JonnyBoy's 1990 4Runner build
Old Jul 29, 2014 | 12:12 PM
  #321
JonnyBoy's Avatar
Originally Posted by Red Wagon
My fabricator pointed out the possible legal issues of a coil over SAS. If you ever get an inspection they may pull it off the road. If you ever get in an accident........ yer f'd.
Is that a Canada/Oz thing specifically? Utah does have safety inspections, but they don't specifically look for original equipment items, ie sway bars. A buddy here works at a shop that does state inspections and said that in the instance of sway bars it would only fail if it was there, but broken or disconnected. If it's totally removed, no problem!
Also Red, this is for the rear. The front is still gonna be leafs, the OME rear set I got from Mark.
Old Jul 29, 2014 | 12:33 PM
  #322
StewsRunner's Avatar
Are you keeping the 3-link or going to a 4-link in the rear?
Old Jul 29, 2014 | 10:55 PM
  #323
JonnyBoy's Avatar
Originally Posted by StewsRunner
Are you keeping the 3-link or going to a 4-link in the rear? Sent from my iPhone using YotaTech
3 link? Stock is a 4 link plus panhard, but the upper links are way too short and tiny, and the lowers aren't really long enough, either. If the rear links were left alone and I lifted the rear enough to match even a pretty low sas, the rear axle would end up further forward and the links wouldn't even be close to parallel with the ground, causing pretty bad handling and "flex steer" when it's all flexed out(the compressed side of the axle would end up further back than the drooped side, making it track crooked).
So this will make it a 2 link plus panhard, technically, but it will behave a little more like a radius arm(that's really more what it is). The upper link mount on the axle will be connected to the short tube that's connected to the lower "link" so there's still anti-wrap built in. It's has a few flaws, but since I'm not going for a ramp champ flex monster rig, I just need it to flex as well as my front will so it's got somewhat balanced handling. I think this will get me there easier than a leaf swap, and maybe even a little cheaper.
Old Jul 29, 2014 | 11:16 PM
  #324
ChefYota4x4's Avatar
Blue Bunny (From Monty Python! Lol)
Old Jul 29, 2014 | 11:24 PM
  #325
JonnyBoy's Avatar
Haha Mark! Although, with the Edelbrock shocks on there being slightly shorter than the OME's I had, the front doesn't droop enough to bind the cv's anymore. Well, that and my homemade diff drop spacers. Hopefully this radius arm setup doesn't allow a bunch of wheel hop, but I'm thinking it won't with such separation between the upper and lower link mounts on the axle to control anti-wrap.
Old Jul 30, 2014 | 11:35 AM
  #326
Red Wagon's Avatar
To be honest I have no clear idea but I have some educated guesses. If you notice on some websites they are very clear about NOT FOR STREET USE. Covers liability issues decide to street it anyway.
What I think the issue authorities have is backyard hack jobs ripping down the hwy over 100km an hour. Also these things are flexy and flexy is unstable. At speed paired with no sway bars and you have a dangerous road vehicle.
So, in some states you will likely go to jail after a bad road accident. I think they might be illegal in Canada also? Not sure if this is Canada wide or Provincial. I should know more about my own system........
I'm sure there is a work around. You might have to get special testing done. Checking body roll etc. They do this in Australia if you lift higher than 2 inches or increase tire size more than 2 inches or mess with track width.
Anything is possible with enough money.
Old Jul 30, 2014 | 11:38 AM
  #327
Red Wagon's Avatar
No it's a State thing I'm pretty sure. Look at disclaimers for 3 link kits on US websites.
Crossing lines into States where it's illegal and you can have issues. You'll not need to worry though if it's for the rear. It's already linked.
Why leafs front and coil rear? I'd take the kick for the load capacity.
I wheel heavy.
EDIT///
Read your reasons, they are sound. I can see that my axle is forward and I've bent the panhard and the little links look wonky too.
Old Jul 30, 2014 | 05:38 PM
  #328
kornhuskerwizard's Avatar
Rules and regulations are boring.
Old Jul 30, 2014 | 07:39 PM
  #329
Red Wagon's Avatar
So is jail.
Old Jul 31, 2014 | 01:42 PM
  #330
JonnyBoy's Avatar
I dunno Red, jail was pretty interesting and educational for me when I got to spend a night in the drunk tank...but what I learned is that I never want to go back!(Before anybody starts judging or whatever, I spent a night in the drunk tank cause I hit my brother first when he was charging at my mom. This was when I was a senior in high school, drove straight to school from jail)
As for the load carrying capacity, I'm with you on that one, but I can already load it up fairly heavy now and not bottom out, so either the spacers or the 80 series lift springs will be just as capable of carrying loads, or more.
