Khione Runner
Old Dec 15, 2011 | 06:58 PM
nick89toy's Avatar
Khione Runner
Ok so I’m finally slowly getting starting on my 1990 4runner build so I thought I would start a build thread. Oh and props to those that know what Khione means.
A little bit of background information: I am 18 and I just started my freshman year of college and at the same time I work about 25-30 hours a week at a hospital to pay for rent, living expenses, and to fund the 4runner build, so I don’t have a lot of free time. Whenever I can, I make a 45 minute drive to my dad’s shop to work on my 4runner, so this will be a somewhat slow build. A couple years ago I got a 1989 ex-cab pickup with a solid axle and a 4.3, and since then I have pretty much been fixing and re-doing everything on it, but I have learned a lot in the last few years. So now I’m trying to sell my pickup and build a 4runner for a couple reasons. I wanted something with four doors and I wanted to have something that I can say “I built that”.
Here is my 89’ that I daily drive
And here is my 1990 4runner the day I picked it up for $1300. It will also be a daily driver. It is really clean and I’m looking forward to having electric windows and remote/electric locks haha.
The plan is:
5.3 chevy vortec
700r4
Twin-sticked Ford 205
Ford Dana 60 front
14 bolt rear
14” coilovers in the front, some sort of coil spring in the back.
Tires are going to be a set of 38” toyos
I got the 3.0 removed as well as the auto transmission and transfercase.
Now there is a spot for the new power-plant to go.
I picked up a 5.3 vortec with 50,000 miles complete with all accessories, harness, and computer.
So I started cleaning it up because I swear I have OCD and I like my stuff looking nice lol
Here it is almost pieced back together. I still have to do some work to the water pump before I put it back on.
I’m going to be running a 700r4. I picked this up and it was pretty filthy, so I spent a couple hours with a wire brush and some crud kutter cleaning it.
I have been trying to collect parts ever since I got the 4runner earlier this year.
I got a hydraulic assist ram from surplus center
And I ordered ruffstuff brackets during their black-Friday sale. I will be running a front and rear 3-link.
Old Dec 15, 2011 | 07:10 PM
87 Deathtrap's Avatar
Wow. You don't play around! This should be an interesting build. Good luck!
Old Dec 20, 2011 | 12:01 AM
nick89toy's Avatar
I got a little more done this weekend, not too much though. I got the 5.3 ready so that it can take the water temp sending unit and oil pressure line when it's in.
Here is the oil pressure fitting threaded into a metric plug that I drilled and tapped.
And here are the adapters and fittings setup so that the water temp sending unit can go in. I drilled and tapped the block plug to 1/2" npt and adapted it down from there to 3/8" npt. It was a pain to get the block plug out because i had to make a 17mm allen wrench to fit it.
I also got my gauges in as well. I found out the hard way about how toyota does the factory lights backwards with the dimmer so my aftermarket ones were opposite when i had them wired through the dimmer.I didn't really feel like trying to make a voltage converter so i just wired them to the gauge light switched wire before the dimmer.
Old Dec 20, 2011 | 03:26 AM
dropzone's Avatar
Fossilized
Saw this build on pirate.. Looks good.
DD on full-size axles? Flares, H1 style backspaced wheels or not worries about tires sticking out?
Did you sell your truck yet or keeping it?
Old Dec 20, 2011 | 07:24 AM
Outsane's Avatar
looks like this is going to be a nice build.. in
Old Dec 20, 2011 | 09:52 AM
nick89toy's Avatar
The rear axle is a Cab-and-chassis 14 bolt so it is only 63" wide, and i'm going to narrow the Ford Dana 60 to about 64" i think. I'm going to try to run some bushwhacker flares as well. I have not sold my pickup yet, but I might be on Thursday, a guy is very interested and wants to test drive it and he has cash $$$
Old Dec 20, 2011 | 03:22 PM
bttrs's Avatar
wow, off to a great start i like you plans and the fact that your doing it right.
Old Dec 23, 2011 | 11:30 PM
nick89toy's Avatar
I got my GM master cylinder adapter plate done. I'm using a 1 1/4" bore from a 3/4 ton. Bolts are 3/8" countersunk fine thread.
Old Dec 25, 2011 | 09:48 AM
nick89toy's Avatar
Oh yeah Merry Christmas! Is it odd that an 18 year old gets parts for Christmas? haha my parents were very generous and got me some cool stuff:
A steering u-joint for the Ford power-steering box that I will be using and rebuild kit for my York air-compressor
And a seal kit for the steering box, and my dad gave me his flex-plate from his 6.0L to put on my 5.3
A seal and gasket kit for my Ford NP205 transfer-case, and a serpentine clutch for the York compressor
Oh and a bling 700r4 pan
Old Dec 27, 2011 | 12:26 AM
nick89toy's Avatar
OK so another small update: I got my York 210 all cleaned up and put new gaskets in it. I also tapped the two top ports to 3/8" NPT and I put in the oil sight-tube and breather. I also got brackets cut out to mount it as well and I will get a picture up when I get it mounted.
Old Dec 27, 2011 | 04:59 AM
Outsane's Avatar
The pile is growing
Old Dec 27, 2011 | 09:44 AM
nick89toy's Avatar
Haha yeah im trying to collect as many parts as I can until my dad gets his amigo done and then I can put the 4runner on the hoist
Old Dec 30, 2011 | 01:47 AM
nick89toy's Avatar
Ok so I've been working on getting my York mounted.
I cut part of the belt tensioner pulley off and flipped it upside down and put a smooth pulley on instead of a grooved one.
Also one of the spots for a water pump bolt needed shaved down because the bolt ends up right behind the tensioner with it flipped.
Before I put the water pump back on, I drilled and tapped it for a fitting for the steam port from the throttle valve.
I got all the plates cut out and drilled for the bracket. The two that bolt the engine will both be welded to a plate that bolts to the side of the york.
Old Jan 8, 2012 | 12:38 AM
nick89toy's Avatar
I went and picked up a 145 amp alternator today to replace the little 105 amp one. The new one is huge!
Once I got that on I was able to make sure the new belt that I got was going to work with the York. I welded up the bracket, painted it, and got the York on there solid.
Old Jan 9, 2012 | 12:01 PM
nick89toy's Avatar
I built a cover for my 14 bolt out of 1/4" plate and put the transformers emblem on there that I cut out last year in my shop class I also got a fill plug and welded it in there.
Old Jan 9, 2012 | 12:30 PM
RMP8080's Avatar
Nice, keep going............
Old Jan 9, 2012 | 06:28 PM
alex_mcnair's Avatar
sweet build! this one will deffinately top the pickup.
Old Jan 9, 2012 | 10:22 PM
RMP8080's Avatar
It going to be a monster of a Toyota.
Old Jan 9, 2012 | 11:48 PM
drew303's Avatar
nice work man! Great to see young guys getting into this stuff and not half azzing it! Keep it up! gonna be a nice rig!
Old Jan 10, 2012 | 02:14 AM
TinMan's Avatar
I agree, you are on your way to having one of the nicest runners on YT. I am not familiar with the York compressor, is it gonna be for onboard air, or AC?
