DIRTCO's 1986 4Runner Build-Up Thread
Old May 18, 2009 | 01:02 PM
  #641
Hayes's Avatar
How is the truck running up the hills? What boost are you running?
Old May 19, 2009 | 05:19 AM
  #642
nosfanatic2006's Avatar
Teach me your ways master. . .
Old May 19, 2009 | 09:49 AM
  #643
DIRTCO's Avatar
The truck is running great up the hills (for a 4 cyl auto at 9500' with 35's ). I'm running around 9 pounds of boost and the thing just cruises everywhere. I was down in Denver on Sunday and on the way home it pulled all the hills at between 65 - 70 miles per hour, the last grade right before you enter the tunnel it dropped to 60 miles per hour. I could of pushed it a little harder but I didn't see the need, the sweet spot with the OD off going up a hill is 65-67 and the flats with the OD on is around 72-75 miles per hour. I also noticed that the truck spools up a lot faster down in Denver than up here, I'm sure it would be a blast at lower elevation.
Old May 19, 2009 | 04:34 PM
  #644
DIRTCO's Avatar
Thanks, but I'm no master. It just takes alot of practice, research and a clear vision of how you want the end result to be.
Old May 19, 2009 | 04:48 PM
  #645
DIRTCO's Avatar
The project is starting to wind down a bit, but there has been a few details that needed to be worked out.
After the snow wheeling trip I noticed that the back window was having some issues. The driver side dropped down and would not go up. After taking the whole thing apart I found that the steel channel at the bottom of the window rusted away.
Instead of buying a new window I built a new channel out of 1/8" x 1" strap and 5/16" (I think) round rod. I didn't really get any pictures but the the 1" steel is on each side of the window and the round rod is welded to the bottom, I then welded the original tracks to the bottom of that. I used a couple sections of the stock gasket to keep the glass from touching the steel and glued it all togther with windshield urethane.
Old May 19, 2009 | 06:03 PM
  #646
DIRTCO's Avatar
I also had to trim the front of the body a little because the tires were rubbing on it. It's a lot better than them rubbing on the firewall.
And here is a picture of the blown up trunion bearing that I replaced a while ago. You can see that most of the bearing rollers are shattered.
Old Jun 14, 2009 | 05:38 PM
  #647
Hayes's Avatar
Any updates?!? I hate to think it's just getting daily driven and no more work...
Old Jun 14, 2009 | 05:56 PM
  #648
nhughes's Avatar
NICE!!! Mine isn't quite as clean inside. Can I HAVE your Altimeter/Inclinometer? LOL Check out my pics...
Old Jun 16, 2009 | 06:17 PM
  #649
DIRTCO's Avatar
I've been in the process of moving so I've not had a lot of time to spend in the shop, I've done a few little things but nothing worth posting. I'm also getting used to the truck and working on figuring out what needs to be done, and in what order.
I have been breaking a bunch of trail though! It's all local stuff, and I've alone, but it's been alot fun!
Old Jun 16, 2009 | 06:27 PM
  #650
DIRTCO's Avatar
Here's some pictures, Georgia Pass May 22nd
End of the trail
Playing around
Old Jun 16, 2009 | 06:54 PM
  #651
DIRTCO's Avatar
On the way down I got into some of the deeper snow on the trail and got to use the winch a couple of times.
Old Jun 17, 2009 | 12:34 AM
  #652
space-junk's Avatar
you've built a really nice lookin snowplow...
man, that thing looks great... now, just build me a copy of that bumper for the 2nd gen runner and it will be even more badarse...
Old Jun 17, 2009 | 05:35 PM
  #653
DIRTCO's Avatar
Thanks!
The best pictures are yet to come! ...
Old Jun 17, 2009 | 05:55 PM
  #654
dropzone's Avatar
Fossilized
Originally Posted by DIRTCO
Thanks!
than get to uploading
Old Jun 17, 2009 | 06:21 PM
  #655
DIRTCO's Avatar
I took the truck out the day after that last trip to the same area, but a back trail that I know of. This was an epic trip for the 4Runner because I realized this thing kicks ass in the snow; I made it ALOT further than I thought I could have. The secret was going nice and slow and floating on top of the snow, but knowing when to give it some throttle.
Start of the trail
Getting deeper with water, the mud under the water was deep!
Old Jun 17, 2009 | 06:28 PM
  #656
DIRTCO's Avatar
And deeper
On the way back down
Old Jun 17, 2009 | 06:34 PM
  #657
DIRTCO's Avatar
Another side trail
Old Jun 17, 2009 | 06:40 PM
  #658
toyospearo's Avatar
THAT IS A BEAUTIFUL RIG!!
Great pictures!!
Old Jun 17, 2009 | 06:48 PM
  #659
DIRTCO's Avatar
A few weeks later (June 5th), I headed up to bash some more snow. With the temps getting warmer the snow got alot softer; you really couldn't float on top of it.
Old Jun 17, 2009 | 06:54 PM
  #660
DIRTCO's Avatar
And deeper!
