Dropzone's 1994 4runner Build AKA: Project Recycle:
Old Dec 20, 2015 | 06:36 AM
  #101
BUDD's Avatar
good thread to get some pointers!
due im doing up my 1994 4runner (hilux surf, due its a Jap import), started fitting 2007 Toyota Sequoia disc brakes, and 13WL calipers.
good job so far, looking forwards for more.
Old Jan 27, 2016 | 04:16 PM
  #102
dropzone's Avatar
Fossilized
Haven't really had much time to work on this project lately.
Recently switched shifts to day shift, after almost 15 years on nights my body is having a heck of a time adjusting.
A couple of weeks ago I headed down to check out 85Toyman's recent Australian acquisition. A diesel straight axle double cab Hilux brings little jeolousy. It is like a cool truck.
He also found a 2nd Gen spare tire swing out mount that was only on 90 & 91's that he offered at a smoking deal. Hopefully get it mounted in the next couple of weeks
I had taken the running boards off and screwed up thinking I had gotten everything removed from the mounts and accidently ripped off the d/s rear quarter guard.
Ordered a pack of the moulding clips off ebay.
4runner moulding clips
Cleaned up the wheel arch so some 3M tape would stick for the next few years
Between the 3m tape and the replacement moulding clips it fit like a charm
Old Jan 27, 2016 | 04:22 PM
  #103
85toyman's Avatar
Lookin good!!!
Old Jan 27, 2016 | 05:40 PM
  #104
habanero's Avatar
Did you get the inside support part for the tire carrier hinges too or are you gonna do some fabbing? At least, I think there's an inner part too...
That's an excellent find!
Old Jan 27, 2016 | 07:17 PM
  #105
dropzone's Avatar
Fossilized
Originally Posted by 85toyman
Lookin good!!!
Thanks Don
From what I understand the internal support was welded internally to the quarter panel.
I have an idea for an internal support that I should be able to fab up fairly easily to help spread the load.
It will take a little cutting, bending and welding but shouldn't take too long if it goes as planned
Old Jan 27, 2016 | 11:24 PM
  #106
BUDD's Avatar
yes there is some support internally, done that before,
http://www.hiluxsurf.co.uk/showthrea...ighlight=swing
hope it hepls
Old Jan 28, 2016 | 03:10 AM
  #107
Terrys87's Avatar
Getting used to day shift will take a while for that to happen and is a little rough for a while. Those diesel, straight axles, quad cabs are a dime a dozen every where else but here. Really are some great trucks. No rust behind that trim is a good sign that the rest is probably rust free. I had a 91 and behind that trim was gone, not sure what held it on at the time.
Old Jan 28, 2016 | 08:09 PM
  #108
dropzone's Avatar
Fossilized
hope it hepls
That helps a lot, kind of what I expected as far as factory internal bracing.
It looks like you shorted the swing out slightly for your roof ladder.
When I was in Panama and Haiti it was cool to see the 2nd & 3rd Gen DC's everywhere. Didn't see any 1st gen.
85toyman said the early ones were quite expensive, he got a sweet deal on both of his.
I got lucky on rust, in the 5 years my neice drove this 4Runner she put less than 20K on it.
I ordered a Noco Genius battery charger for the 4Runner today that will allow me to keep a trickle charge going.
The 4runner sits for so long that I have to jump it periodically. PITA. .
Old Feb 11, 2016 | 04:44 PM
  #109
dropzone's Avatar
Fossilized
Quick 15 minute project to get the Noco Genius charger installed
Added the connector through the grill (grill will be replaced down the road)
Easy connection
The charger has settings for different batteries, gives you battery status.
Old Feb 12, 2016 | 05:49 PM
  #110
85toyman's Avatar
Lookin Good!!!!
Old Feb 12, 2016 | 06:07 PM
  #111
habanero's Avatar
Neat little gadget with plug-in convenience. I like it.
Old Feb 12, 2016 | 11:51 PM
  #112
BUDD's Avatar
i found this morning in the barn a spare internal reinforcement, swing away spare wheel bracket, if you want to save yourself time fabricating that, let us know
Old Feb 14, 2016 | 04:52 PM
  #113
dropzone's Avatar
Fossilized
Lookin Good!!!!
Thanks Don
Thanks Hab-I am all about convience
Sending you a pm
Old Feb 15, 2016 | 12:48 AM
  #114
BUDD's Avatar
pmd you back!
just sent you a pic of it
Old Feb 16, 2016 | 08:37 PM
  #115
dropzone's Avatar
Fossilized
So today was sort of like Christmas for me when I got home from work. I scored a Ram Tablet Mount on eBay for 20% of what they go for new. This one is used but functions awesome. It is missing the right side retainer but the spring loaded tongs hold the tablet well.
The dual suction mounts are extremely secure even with a 10" Tablet.
Even my blind old Vision balls can see the map.
Nice thing is it is easily moved from vehicle to vehicle
Old Feb 17, 2016 | 05:44 AM
  #116
habanero's Avatar
Vision balls...
Old Feb 17, 2016 | 08:04 PM
  #117
dropzone's Avatar
Fossilized
Vision balls...
Heard that in my army days...it has stuck with me
Old Feb 25, 2016 | 05:08 PM
  #118
dropzone's Avatar
Fossilized
Had the afternoon to work on the 4Runner so started to tackle the rear tire mount
Looks like no one had touched the tailgate before
Some people said to take out the window...decided to chance it
Someone's not so good version of trailer wiring. .it will get fixed. ..not that these things can tow much
The afternoon went quicker than I thought so I don't have pics of the flat stock I used to beef up the inside mount
I will need to raise the tire mounting surface when I put the 35's on this thing but it should do the trick
Still need to cut the old license plate mount to cover the holes in the tailgate and repaint the swing out, it is a bit weathered after 25 years.
Old Feb 25, 2016 | 06:13 PM
  #119
habanero's Avatar
That is just awesome!
Old Feb 25, 2016 | 07:27 PM
  #120
rustED's Avatar
The spare tire mount turned out nice. I didn't realize they were only offered for a couple years on second gens, now it makes sense why I never see any around lol. I like your Ram tablet mount. I was trying to find something similar, but my inclinometer kinda limits my mounting options. I cheaped out and started building a mount, it's going to slide into the track were the ashtray used to go. Should have it finished tomorrow.
