RAD4Runner's 1986 4Runner dlx Build-up
Old Nov 28, 2017 | 08:25 AM
  #921
coryc85's Avatar
Nice Ray, looking forward to seeing what you do on those cargo sides. Are the washer bottle and jack holder permanently gone or are they just removed for the picture?
Old Nov 28, 2017 | 11:54 AM
  #922
RAD4Runner's Avatar
Thanks, Cory,
I hope everyone had a fine Thanksgiving weekend, and had burnt those calories already
Pics were taken while in-process. Rear windshield washer reservoir and pump, bottle jack storage and handle extension rod will be re-installed. I am deleting rear wiper and windshield washer. May re-purpose windshield washer/pump into:
1) Water storage pump, OR
2) Cajon/Tejon/Towne Pass cooling-system boost with irrigation spray nozzle in front of grill - away from air intake, of course
Old Nov 30, 2017 | 07:37 PM
  #923
RAD4Runner's Avatar
Deleted Hidden Fasteners and Streamlined Inner Side Body Panel
I detest hidden (pop-in) fasteners and
I hate having to remove other parts in order to remove / access another; in this case:
1) Having to remove the side window garnish just to remove the inner body panel, say to work on the speaker, etc.
2) Having to unmount the front seatbelt, and the rear passenger seatbelt anchor to completely remove the panel from the truck.
Solution:
I removed the pop-in fasteners, replaced then with nylon expansion nuts for 7mmx7mm hole and #8 finishing screws from ClipsAndFasteners.com.
I trimmed the top edge of body panel board by about 1/8 inch and glued the vlnyl cover back. Also trimmed the edge of the vinyl that wraps around the door frame and glued it back to the board.
I slotted where the seatbelt goes through the inner body panel board.
Notched where the rear passenger seatbelt anchor screws THROUGH the body panel board.
Original Mounting Holes - Round
Mounting Holes Squared
Expansion Nuts Installed
MODIFIED BODY PANEL
OK, OK... NoT only did I notch this - I BOTCHED IT- LOL!
BODY PANEL INSTALLED
Now I can easily remove or re-install for spares storage by using a screwdriver. No need to read the manual to figure out those stupid clips.
Old Nov 30, 2017 | 07:55 PM
  #924
RAD4Runner's Avatar
Cubby Hole in Side Body Panel
I disposed of the inner quarter panels to replace them with full door panels, and there's a nicely-placed opening between the front side panel and the roll-bar. Perfect for a cubbyhole (IIRC, the SR5 has a similar one but accessible by the passenger.) This one is accessible from the rear deck when camping in there. I think this would be perfect for pocket contents, phone, glasses, headlamp, etc. when camping in the back. I amy also put the rear window switch in there.
So, while I'm in there cleaning up the body compartment, I made an interim compartment out of foam. Should be functional now. Will make it pretty later...
Old Dec 2, 2017 | 04:09 AM
  #925
SomedayJ's Avatar
It looks good, tidy and practical, easy and fast access to those compartments now.
Other thing I'd like to ask you, do you plan to install a popup tent on your 4R roof in the future? Do you like them?
Old Dec 2, 2017 | 12:38 PM
  #926
RAD4Runner's Avatar
Why no Roof-Top Rent (RTT) for me :)
Originally Posted by SomedayJ
It looks good, tidy and practical...
Thanks, Fer!
... do you plan to install a popup tent on your 4R roof in the future? Do you like them?
No and no, because I don't want a $700 tent that I could not carry in my backpack to here...
Franklin Lakes, Mineral King Wildernes, CA
or here...
Ingraham flats Camp on Mount Rainier
or load on my kayak to here...
(Pelican North Beach on Tomales Bay, CA)
or take on a 10-minute walk to here...
Environmental Campsite above McWay Waterfall in Big Sur, CA
And MOST IMPORTANTLY... what if I've already setup tent and realize I'm out of beer? - LOL!
Old Dec 3, 2017 | 02:45 AM
  #927
SomedayJ's Avatar
Thanks, Fer!
or here...
(above McWay Waterfall in Big Sur, CA)
You've been in amazing places!
Ok, I understood, you don't like hidden fasteners, pop up roof tents and run out of beer I think nobody like the last one...
Old Dec 17, 2017 | 09:02 PM
  #928
RAD4Runner's Avatar
Throwback to last year's Route 66 Road Trip...
Driving Through Oatman, Arizona were asses roam the streets
Old Dec 18, 2017 | 05:46 AM
  #929
dropzone's Avatar
Fossilized
great video!
