Dropzone's 1994 4runner Build AKA: Project Recycle:
Old Mar 23, 2016 | 07:27 AM
  #141
atlastrekker's Avatar
Can you please snap a picture of the tail gate now with the tire carrier open?
Great work so far.
Old Mar 24, 2016 | 03:49 PM
  #142
dropzone's Avatar
Fossilized
Great work so far.
Good timing, as it just got covered up, the picture is down a few images.
I looked around at how various people had covered up the area of the tailgate where the stock license plate holder and back up lights were.
I would have loved to have picked up a factory tailgate that was built for the swing out and would have had the correct factory fascia piece but in keeping with the keep it cheap theme of this built decided to experiment with stuff i had on hand.
using the stock license frame as a template
dug around and found some diamond plate in the garage
figured i would use it to cover up the hole left when the plate mount was removed, though it was hidden with the spare tire on:
Using my knee to bend the diamond plate got the contour pretty close to the curvature of the tailgate. Not perfect but it will do
Old Mar 24, 2016 | 05:11 PM
  #143
rustED's Avatar
Looks good, I like the "making do" with what you have on hand style of builds, keeps things interesting and helps keep the budget for the spendy stuff!
  #144
sphealy's Avatar
Looks good but I wonder if its going to blind people behind you. Would suck to get rear ended and have them blame you. Wonder what it would look like with some bedliner covering it?
Old Mar 24, 2016 | 05:21 PM
  #145
rustED's Avatar
I think it will be hidden behind that 35" spare
Old Mar 24, 2016 | 05:23 PM
  #146
sphealy's Avatar
Good point.
Old Mar 24, 2016 | 06:46 PM
  #147
Thanks for the info on covering the stuff up. I think you did a great job on it.
Old Mar 25, 2016 | 07:25 PM
  #148
dropzone's Avatar
Fossilized
Thanks! Appreciate it.
Old Mar 25, 2016 | 07:46 PM
  #149
dropzone's Avatar
Fossilized
Added some additional LED's in the cargo area. A single LED in the stock cargo lamp was pretty lame
Much better
Old Mar 25, 2016 | 10:28 PM
  #150
Reluctanse's Avatar
Dat lighting tho... Looks great, not like the crappy stock useless stuff!
Old Mar 26, 2016 | 08:23 AM
  #151
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
So, what exactly did you do? I always thought the lights weren't lousy, it was just my "old and dim of eye" age!!
Old Mar 26, 2016 | 11:23 AM
  #152
dropzone's Avatar
Fossilized
thanks!
I can relate, my old vision balls are getting bad tool.
I added some LED's that I was going to use as rock lights.
I had bought a set similar to these for the Trekker and decided they would get more use in the back. Not sure if i am going to add rock lights to the 4Runner
http://www.ebay.com/itm/381505124332?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Mar 31, 2016 | 07:46 PM
  #153
dropzone's Avatar
Fossilized
Decided to see if the recycling parts from the Trekker so pulled the stock tinfoil bumper. 6 bolts and 3 minutes it was on the ground..
Absolutely no protection whatsoever
Pulled the Trekker Bumper out of storage for a test fit
Not sure if I like it or not.
I need to make a 1" thick spacer for the lower mount it actually bolts up in 4 spots. I would need to fab a mount for each of the stock side mounts.
What do you guys think? Recycle it or get something new?
Old Mar 31, 2016 | 08:05 PM
  #154
It would be better if it were up an in more, but I don't know if that's possible. As it stands now I would probably not run it myself, since it seems pretty obvious it wasn't made for that car.
Old Apr 1, 2016 | 06:36 AM
  #155
habanero's Avatar
What sort of tweaking besides a puck are you thinking of?
Old Apr 1, 2016 | 11:24 AM
  #156
dropzone's Avatar
Fossilized
I hear you, you were the only one to mention raising it up.
So I was thinking of a 1" steel spacer that would push it out far enough that the bottom core support would not need any reworking. Redeth005 made a comment on instagram that made me remember I had a big chunk of plate.
So I dug out my winter truck bed weight, a chunk of 1 1/8" plate, I need a piece 26" long. It will be a PITA to cut(going to talk to friend who runs a metal shop with big toys to see if he could cut it) but I am thinking this could be cut and threaded to act as a solid spacer and a secure enough mount to raise the bumper so it looks better.
Trying to this whole project with using crap around, hoping to keep the entire build under $2500, one reason it is so slow.
If raising the bumper doesn't pan out I can still use the winch mount and come up with a different bumper plan. Ideally I would love to have an ARB bumper fall into my hands
Old Apr 1, 2016 | 11:43 AM
  #157
sphealy's Avatar
Let me know if the arb tree is found on the east coast I'd like a few items from it myself.
Old Apr 1, 2016 | 06:32 PM
  #158
dropzone's Avatar
Fossilized
No kidding, they want more for the bumper than I am into this POS so fsr.
So found my winter truck bed weight I have been using for almost 30 years.
Measured it, long enough, 1/8" thicker than I wanted but oh well
Was hoping to use a friend's plasma table but no response to text msgs so decided to take the long route
2 hours or so and 3 cut off wheels later I had a 27x4.25x 1.125" hunk of steel
So my half baked plan is to use this as a spacer to push the winch plate put so I wouldn't have to trim the lower core support and move the AC condensor and anot electric fan. It will also allow me to move the bumper up a couple of inches.
If it doesn't pan out I am out a few hours and some miscellaneous supplies.
Old Apr 2, 2016 | 11:43 AM
  #159
coopster's Avatar
Cool! Using spare pieces of battleship armour you have! At a least that will help keep the front end hop down.
Reminded me of some bbq place I used to hit down in like Odessa or Seguin or somewhere. Across the street was (closed?) old fab shop, with humongous slabs of various widths plate (1"+, 5'x 10' ish) laying in this lot. Wasn't like anyone was ever going to sneak off with it.
Old Apr 3, 2016 | 08:58 AM
  #160
Reluctanse's Avatar
Did you post part numbers for those LEDs or did I miss it? Definitely want to run those in mine.
