RBx 1988 4Runner Build-Up Thread
Old Aug 6, 2013 | 08:56 AM
  #1521
ChefYota4x4's Avatar
Flesh hemming. .... love it! Lol.
Really sorry bout the injury, Rb.... sux.
Old Aug 6, 2013 | 09:15 AM
  #1522
RBX's Avatar
RBX
needles in your fingerprint area suck majorly.
I didn't finish before my trip....but i'll get it finished up, i got lots to do while the thumb heals.
Old Aug 6, 2013 | 10:10 AM
  #1523
JBurt's Avatar
I got myself on my index finger and thumb on my left hand three years ago with 3 stitches on each. Right where you pick stuff up. It sucks for a while but it goes away to the point where you don't notice it. Glad it wasn't worse.
Old Aug 6, 2013 | 10:24 AM
  #1524
RBX's Avatar
RBX
Yes, I'm lucky it wasn't worse.
Old Aug 6, 2013 | 11:05 AM
  #1525
.... I almost refrain from mentioning this because it often makes people sick just thinking about it... But it definitely could be much worse and I'm glad that you didn't lose your finger, or should I say thumb?
Around 10 years ago I was running a kitchen and they send me a bunch of students one day from my alumni... I asked everyone what they are good at are comfortable with and one of the guys was very gung ho about doing the meat slicer... Yeah I know... Obviously I watched him and make sure he knew what he was doing and he knew all the safety features and begin to do for a while. After a short while he was done doing pretty much everything I needed the meat slicer 4 so I put him on something else, slicing potatoes for Duphinois.... It's basically a fancy word for scalloped potatoes with heavy cream and parmesan and butter. Anyway, those potatoes need to be very evenly slice because the dish is largely about presentation... The guy sucked with a knife, and so he figured in his brilliance, "hey, I sure love that meat slicer!" About 30 seconds into it, the potatoes being very starchy and often creating a vacuum on certain services caused, somehow, a suction of one of the potatoes into the blade and pulled his thumb just below the nail straight back and peeled it like a banana all the way to the joint, along the bone ! Let's just say it was the very end of his cooking career before it had barely gotten started.
Old Aug 6, 2013 | 11:18 AM
  #1526
RBX's Avatar
RBX
Note to self...
Meat slicer doesn't care what meat it slices!
Old Aug 6, 2013 | 11:34 AM
  #1527
Redeth005's Avatar
Hey RBx. Sorry about the finger. I know that crap hurts bad. I've had tons of deep cuts on my hands; mostly my fingers.
Hey was wondering if you could take some more pix of your new oil pan installed and possibly with a measuring tape from those high steer bars to the oil pan. Thanks to you I looked at my oil pan and seen that it has hit in the past. You can definitely make out some rubbing had happened. So I'd like to get the problem fixed before a make a wear hole in there. Lol
Old Aug 7, 2013 | 03:51 AM
  #1528
RBX's Avatar
RBX
Not sure if this helps, but here is the a pic of the 3VZ 2wd oil pan installed. My panhard is very very close a full stuff, but doesn't touch
Old Aug 14, 2013 | 02:56 PM
  #1529
RBX's Avatar
RBX
Bump can is off because it won't clear in this position, It's close to the same position on the other side, but honestly I haven't 'X'd the tops of the towers yet. My buddy is bringing a tram bar over so getting the towers square when they are in the final position will be more accurate then me and a tape measure, well, in theory.
the tower needs to tilt out a bit, but that is going to make it closer to the tire, and I just have little 31.5"x10.5" BS is 4.375" (IIRC). I am just trying to get the most clearance possible. The coil also hits the panhard bracket, the rear of the can mount, I could probably slide the bracket forward 3/8".
Double stuff
Ride height?
Compress driver side
Close, but it clears by about an 1/8"
Old Aug 14, 2013 | 03:36 PM
  #1530
Redeth005's Avatar
Wow just seen you replied with a picture of that oil pan. Thanks RBx. That's a huge difference compared to the normal one. I'm gonna have to do this mod in the future. Do you also need to take the 2wd dipstick when you get it?
Old Aug 14, 2013 | 03:41 PM
  #1531
RBX's Avatar
RBX
Not for the v6, but you will need the oil pickup since its a rear sump.
Old Aug 14, 2013 | 04:39 PM
  #1532
Redeth005's Avatar
Oil pickup? What do you mean?
So my current dipstick will work then? All ill need is the pan correct?
Old Aug 14, 2013 | 05:40 PM
  #1533
RBX's Avatar
RBX
Drop your oil pan, you have a front pickup and it won't work
Old Aug 14, 2013 | 07:54 PM
  #1534
ToyoTech559's Avatar
wow thats alot of work. gonna be sweet once done. im still new to the linked/coil-over set up but i have seen guys just run air shocks. any reason you dont just do that?
Old Aug 14, 2013 | 08:09 PM
  #1535
RBX's Avatar
RBX
Air is no substitute for coils when you drive to your wheeling spot. Maybe on the back but I wouldn't want it on the front, I'm sure other folks that know way more then me would argue.
Old Aug 14, 2013 | 09:28 PM
  #1536
RBX, .....SIIIIICK WORK! I'm often impressed with some of the things you do,.... But this is the tops! it looks intense man... Kudos for sticking it out, you really did a nice job so far.
Old Aug 22, 2013 | 02:59 PM
  #1537
liveoffroad's Avatar
hey RBx,
i know this is buried a ways back in your thread but i'm wondering how that puma compressor is holding up? i'm thinking of getting one to replace my quick air 2. how fast does it air up your tires?
Old Aug 22, 2013 | 05:29 PM
  #1538
dropzone's Avatar
Fossilized
Front is looking awesome
Old Aug 22, 2013 | 05:47 PM
  #1539
RBX's Avatar
RBX
Thanks guys.
Puma compressor is holding up well. It's not the fastest at airing up, but I don't have anything to compare it to other then my shop compressor.
Old Aug 27, 2013 | 03:12 AM
  #1540
RBX's Avatar
RBX
Well, I'm still at it, but the clearance is so close with this SAS that I cannot afford to guess if I have enough room before I burn it all in, so I need to get so better backspaced rims and the 35"s on her first. I'll be selling my Firestone A/Ts with the ProComp rims to fund the new shoes and meats.
I'm gonna get these rims...
Interco BirdDog
