RedDemon 87 4runner sr5 Turbo
was jamming on my truck today. Got the inside lights going. Had too run my own using old lines that was in the truck already. Bought some L.E.D strip lights off ebay. Run them on my camper back too front. Also ran ah line for the front, right on the window (front) molding. Now i got hella lights inside!
Just got done with doing my zuk mod on my 87 4runner. Did the no cut mod. Used old 04' gs300 rear springs. Don't know the load on them but both was 12.5" (almost) long. Feels like the rear is higher when you get in. How do i know if the rear drum brakes are still working. The rear is on the stock load sensor system. I hope its still working. Will take pictures 2morrow.
#25
was testing on some small bumps.
The 4x4 low is smooth i like for stock.
P.S. Also got my power windows hooked up. My luck blow out the driver side switch (switch kit from jeggs) ordering another kit for the driverside and gonna use the extra switch for the rear window
#26
fuel pump!
so I went too the bank too pull some cash. had too toll the demon home. it started too stall. on and off intill it cut out. the motor stopped and cranks but no fire. I hope its just the pump. no fuel in the lines when you turn it too on. nothing. so lets get this going now. fun, fuel pumps are not cheap. So gonna save for pump, fuel filter plus ah switch.
#27
So i just placed ah order on my fuel pump from denso. Now just waiting on it too show up. Got it on ups 2day. Gotta get it up and running again. So i can find out what else needs too be replaced.
love it or leave it
#28
hope the fuel pump fixes it for ya! On your Zuk mod, does the tire rub the coil spring all the time, or just when you're flexing it out on obsticles? I used some Jeep TJ front coils springs without any issues.
#30
[IMG]
[/IMG]
If i'm right this is the fuel pump mounted out side of the fuel tank?
The last owner did ah hella job on the replacement
So he mounted it onto the old pump too i'm taking it. My tracking number says it won't be (new fuel pump) here in till monday. So i opened everything too get ready for the new pump and found this? Wtf
o well gonna have too think of something here.
the things people do too save 5 mins.
[/IMG]If i'm right this is the fuel pump mounted out side of the fuel tank?
#31
Got it running. But it wasn't the fuel pump
it was the black circuit rely from behind the glove box. Changed that one out with one from the junk yard. Got three total from there. It started right up and stayed strong. Testing it again 2morrow, but gonna take it out saturday big time.
#32
jamming now guys, but i gotta make time coming up here too install that new fuel pump. The old one there is making hella noise now.
Was following alilo honda crv. My cousin's awd crv. Not the best off roader but he got it rolling along with me.
This trail we where wheeling on was san jacinto truck trail if i'm right, we started from bee canyon on helmet side. If you guys know where i'm talking about.
#33
Gonna be doing some wheeling plus maybe get me some cotton tails or jackS. Some good eatting plus dogs will love them too. I'll take some photos if this trail (Thomas mountain trail) has any spots too get some stock flexing going
lilo cousin with the crv gonna be going too
Hope trail is smooth for him (packing chains, pull rope, etc) mainly for him
will post
#34
Was wheeling today and while driving i felt the driver front wheel having alot of play in it. Plus when tou make right turns that wheel dips alot more then the right side does(when turning left). Gotta save up for new set all around.
Nothing much on that trail (thomas mountain trail)
#35
Will its been some time but i got ah set of front bilstein for the runner. Gotta replace the dead rs9000 that the PO hold put on. Gonna post pics up when the install goes down
#36
Its running on 1.2 channel 1 and 1.2 (1.3) i guess on channel 40. Haven't tuned it yet but running ok right now. Setup is cobra 148 gtl (china) its good for me
hooked up too a door jam mount which is hooked up too a wilson tunable antenna (silver-lined) 5' where i hunt and wheel in so far there is not much trees. So 5' it is.
Still waiting on lowrange too send me my shocks. Should be in tuesday from what the tracking # says. I guess they forgot too send my shocks but i got my grip tape fast but shocks where nothing intill i emailed them then bam tracking # like i just order it.
#37
Ok so my bilsteins for the front came in.
what i thought too be good but old rancho's rs90000 in the front, i replaced one of the fronts (driver side front) cause it was totaled dead. Had some trouble installing it. The bottom mount holes for the shock was bent too the back (front of the car, back of the car) so the shock wouldn't fit right. Had too bend and tap stuff back in line so the shock would slide in right. After that i put everything back on and give it a test drive
I love the bilsteins (even if it was only one). From what i can tell the only good shock is the new bilstein i just put in. The other three (compared too the new one) are dead as well. Gonna have too order two new ones for the rear. Gonna get home 2morrow and install the right side front shock too, get the front done with at least the shocks. Will have pictures up 2morrow. UPS guy came hella late.
#39
