Ocell's 88 4Runner build thread
Old May 20, 2014 | 08:36 AM
  #701
Ocell's Avatar
Originally Posted by PayneInTheYota
Hey Ocell, it's been a bit over a year since you bought your bumper. Have you used it for any recovery? How's it holding up? Just curious I'm kinda in the market for a bumper. Thanks.
I've used it several times. In the video I just posted you can see me getting winched up a ledge. I also used it on the same trip to get out of some mud. I've used my own winch several times to get out of trouble.
I've also used the tubes against a few trees and a wall in a creek bed. I love it, and highly recommend it if you're considering one.
Old May 21, 2014 | 04:05 AM
  #702
coryc85's Avatar
Originally Posted by Ocell
I didn't check the backlash. I worked very carefully to put everything back in exactly as I had removed it, hoping that the backlash would stay the same. Maybe that's not how it works?
Well, it could stay the same, but in my opinion it's pretty hard to get everything exactly back where it was with just some marks. For instance, you can mark the adjuster wheels, but if you put it in a thread or 2 deeper when you start off, marking it doesn't mean that when your marks line up the adjuster will be same as it was. All of this doesn't really matter that much though, I wouldn't take the diff out just to measure the BL. I think you're probably going to be fine the way it is, if you ever pull the axles to do the bearings maybe that would be a good time to check the BL.
Great videos by the way, keep them coming.
Old May 26, 2014 | 09:05 AM
  #703
Ocell's Avatar
My first broke CV axle! This weekend I did a 2 day trip to Katemcy Rocks in Grit, Texas.
http://katemcyrocks.com/trails.html
Near the end of the second day I heard a loud pop while starting a climb cut hard left. I backed out and drove a bit, everything seemed fine. I thought it was just the locker unloading. I tried the climb again and made it fine, then did a couple more trails.
On the drive back to camp things started flopping around and it became obvious I had broke the axle. I unlocked the hubs and made the 2 hour drive home at 80mph in an immense storm with no problems.
I'm putting a video together and hope to have it posted soon.
My first broke CV Axle! Katemcy lived up to its reputation this weekend. by Ocell, on Flickr
Old May 26, 2014 | 09:09 AM
  #704
Ocell's Avatar
Thanks for the feedback. I was careful to count exposed threads when I was putting the caps back in, but I agree with your points.
Old May 26, 2014 | 09:21 AM
  #705
Ocell's Avatar
I decided to bite the bullet and replace the fuel pump to see if it fixes my issues. I've finally learned my lesson, between working on this 88 4Runner and my 91 BMW E30, to take things apart before ordering new parts.
I pulled the access panel to get to the fuel pump and found that someone else had trouble breaking the fuel line off of the hard line coming off the top of the fuel pump hanger. It folded the hard line, so I've been running with restricted fuel supply this whole time. I then had my own shot with PB Blaster, a wrench, a vice grip, and drilling a hole through the hard line so I could stick a screw driver through it for leverage. No luck. I finally popped it loose by cutting the hard line off and putting it in a vice with a screw through the hole I had drilled to keep it from rotating.
This is what I found when I removed the access panel. Ugh!
Even this didn't work.
This made it easy.
My Katemcy trip was coming up in a week, so I didn't have time to mess with pick-n-pull for a new fuel pump hanger. I thought of cutting off the threaded connectors, flaring the hard lines, and running standard injection hose. But, I was worried about getting to the end of the hard line that runs inside the frame up to the engine to flare it. In the end I just spent the money ($140, ugh) to get a used fuel pump hanger that showed a disconnected fuel line in the photo. Many of them showed the fuel hose cut off, so I figured they were seized on as bad as mine was.
I ordered a new Denso fuel pump from Rock Auto and got it all together the Thursday evening before the trip. I drove 2 hours to Katemcy, ran all weekend on the trails, and drove it back home with no problems. I'm feeling optimistic that I've fixed the issue. I'm assuming my pump was getting killed over time by trying to push fuel through that pinched line.
Old May 26, 2014 | 09:37 AM
  #706
twistedyota's Avatar
That is how I bout my red 4runner bone stock for $500, the guy couldn't get it to run, found the fuel hard line their to be kinked, it took out the fuel pump filter and gauge.
Old May 26, 2014 | 09:49 AM
  #707
Ocell's Avatar
Is that how you chose your name, too?
Old May 26, 2014 | 09:54 AM
  #708
Haha, no had another yoga before that one.
Old May 26, 2014 | 02:06 PM
  #709
Red Wagon's Avatar
You've been busy.
What kind of axle will you go after?
Old May 26, 2014 | 04:28 PM
  #710
Ocell's Avatar
Originally Posted by Red Wagon
You've been busy.
I'm just planning on getting whatever's new (not a reman) at a local store like Advance or O'reilly's. I was looking in to the lifetime warranties, but they don't cover off-road use and I think I'd look suspicious when I roll up with a broken axle and rock-rash on my bumpers.
I'm fine with swapping in the $60 OEM style replacements for now. I've lasted a year and a half without breaking one, and I'm hoping to be SAS in a couple years anyway. $60 a "pop" isn't that bad.
Old May 26, 2014 | 04:59 PM
  #711
PayneInTheYota's Avatar
I have two cv axles I just pulled out of my truck (doin an SAS) I'll give them to you if you pay shipping. Should fit in a flat rate box.
Old May 26, 2014 | 05:21 PM
  #712
Ocell's Avatar
Whoa, that's awesome. Let's take this to PMs.
Old May 26, 2014 | 06:07 PM
  #713
Ocell's Avatar
Here's where I broke the axle. As always, the video doesn't do anything justice!
Old May 26, 2014 | 08:53 PM
  #714
I sent you a PM I don't know if it went through I'm on mobile and it does weird stuff.
Old May 27, 2014 | 09:12 AM
  #715
Red Wagon's Avatar
Nice one Payne!
I've been happy with all my Napa CV shafts. No idea how I've not broken one yet.
Old May 29, 2014 | 09:43 AM
  #716
Ocell's Avatar
Here's the full video from the trip.
Old May 30, 2014 | 09:58 PM
  #717
Red Wagon's Avatar
At 8 minutes roughly I bet he was clenching.
Old May 31, 2014 | 05:56 AM
  #718
Turbo_4runner's Avatar
Looks like you were all having some fun! I really like all the work you've done with your truck
Old Jun 2, 2014 | 11:26 AM
  #719
Ocell's Avatar
Thanks!
We did a little tooling around in a creek bed yesterday. My friend shot this video and accidentally sent it to me in slow motion. It's kind of mesmerizing.
I made it up by turning hard-passenger right after he turned off the camera.
Old Jul 7, 2014 | 12:41 PM
  #720
Ocell's Avatar
On my last trip out to Hidden Falls I was backing off of a ledge and I guess a rock caught my exhaust. It bent it back and I drove over it as I backed up. It broke the mounts off of the exhaust and broke the weld at the front of the muffler. I'm trying to figure out a better way to route the pipe so it doesn't hang down as low, and I'm trying to find a decent shop in Austin that can bend a new pipe and hopefully salvage this muffler. The system is fine as-is and I don't want to drop a ton of money getting all new stuff.
Hidden Falls Trip June 2014 by Ocell, on Flickr
