RBx 1988 4Runner Build-Up Thread
Old Feb 5, 2014 | 01:14 PM
  #1681
RBX's Avatar
RBX
No Zuk mod for me, it doesn't sag bad enough to put a band-aid on it. I will probably buy some taller springs since the 4-link is a bit away from being reality. That may not solve the mushy rear feeling. I'm going to install a sway bar on the rear and try to figure out how i can stuff one on the front. I think the rear is my issue but it honestly could be a result of the front, I'm just not sure yet.
Old Feb 7, 2014 | 12:24 PM
  #1682
Yota's Avatar
awesome build, thanks for all the great write ups. i will be doing a sunken trunk in my 86 somewhere down the road, (permission from the boss lady permitted)
Old Feb 7, 2014 | 12:39 PM
  #1683
RBX's Avatar
RBX
I wish I was better about documenting, as for lady approval upgrading a 20yr old vehicle is a "safety measure"
Old Feb 9, 2014 | 12:35 PM
  #1684
RBX's Avatar
RBX
Winch Plate Bumper Fit Up
Most parts are only tacked together as I need to bend the front face around to the sides and slide the wings in a bit to close the gap at the marker lights.
Puzzle Bumper
Old Feb 9, 2014 | 01:25 PM
  #1685
irab88's Avatar
skull
Old Feb 9, 2014 | 01:58 PM
  #1686
JBurt's Avatar
When do we get visual proof that your rig moves?
Great job on the bumper btw.
Old Feb 9, 2014 | 02:04 PM
  #1687
dropzone's Avatar
Fossilized
Nice work on the bumper...internally looks a lot like the construction on my old '05 tacos ARB bumper..
Old Feb 9, 2014 | 02:19 PM
  #1688
RBX's Avatar
RBX
Truck moves, but need an alignment so not driving it unless absolutely necessary. Hope to get her out soon the stretch her legs.
Thanks for the compliments.
Didn't realize till Ian pointed out it looks like a skull. Too as that's the bottom view you'll never really see it.
Old Feb 9, 2014 | 05:38 PM
  #1689
Toyota~Boy's Avatar
Really nice work on the bumper. I'm about to build a set for my T100. I'm unsure how or what I'm going to make tho. Keep up the good work and keep us posted with pics. Can't wait to see the finished product.
Old Feb 9, 2014 | 06:14 PM
  #1690
RBX's Avatar
RBX
Thanks for the kind words I'm trying.
Old Feb 10, 2014 | 08:20 AM
  #1691
kawazx636's Avatar
Not sure how I missed this thread for so long, but good job my fellow Marylander!
Old Feb 15, 2014 | 08:24 AM
  #1692
RBX's Avatar
RBX
How much snow did Salisbury get? We got about 16" in Baltimore.
This is out in Frederick.
About 16" of dense white stuff.
Old Feb 15, 2014 | 07:09 PM
  #1693
kawazx636's Avatar
What is snow???? Man, we barely got a snowflake around here. We typically don't get snow here when the systems are coming from the south - the warmer mouth of the bay usually kills it for us, but I'm not complaining.
Old Feb 15, 2014 | 07:32 PM
  #1694
ChefYota4x4's Avatar
Lookin SICK! Beautiful job man!
Old Feb 21, 2014 | 11:58 AM
  #1695
yotarob2005's Avatar
Hey RBX! Man this rig is looking great. Love the 3 link SAS.
Old Feb 21, 2014 | 12:41 PM
  #1696
RBX's Avatar
RBX
Thx man. I'm still ironing out some ride issues. More testing and more adjusting
Old Feb 27, 2014 | 04:54 AM
  #1697
RBX's Avatar
RBX
Update:
No pics, but i have reduced my handling issues. CASTER CASTER CASTER, this is a very important term/theory.
My wandering and squirrely driving characteristics were partly due to my caster being close to 4°(it should be 6°). I must have not had my angle finder set correctly on the knuckle when I did the reassemble.
Last night, in the cold and dark, my buddy convinced me to crawl under the truck and check the caster. With his help, watching and holding the angle finder(there isn't any real place to set an angle finder on the knuckle) I was able to adjust my upper link to get proper caster. This adjustability is worth the extra $$ to spend on links IMO.
In my recent posts I complained that the rear end felt it was stepping out over small bumps or uneven pavement. Searching for solutions became difficult since i was describing a problem. But after reading many Jeep forums, I was getting closer to a solution. Since so many Jeeps get lifted by DIYers, there was an abundance of forums with similar complaints of vehicle handling after a suspension lift. Using keywords like wandering, or squirrely, got me better search results.
The truck drives 90% better then before. I say 90% because I need to readjust the toe, since I believe I set it to 1/4", the truck feels like it wants to 'hunt' in the lane when you correct the steering. This isn't a big problem, but it isn't perfect either.
Brian from 4Wheel Underground gave me a call last night to talk about my truck handling issues, this is a man that delivers a product and stands behind it 110%. His customer service is reason alone to use this product.
Old Mar 10, 2014 | 08:15 AM
  #1698
RBX's Avatar
RBX
This weekend I added another ounce of BBs to my tires, to bring the total weight up to 8oz per tire. At the same time I removed the Monster Valve kit and installed low profile compressor drains.
Some Bead Balancing notes:
The Monster Valves are 1oz. each and the drains are only 3/8oz.
Goodyear Wrangler MT/R 315/75R16 (34.8")
DynaBeads and Equal recommend 6-8oz
Started with 7oz each wheel, slight vibrations start at 75mph(corrected)
Added 1oz in hopes to reduce any vibrations at highway speed.
8oz in each tire made vibrations worse before 75mph
Conclusion:
7oz with monster valves was a pretty smooth ride, I think that the heavy monster valves helped actually balance the tire by creating a heavy spot. The removal of the valve and addition of another ounce made things worse. So I can't tell at this point if adding the extra BBs is the issue or the removal of the monster valves. I would think less rotating weight around a tire would be easier to balance, but perhaps the beads have more of an opportunity to spread out since the heavy valve is not concentrating rotating weight in one area of the tire.
also started to wire my eLockers, stole and redrew a wiring schematic without relays:
Old Mar 10, 2014 | 08:44 AM
  #1699
irab88's Avatar
the switch doesn't need to be momentary. the position switch cuts power when the fork is in the desired location. it might make the user-end of things a bit easier, but that's just me. schematic looks good.
Old Mar 10, 2014 | 09:03 AM
  #1700
RBX's Avatar
RBX
easy enough to change the switch out later if i don't like the momentary. thanks for the info.
I do have a fuse after the battery, I'll need to update the drawing.