Old Aug 19, 2014 | 09:31 PM
  #331
JonnyBoy's Avatar
Today was maintenance/repair day...got a couple r&r days off after my last assignment to Wenatchee, WA, so I made the best of a weekday off and visited the dealers in Ogden. First was the Subaru dealer for a few oil filters for engine break in and some new head alignment dowels since the machine shop mangled the originals removing them to mill the block surface. One of the salesman there about freaked out checking out the Runner, asked to see under the hood, etc, then looked at me all puzzled and said "You're not putting Subaru parts on this, are you?" So after I told him about the Forester, he said he'd like to see it when I get it running. He was pretty interested in the fact that I'm hotrodding it without using a turbo, which is the "easy" way with Subarus.
Next up, the Toyota dealer for a couple filters, a drain plug washer(I actually haven't changed mine since I bought the Runner with 186k miles on it...I know, shame on me), and finally decided I'd better get a rear wiper since I'll be dealing with more snow in the winters now. Next up will be figuring out why the rear defroster doesn't work, even though the switch lights up. The parts guy asked me if I was having my car serviced there, I told him I wouldn't put that kind of curse on them with the retrofits I've done so far. He laughed and said they got some pretty strange rigs sometimes, but stopped laughing when he saw my Runner. It's always priceless to watch the salesmen walk out when they see a car come in, then go back inside when they see I'm just there for parts!
So the chassis is now at 275k miles, the engine is only at 171k. Just getting broken in!
Here's some pics from the WA assignment to pretty up the thread
In the Wenatchee rappel base they have a little info/memorial that's pretty neat
Our helicopter on the left, the Wenatchee Rappellers ship is just landing, and you can see the smoke from the fire above the ridgeline on the right...they both got set down to clear the airspace over the fire while the DC10 dropped slurry
And one of the nights I went out to a hole in the wall sushi restaurant by myself, and it was slow. The chef must've been bored or something, but whatever the reason for the presentation it was awesome! I almost felt bad about eating the roll.
We went back as a crew a few nights later and my supervisor was pretty upset he didn't get the same presentation when he ordered the same thing
Old Oct 2, 2014 | 05:40 PM
  #332
rattlewagon's Avatar
Thats some fancy eatin!
Old Dec 7, 2014 | 01:38 AM
  #333
Redeth005's Avatar
Old Dec 7, 2014 | 02:43 AM
  #334
dropzone's Avatar
Fossilized
I know staging areas can be hard to find but that LZ is down right scary with the power lines:p
The 2nd bird set down between 2 sets of wires?
Glad the DZ's and LZ's we usually used in the Army were generally clear of hazards. We did have the random grizzly and moose periodically in Alaska
Old Dec 8, 2014 | 03:25 PM
  #335
JonnyBoy's Avatar
Haha, it just looks bad. There was actually lots of room and both ships were on my side of the power lines. Doesn't mean I wasn't nervous, though. I hate the lines that you can hear crackling 150 feet away.
Old Dec 9, 2014 | 09:10 PM
  #336
Zpd426's Avatar
Hey hey, hows it all going? Been away from the site forever just saying whats up!
Old Dec 11, 2014 | 01:36 PM
  #337
I like eggs runny! Muahahahaha! Hehe
Old Dec 21, 2014 | 09:34 PM
  #338
ski87's Avatar
Loved following the journey on instagram. This is great.
Old Dec 23, 2014 | 04:52 AM
  #339
JonnyBoy's Avatar
Ski87 nice man! What's your name over there?
For anyone else that's been following my build and such, I haven't had any big updates lately. I'm gonna do a bit of a write up on all the little things, plus report in on the BFGoodrich Rocks to Riches trip, but I need a computer for that, and I'm still away from home with pretty much just my phone for the internets.
Old Feb 10, 2015 | 03:54 PM
  #340
924runner17's Avatar
Well, got some stuff done getting ready for a potential cross country road trip in August or so. Installed a Cobra 19 cb I'd been kicking around every time I've moved since before I owned my Runner, happily it fit well in the ashtray location like many more people have done before me, so no real tech there. Also mounted the antenna just above the taillight with a door jamb mount, got a 5' antenna so it would clear the body by plenty. Got it all on, and the mount was flexing more than I'd like, then I looked online again and found that the mount was only rated for a 4' antenna. Oops. So I figured I had nothing to lose and fabbed some reinforcements for it. I was reminded again how bad of a welder I am, but I guess it'll get the job done and paint can hide bad welding a little.
I'll get a pic of it reinstalled when the paint dries and stuff.
Then stuff fell off
And stuff came back
Just waiting on the paint to dry on my Marlin, finally did it right with primer and everything
Edit-Done for the day
Here's the reinforced, booger welded, painted antenna bracket now
And my Marlin made it back on tonight, too
Looks better to my phone not being in direct sunlight, I guess.
So that leaves the door handles(I'll probably remove and paint mine, not sure if I'd need a new key if I got new ones), mirrors(I'll buy new, they're fairly jacked up anyway, motors don't always work, vibrate around like crazy), the trim on the tailgate, which is apparently missing a couple letters of Toyota, and if I really wanna get picky, the radio antenna.
Thanks for looking, if anybody has tips to paint the chrome better or weld better, I'm all ears!
What kind of bumper is that? I really like it
