Mike's 93 Pick~Up Build
Old Apr 20, 2013 | 05:44 AM
Toyota~Boy's Avatar
Originally Posted by thefishguy77
Glad the eyes ok. Truck looks great. Unless you have tire clearance problems I probably wouldn't do a body lift I think it looks great in relation to the tires. I have a nice "parts" truck that's complete with a mildly bent frame. I need to find a frame straighter. Any chance your in Washington? Keep up the good work
WV....
Yeah I have a little clearnce problems.
Old Apr 20, 2013 | 05:50 AM
thefishguy77's Avatar
Well then a small BL is probably in order
Old Apr 20, 2013 | 07:09 AM
kornhuskerwizard's Avatar
Glad your eye is ok!! Truck is coming together nicely. You running your swaybar? Also have you done any adjustments on the torsion bars?
Old Apr 20, 2013 | 07:26 AM
Toyota~Boy's Avatar
I don't run a sway bar. I have one however I removed it. I haven't messed with the torsion bars. It seems like every time a turn a bolt it breaks on this truck. I guess that's because it sat in a yard for several years unmoved. I have been spraying the adjustment bolts every other day with PB blaster so hopefully they will be freed up.
I been doing a lot browsing here lately on bobbed beds. I'm highly considering bobbing the bed on this thing. I have all the tools needed and I'm a excellent welder so I do not think it will be hard to do
I been searching bumpers as well. I'd really like to build a set but I'm also considering a few tube bumpers that I've seen. Man I wish I had a tube bender
The main reason for the body lift is so that I have no rub at all. It also helps out on accessing certain bolts. One of these days I'd like to run a 35" tire and maybe a engine swap. So who knows. A SAS may come once I finish up my 87.
Old Apr 20, 2013 | 08:31 AM
  #25
Gizler00's Avatar
I like the idea of a bobbed bed. And if you have the welding skills, I would dive into the bumper project as well. You can pick up a simple hydraulic pipe bender from harbor freight. That's whAt I use to bend stuff for my rig.
Although I don't like body lifts, there's no denying that it gives you waaaaay more access to certain areas of the vehicle. My buddies reg cab that we put a SBc into has a body lift, and it has made things alot easier.
Old Apr 20, 2013 | 08:57 AM
  #26
Toyota~Boy's Avatar
Harbor Freight huh.... I've seen those but been sketchy of buying one. Does it work as good as the description says.
Old Apr 20, 2013 | 10:04 AM
  #27
Gizler00's Avatar
Yeah. It's just a simple plain Jane bender. I made a set of sliders with it. And also made a top tube for a front bumper.
Again it's not great but it works.
Old Apr 20, 2013 | 10:06 AM
  #28
Gizler00's Avatar
It's this one.
http://www.harborfreight.com/garage-...der-35336.html
I use it in the auto shop with my students. If I had the money I would definitely spring for something better and easier to use.
Old Apr 24, 2013 | 05:26 PM
  #29
Toyota~Boy's Avatar
I didn't get to meet with the frame guy on Sunday. I'm assuming something came up on his end.
Today I replaced my funky antenna with the factory one. I also redid my exhaust.
As for the exhaust, I removed my cat and installed a 30 series flow master. It's a 2 1/4 inlet and dual 2" outlets. I just put 2 nice chrome turndowns on it. It has a really deep rumble but highway noise is a little loud. Shouldn't be to bad once I get tailpipes. I will post a video tomorrow.
Old Apr 24, 2013 | 05:47 PM
  #30
Toyota~Boy's Avatar
I went ahead and filmed a small vid tonight. Heres a link.
Old Apr 24, 2013 | 06:19 PM
  #31
videos kinda dark, but engine seems to be pretty snappy. Sounds good too. Was engine not warmed up? Idling kinda high (2k).
Old Apr 24, 2013 | 06:22 PM
  #32
Toyota~Boy's Avatar
Nope cold as cold gets lol..... I was goona wait for it to warm up but it's cold out side lol. It was 70+ outside yesterday. It's like 40 out today lol. I will get a better one tomorrow after or during work lol. I'm my own boss I get away with that stuff
Old Apr 24, 2013 | 06:33 PM
  #33
Ahhhh ok, so it idles down after its warm i assume. You get rid of the egr system?? Im assuming you dont require it.
Old Apr 24, 2013 | 06:39 PM
  #34
Toyota~Boy's Avatar
Umm I kinda did my own little EGR mod. But yeah it's gone along with some other stuff. I'd love to remove half the other unused stuff but I do not know what needs to stay and what can go.
I live in WV. We do have a vehicle inspection however its a visual inspection. No rust holes, tires can't stick past fenders no more then 2". We have a hight limit. Not to bad though. As far as emissions, you can do whatcha want.
Old Apr 24, 2013 | 06:56 PM
  #35
have any blockoff plates?
Old Apr 24, 2013 | 07:04 PM
  #36
Toyota~Boy's Avatar
No I don't have any. I left the manifold tube on and welded it shut. I then cut the EGR in half. Welded it shut then bolted everything on.
Old Apr 24, 2013 | 07:08 PM
  #37
That works too, ive done that. Same principle.
Old Apr 24, 2013 | 07:16 PM
  #38
Toyota~Boy's Avatar
Yeah the plates are just cleaner.
I was looking at getting the complete deal from LC. I would like to get completely desmogged and all prior to buying all the plates. My truck had factory air so I have all those plug-ins and vacuum lines that need disposed of along with a few other things. I'm just unsure were to start. I'm trying to clean as much junk out of my engine bay as possible. Keep in mind I have to replace the entire front clip. So what's not needed will be less to put back. And a header will be coming soon. I have the TriY headed on my carbed 87. I'm unsure of what I want for this one.
Old Apr 24, 2013 | 07:23 PM
  #39
I love lc's stuff, cant afford it though. KelvinB made me plates. Plenty of threads on here that tell you what sensors n vac lines you dont need. Im in the process of doing it myself on my runner.
Old Apr 24, 2013 | 07:36 PM
  #40
Toyota~Boy's Avatar
Yeah I've read a few. Once I compile enough info ima going to do it. As well as take plenty of notes and pics to add to my build thread.
