RBx 1988 4Runner Build-Up Thread
Old Apr 29, 2014 | 07:58 PM
  #1721
kornhuskerwizard's Avatar
3link rear be sick!! but 63s be better than what you have now maybe.
Old May 2, 2014 | 05:36 PM
  #1722
RBX's Avatar
RBX
Could some one tell me why this happened or have you seen it before...
Just installed front hi-pinion diff w/elocker and went wheeling, nothing to hardcore. I noticed today while hosing off the mud that my gasket is poking out at the top of the diff, like it got squished and pushed out. There is no fluid leaking or even wet areas.
I haven't re-torqued the nuts yet to see if they worked loose, but I did red loctite them and used the torque specs of 18ft.lbs. I did use the locker a bit on the trail and wonder if this presents more stress on the front housing. And this is a retro fitted mini-truck axle housing.
here is a crappy pic of the brown gasket poking out at the top of the diff seal...thanks
Old May 3, 2014 | 07:25 AM
  #1723
Gizler00's Avatar
Originally Posted by RBX
Could some one tell me why this happened or have you seen it before... Just installed front hi-pinion diff w/elocker and went wheeling, nothing to hardcore. I noticed today while hosing off the mud that my gasket is poking out at the top of the diff, like it got squished and pushed out. There is no fluid leaking or even wet areas. I haven't re-torqued the nuts yet to see if they worked loose, but I did red loctite them and used the torque specs of 18ft.lbs. I did use the locker a bit on the trail and wonder if this presents more stress on the front housing. And this is a retro fitted mini-truck axle housing. here is a crappy pic of the brown gasket poking out at the top of the diff seal...thanks
That's weird. Maybe there was some extra stress going on in there when the locker was engaged and caused it to poke out. I would say as Lon as it's not leaking your ok.
Old May 3, 2014 | 01:22 PM
  #1724
RBX's Avatar
RBX
I'm gonna trim the gasket and retorque.
Old May 9, 2014 | 06:39 PM
  #1725
RBX's Avatar
RBX
Ordered my brake lines from technafit 5 total including flexible lines for the rear calipers. Came in around $110, DOT certified and stainless. I'm happy with that deal. Hopefully this solves my squishy brakes issue. I noticed today a fitting on one rear caliper is wet, certainly isn't helping but it's not dripping.
Old May 19, 2014 | 10:34 AM
  #1726
RBX's Avatar
RBX
Body Work 88 4Runner
Did some body work this weekend, mostly fixing rust. So I started under the fuel filler door. this was a hole, even though the factory caulk was holding the rust/metal together. I'm not to concerned about having a straight dent free truck, rust is the real concern.
Rocker finished
Old May 19, 2014 | 11:22 AM
  #1727
irab88's Avatar
at first i was like "you still have snow?!"
looks great!
Old May 19, 2014 | 12:31 PM
  #1728
RBX's Avatar
RBX
Those were the only shots I had.
Old Jun 3, 2014 | 04:15 AM
  #1729
RBX's Avatar
RBX
Time for some Armor
Starting with some homebrew sliders. The only thing I don't like about this is that mud will pile on the flat surfaces...maybe I'll turn the box tube. These are not attached yet but pretty close to where they will live. I have provisions for 4 outriggers from the frame....more to come.
Old Jun 8, 2014 | 01:27 PM
  #1730
RBX's Avatar
RBX
One side sliders on, needs paint. Working on the passenger side now.
Old Jun 8, 2014 | 05:54 PM
  #1731
RBX's Avatar
RBX
Big Dog OffRoad 4x4 Expo today had an RTI , so I got to take some poser shots.need more rear droop, this is just about where the rear was about to lift, front wan't even close to full stuff.
Old Jun 9, 2014 | 06:12 AM
  #1732
CamTom12's Avatar
I love your suspension mods, very unique!