Old Dec 18, 2017 | 10:12 AM
  #930
muddpigg's Avatar
RAD, finally able to get into longer post since I got off Iphone and onto laptop. Awesome write ups!!! Thanks for taking time to post your progress. I'm only on page 2. Got some catching up to do but for now out to the garage.
Old Dec 18, 2017 | 10:25 AM
  #931
RAD4Runner's Avatar
Thanks, guys!
Originally Posted by dropzone
great video!
LOL! Yeah. Sometimes I check my email with my phone then start replying. Then, I catch my self. Screw this.... so hard to do any graphics or even post plain pics
On this day last year, I was standing on a corner in Winslow, Arizona... on my Route 66 trip from so Cal to Mid-point in Adrian, TX... I would be happy to do that road trip again!
Turns out that the real story is:
Jacksone Browne's car broke down in Winslow Arizona.
He was actually on a corner in Flaggstaff Arizona when he saw a girl drive by in a pick-up truck. However, it was really a Toyota Truck! "Flat-bed Ford is just used to make the lyrics "...It's a girl, my Lord, in flat-bed Ford" rhyme.
Old Dec 19, 2017 | 05:40 PM
  #932
RAD4Runner's Avatar
Cargo Organization / Tie-Down / Sleeping Pad Storage
Cap mounting bolts doubling as (light) cargo tie-up points.
For Interim anchor, I used webbing straps stiffened with super-glue, melted clearance holes for the mounting bolts (8-mm?).
This is temporary and only to stow my sleeping pad or soft cargo against the topliner when not used. This would get it out of the way, and because it covers most of the width and length of the roof, will add to insulation from wind noise.
Yes, bolts were torqued back to 10 foot-pounds. I will replace with metal D-rings when I find the right ones.
CONTINUING THIS DISCUSSION HERE.
Old Dec 22, 2017 | 10:28 AM
  #933
RAD4Runner's Avatar
Selling my Rear Wiper Motor, Mount, arm and Step (aka parking)
I removed my perfectly-functional rear wiper assembly in excellent condition (except for surface rust on wiper are) because I want to make room in that upper-rear corner for storing my sleeping pad, and I had never absolutely needed the wiper.
$55 shipped to mainland U.S.
It's on classifieds here:
https://www.yotatech.com/forums/f109.../#post52385519
Old Dec 22, 2017 | 11:45 AM
  #934
wrenchtech's Avatar
Been standin’on a corner in Winslow, Arizona myself. I used to transport motorcycles, based in Millwalkie, running out to California and Arizona in my 18-wheeler. Traced Route 66 many times. And when I had room, I would haul some nice rust free Toyota parts back to Wisconsin
Old Dec 22, 2017 | 12:03 PM
  #935
RAD4Runner's Avatar
SUWEET! I love the drive, especially on the actual old road. I did
between Santa Rosa and Cuervo, NM.
Wished to do the "La Bajada Switchbacks" but I did not have enough information and heard it's rougher so I did not want to do it alone.
Old Jan 4, 2018 | 03:37 PM
  #936
RAD4Runner's Avatar
To Little Blair Valley, Anza-Borrego Desert tonight, so off the grid until Saturday afternoon
Old Jan 6, 2018 | 09:37 AM
  #937
MadMax2013's Avatar
nice truck
Old Jan 6, 2018 | 04:02 PM
  #938
RAD4Runner's Avatar
Originally Posted by MadMax2013
nice truck
Thank you, Sir!
No-frills but she runs well. I'm unemployed but have been too busy with adventures to have time to make her pretty - LOL! I still haven't even fixed the leaking gutter leak. LOL!
Old Jan 7, 2018 | 10:30 AM
  #939
RAD4Runner's Avatar
Anza-Borrego Weekend
SUNRISE FROM OUR CAMP IN COYOTE CANYON
SYNTHETIC 01L IS SUPERIOR, SYNTHETIC COFFEE IS NOT, SO I PREFER MINE FRESHLY-GROUND, FRENCH PRESSED.
THE HILLS DWARF THE VEHICLES ALONG FISH CREEK WASH ON THE WAY TO THE WIND CAVES
OVERALL VIEW OF THE WIND CAVES
FLINTSTONES DIVORCE - LOL!
Old Jan 7, 2018 | 11:24 AM
  #940
coryc85's Avatar
Ray - love your adventures man, you are certainly getting out there. And I love a good french press with some freshly ground beans.
