking project, my 86 had a lot of rust as well its a slow process to fix but it can be done. I have use spray on bed liner for a lot of things my only issue is its hard to clean once dirty but I used it on my sliders, rear bumper etc its holding up well otherwise. Keep up the good work I look forward to it coming together for ya.