Old Jun 9, 2014 | 06:47 AM
  #1733
RBX's Avatar
RBX
Thanks, but I can't take credit for it. It is most unique because it focusses its geometry on 'flat links'. Just like any KOH Formula Cars
http://www.4wheelunderground.com/3-L...leSystems.html
I installed it, but I bought the kit. Amazing service, tech support is unmatched and craftsmanship is top notch.
Old Jun 9, 2014 | 07:02 AM
  #1734
rustED's Avatar
Awesome flex pics, I really like the front 3 link setup! Nice work on the sliders, they turned out really good, I like your design! I envy the soft top, I want one SOOoooo bad! Are the bow supports the same height as the 4runner cab, or slightly taller? I'm really contemplating on building a DIY soft top for mine, Ive read every DIY thread I can find, and looked at tons of pics, hopefully I can start on one soon, plan on doing a write up and listing all the specs in case others want to copy it. Really like the rear bumper/tire carrier, that's another thing I need, lol, I'm rear bumperless at the moment. Have you done any more work on your front bumper project? That thing is going to be sweet when your done!
Old Jun 9, 2014 | 07:11 AM
  #1735
RBX's Avatar
RBX
Spoiler alert.....^^^
It won't ever be done! Improved, modified..whatever you want to call it, there will always be something else I want to do to it.
Front bumper is just waiting for more time to finish.
the Can-Back top is very simple in its design, the bows are the same height as the cab.
I will be building a new tire carrier at some point, there are a few design improvements I want to incorporate as well as a hammock stay, lighter and more protection
Old Jun 12, 2014 | 04:17 AM
  #1736
RBX's Avatar
RBX
On a constant quest for better brakes, I replaced all four corners with new Technafit brakelines. Because I did a rear disc swap, I have 5 flex lines due to the semi-float Supra anchors out back.
Made some brake line block-offs
Old Jun 13, 2014 | 07:04 AM
  #1737
liveoffroad's Avatar
well done on the suspension, it turned out well! how'd you fix the rust holes..bondo? turned out well and i need to do some of that!
Old Jun 13, 2014 | 08:28 AM
  #1738
RBX's Avatar
RBX
Thanks
I added metal to the rust hole then skim coat.
Old Jun 16, 2014 | 05:51 AM
  #1739
RBX's Avatar
RBX
Cove Campground Big Dog's Offroad Spring Fling 2014
Popped My Cherry….
Did a little wheeling this Father’s Day weekend at Cove Campground during the Big Dog’s Offroad Spring Fling Event. About an hour in to the trail I broke a stock birf, bound to happen. The pictures don’t do the trail justice. Many of the rock fields have holes for your front and rear tire to drop into making climbing out a bit more challenging. Honestly, its all challenging to me because I have no Idea what I’m doing. I may have been able to avoid breaking the axle shaft, but I was consumed by trying to find a good line and didn’t realize I had my wheels turned when I was hitting the skinny pedal while stuck. FailRated (Evan) had invited me to go along with him and his father as well as another buddy and his family in a CJ-7.
A shot of the rock field that would end my stock passenger birfield’s 30yr life. While the east coast doesn’t have the size rocks you find out west, we do have shade. Very nice mild weekend for camping and wheeling.
Front is locked, in the pic below, and this is when the birf detonated. It’s funny I had never heard it before, but I knew what it was immediately when I heard it.(but what do I know, it could have been a shattered hub gear). I like to pretend I learn something every trip out. Took about 20 minutes to swap in a spare FailRated brought. When the birfield shattered, bits lodged themselves around the knuckle balls making it impossible to turn right. But no pics of the carnage.
The view from Pinnacle Ridge on the Appalachian Trail. We were able to drive up to a certain point of the trail(not the AT), then had a short hike on the AT(no motorized vehicles allowed).
Obligatory Father Son photo for Father’s Day
Old Jun 16, 2014 | 06:28 AM
  #1740
very good pics man, looks like a fun day. I've yet to break anything in my front end (knockonwood) but then again, i'm still open in the front....
Good thing you had a spare
