RBx 1988 4Runner Build-Up Thread
Old May 24, 2011 | 03:06 PM
  #461
irab88's Avatar
yeah, you just wanted to see if any of us knew what the problem was
Old May 24, 2011 | 07:10 PM
  #462
RBX's Avatar
RBX
^^^ of course, trying to see who the real knowitalls are.
Old May 24, 2011 | 07:13 PM
  #463
rattlewagon's Avatar
Glad you got it figured out!
Old May 24, 2011 | 08:35 PM
  #464
irab88's Avatar
so are you still getting rid of the egr stuff?
Old May 24, 2011 | 09:13 PM
  #465
ChefYota4x4's Avatar
Yeahhhhhhhhhhhhhhhhhh boooooooooooooy! That's awesome, man!
How's it ridin?
Old May 25, 2011 | 03:48 AM
  #466
RBX's Avatar
RBX
EGR removed 3VZe no idle, dies after a few seconds
Thanks for the support gentlemen
I now think my fuel pressure gauge is goofy, and not actually posting 70psi.
Yes the PAIR and EGR systems are deleted, removed, eliminated... very simple, quick mod to clean up the engine bay.
Because i was victorious, i ordered my pipe, and silicon couplers for the ISR mod.
No real difference in ride characteristics, but i blame that on the soon to be evicted A/T sucking what little life the 3weezee has.
One thing i did notice was that the idle was a bit lower at 5500-RPM, but idled very smooth for being so low. An adjustment of the idle screw cured that, and then she got Seafoamed....alot.
I discover a bunch of oil in my plenum, and not sure why. I have a new PCV in-place. However, when i did the valve cover gaskets, the metal splash shield on the passenger side fell out, so i left it out.
Could that shield be responsible for the oil in the plenum?
I have another valve cover to install, but i have to remove the plenum for that....don't want to if i don't have to.
This is section is just for search results:
EGR remove, EGR removal, EGR elimination, EGR delete
PAIR remove, PAIR removal, PAIR elimination, PAIR delete
Truck will not idle, dies after a few seconds once started. Replace the bolt that holds the EGR valve bracket on th e front of the plenum, it creates a huge vacuum leak.
Old May 25, 2011 | 04:52 AM
  #467
irab88's Avatar
I have another valve cover to install, but i have to remove the plenum for that....don't want to if i don't have to....
yeah, i think the splash shield being gone would do it
Old May 25, 2011 | 05:38 AM
  #468
RBX's Avatar
RBX
I didn't think about it when i did the valve cover gaskets, so i guess i will clean the plenum and do th gaskets while i wait for my intake stuff to arrive.
This is actually the reason i get the blue smoke on start up, it has been greatly reduced since i removed the breather tube that feeds the intake.
Old May 25, 2011 | 06:40 AM
  #469
irab88's Avatar
makes sense. cool. now you know that (some of) the smoke wasn't a bad ring or something.
Old May 25, 2011 | 06:47 AM
  #470
S.Skinner's Avatar
Glad to hear your getting it running again! Im getting closer every week myself, got the secondary cooler ( brand new ) paid for from a fellow yotatecher, so it should be here soon. Still paying off the block and heads slow and steady. With some luck i should have the lower end back and start putting it together next friday ish.......lol
Old May 25, 2011 | 07:09 AM
  #471
Sweet, just one 'lesser evil' find after another, eh?
Old May 25, 2011 | 07:16 AM
  #472
RBX's Avatar
RBX
the next evil to be eradicated will be the A340...i'm going to work on some hexes tonight!
Old May 25, 2011 | 07:18 AM
  #473
Hmmmm, don't laugh at me, .......but .....is that a Trans? lol.(Sorry, not a 3.0 guy<<<< hope that didn't make the mocking worse! hahahaha)
You'll get it, RB, ....wishing for no problems for ya!
Old May 25, 2011 | 07:19 AM
  #474
irab88's Avatar
a340? huh?
(mark- it's the auto tranny)
Old May 25, 2011 | 07:21 AM
  #475
Hahaha.... ^^ >> Good'n! And YES, RB, ....if that's the case, ....WHEN YOU FLYING OUT TO HELP ME? HAHAHAHA.
Old May 25, 2011 | 07:33 AM
  #476
RBX's Avatar
RBX
the a340 is also found behind the 22re...nooobs...ha!
Chef, i'll fly out when you buy my ticket, never been to Palos Verdes, wait...i just looked at the map, i have been all around there but never PV. (i was born in LB, but not a member of the LBC...haha)
I have friends in Santa Monica, and West Hollywood.
Old May 25, 2011 | 07:36 AM
  #477
Wow, small world.... I was born in Santa Monica(now known as the Peoples Republic of Santa Monica! hahahaha).... Worked in LB for a time. Anywhooooo, "LBC", HAHAHAHAHA! Chickidy Check Yoself before your rickidy wreck yoself, Homie! hehehe.
Anyway, ....it's the more Common Auto Trans, right? lol.
Gotta run,.....off to have the OEM LCA bushings squeeeeeeeezed out and new ones FORCCCCCCED in! lol.
Old May 25, 2011 | 07:42 AM
  #478
RBX's Avatar
RBX
yes A340 is common
Old May 28, 2011 | 06:31 PM
  #479
RBX's Avatar
RBX
No blue smoke on start up, replaced the passenger valve cover, one without a broken oil shield inside.
Then I started her up, let her idle a bit and figured I'd give her a good few revs before took her out for a shake down, then the throttle sticks wide open.
Turn off the truck and figure out that the accelerator cable has delaminated from the plastic around the cable and is bunching up in the sheath. Nice to have found that gem while sitting in my driveway! Ran to the local yard and grabbed a newer better version from a 95 for ten smackers.
Tore into the r150f and ordered my adapter from inchworm while it's on sale!
That is all
Old May 28, 2011 | 08:46 PM
  #480
twistedyota's Avatar
glad the sticky throttle happened in a safe place. good luck on the rest
