RBx 1988 4Runner Build-Up Thread
Old Apr 29, 2012 | 06:39 PM
  #1141
SHAGGY21's Avatar
1UZ-fe. That's all I'm sayin
Old Apr 29, 2012 | 08:36 PM
  #1142
RBX's Avatar
RBX
Shaggy, I had a 1uz months ago, if I new what was brewing...
Ian, thanks man.
Old Apr 29, 2012 | 08:40 PM
  #1143
ChefYota4x4's Avatar
Ahhhhhhhh, ...dang you and your SICK 1UZ Second Gen, Shaggy! lol... Especially while I'm dealing with these stupid OBD1 mysteries/Smog issues, lol. Course, I wouldn't mind having RB's project running, either... But alas, it's more of my DD than anything right now, so I guess I'll just live vicariously through you guys! lol.
I hear ya, RB.... best wishes on the 'patience' game!
Old Apr 30, 2012 | 05:35 PM
  #1144
RBX's Avatar
RBX
Removed the leaky freeze plug. Poking a it with a flat head sprung a leak immediately, I was running on borrowed time, yikes!
Used a pry bar and she popped out, after swearing at it
Old May 1, 2012 | 06:06 AM
  #1145
irab88's Avatar
pssst!
http://washingtondc.craigslist.org/n...985664796.html
Old May 1, 2012 | 06:17 AM
  #1146
RBX's Avatar
RBX
Ha, i was actually excited at first cuz i thought it was an diesel 5L.
Old May 1, 2012 | 06:26 AM
  #1147
irab88's Avatar
if it was diesel, i'd've posted it on your other thread.
i actually considered buying it, but my bank account got the better of me
Old May 1, 2012 | 06:29 AM
  #1148
RBX's Avatar
RBX
650$ doesn't seem bad, but you will need wireharness and ecu for a JDM engine(good luck) or you may be able to megasquirt it. It is also a I-6cyl....long.
Old May 1, 2012 | 06:36 AM
  #1149
irab88's Avatar
like i said: my bank account got the better of me
Old May 22, 2012 | 11:31 AM
  #1150
RBX's Avatar
RBX
Heads and exhaust manifold are on. Hopefully tonight ill have the intake on. Once i get this boring maintenance done i can move onto funner mods(yes i said funner). Actually just finish up my OBA and tire carrier (hitch reinforcement) mod. I'll also be mounting my CB antenna to the tire carrier, and maybe(just maybe) i'll be able to build my JerryCan mount for the swing out. I have a custom hi-lift mount installed on the swing out already.
Maintenance is Boring, that is the tip of the day!
Old May 22, 2012 | 12:03 PM
  #1151
Boring or not... IT'S GONNA BE BACK IN BIZ for the interim! lol.
Posting expired... What's that, Ian? 3RZ?
Old May 23, 2012 | 05:22 AM
  #1152
irab88's Avatar
no, it was a 2jz or something. an i-6 with turbo(s). don't remember now
Old May 23, 2012 | 05:48 AM
  #1153
RBX's Avatar
RBX
This one puts out 900hp. They took the V8 out of the Lexus SC430 in favor of the highly tuneable 2JZ-GTE. Stock the 2JZ-GTE is reported from the manufacturer with 276hp...many think this figure is not acurrate, but an agreed HP for Japanese auto industry HP cap.
But fuel eco is a primary concern of mine, or i would have started this swap a while ago.
Old May 23, 2012 | 06:03 AM
  #1154
irab88's Avatar
ha! you see what's covering the intake?
Old May 23, 2012 | 06:09 AM
  #1155
RBX's Avatar
RBX
The other photos have the air cleaner attached. But 'what' is covering the intake? looks to me like the bottom of a catch can or similar.
Old May 23, 2012 | 06:21 AM
  #1156
irab88's Avatar
lemme put it this way: it was stretched over the intake
Old May 25, 2012 | 08:00 PM
  #1157
RBX's Avatar
RBX
Finished assembly of the 3vze this afternoon. Cranked it, and it won't start. I have fuel and spark. I think the afm that is faulty may have died. I am also getting code 51. But I haven't been able to get it to even sputter. Just crank.
Old May 25, 2012 | 08:14 PM
  #1158
DAYUM! Sorry man... Hmmm..... Have a Veezee AFM you can borrow?
Old May 29, 2012 | 05:49 AM
  #1159
RBX's Avatar
RBX
Update from a holiday weekend:
Timing was out , I was aligning the wrong mark on the crank pulley due to the many nicks and chips on it. That has been resolved.
However, upon setting my timing there seems to be an issue. A start and idle are tip-top....give her some gas and she makes a new noise like a cylinder is not firing. I know i need a new VAFM which i have read may cause the same issue, but i am thinking it may be an injector clogged because it sounds like it is coming from the passenger bank of cylinders.
Any ideas before i pull the plenum, and start testing?
Oh, and i reinforced my hitch for towing and added my CB antenna, just need to wire up the connector in the cab.
I did all the above over the weekend in between renovating our dojo, going to my son's concert in Frederick and a holiday cookout yesterday.....i love it when a plan comes together.
Old May 29, 2012 | 05:59 AM
  #1160
irab88's Avatar
did you try any of the injector cleaner stuff in the tank? i'm not familiar with the 3.0, but can you get a stethoscope (or piece of tube, etc) to the injectors?
those are my only suggestions. glad you finally got that thing running again
