de6w6it's 1988 4Runner Build-Up Thread "Flat Black Lemon"
Old Jun 13, 2020 | 05:16 PM
  #121
de6w6it's Avatar
i also pulled the third, welded up the holes in the housing from the inside, ground it down, put on new rtv, and buttoned it back up.
Old Jun 13, 2020 | 05:20 PM
  #122
de6w6it's Avatar
i made some plates to weld the shackle hangars to, and then weld up to the frame. since it is thin there, and needs to be welded overhead, i figured this gave me a better shot at getting the mount solid to the plate, then have more linear welding overhead.
Old Jun 14, 2020 | 11:15 AM
  #123
de6w6it's Avatar
i was hoping to get more done today, but when i was drilling through the ends of the cut leaves i am using to make my rear pack, i broke the only bit i had that was able to drill through the spring steel (apparently). i tried many others, to no avail. 3 holes, 3 to go. i am drilling to add those nylon slider/insulators.
i did get the spring and shackle hangars on the passenger side tacked in. i didn't cut off and grind smooth anything on driver side so i could get good measurements for initial placement on the passenger side. since it will be a different spring pack, it wasn't perfectly level before, and there is now 1/8" plate between the new mounts and the frame, i need to set it down on its weight on the tires to check shackle angle, pinion angle, and level.
Old Jul 19, 2020 | 12:43 PM
  #124
de6w6it's Avatar
i got the driver side frame rail all cleaned up, and it looked much better than the other side. i didn't plate the outside much, it looked pretty solid, but the inside got the full treatment. the only piece left to weld on is the strap under the bottom to make it the same as the passenger side. then tack on the hangars and set it down to check angles.
Old Aug 2, 2020 | 09:11 AM
  #125
bone collector's Avatar
You are doing amazing work! Keep it up! I'm in the middle of a frame swap due to a rusty frame so I feel your pain. I really like the 35s on the FJ rims. Looking good! Hopefully you can get it on the road soon
Old Aug 2, 2020 | 11:55 AM
  #126
5 Fists's Avatar
Nice shackle mounts! Frame is looking excellent!
Old Sep 1, 2020 | 11:37 AM
  #127
de6w6it's Avatar
thanks man, much appreciated
i've got a 4 day garage weekend this weekend, so hopefully i'll make some progress
Old Sep 1, 2020 | 11:38 AM
  #128
de6w6it's Avatar
thanks, much appreciated
its getting there
Old Sep 1, 2020 | 11:44 AM
  #129
de6w6it's Avatar
i got my axles stripped down and cleaned, and got the new bearing pockets, rotors, disc swap rotor spacers, and longer studs mounted onto them
my new gas tank, front fj rotors, front spring bushings, front axle seals/felts, and front u bolts are on the way
rear spring bushings, rear loaded calipers, and new black lug nuts are here already
ready to get to it this weekend
Old Sep 8, 2020 | 07:10 AM
  #130
de6w6it's Avatar
well, i ordered 8 large and 4 small spring bushings for the rear, and it should have been the other way around. That count from Marlin's site is for after market springs. I have old school Downey springs which require only large bushings in front, and small for both ends of the shackle. This prevented me from setting it down on its own weight to do shock placement, final hangar welding, etc. So that was a bummer for a nice long weekend. I did make some progress though.
I got my axles in and disc brake brackets mounted:
Old Sep 8, 2020 | 07:12 AM
  #131
de6w6it's Avatar
Driver side hangars:
Old Sep 8, 2020 | 07:16 AM
  #132
de6w6it's Avatar
Chassis saver paint, front spring bushings, rear bushings, and new oem sending unit on the way. The old one was non-functioning:
"Old" fuel pump and bracket assembly are installed into my spanky new shiny spectra premium replacement gas tank.
Old Sep 8, 2020 | 07:41 AM
  #133
Gevo's Avatar
Making steady progress! Looking good.
Old Sep 20, 2020 | 05:12 PM
  #134
de6w6it's Avatar
its on its own weight!
Old Sep 20, 2020 | 05:16 PM
  #135
de6w6it's Avatar
i got the pinion set perfect at 2 degrees down at ride height
the shackle angle is a good compromise
wheelbase on either side is very very close
frame is level front to back within half a degree or so
ride height seems good
less arch in this spring pack, hopefully a better ride
everything is only tacked and nothing is tight, as it all has to come back apart for final welding
Old Sep 20, 2020 | 05:18 PM
  #136
de6w6it's Avatar
got the lower shock munts tacked
the upper shock mount is fabricated, it just needs to be installed
Old Sep 21, 2020 | 02:45 PM
  #137
I know that feeling well. Keep up the good work!
Old Oct 3, 2020 | 01:11 PM
  #138
de6w6it's Avatar
i got the spring and shackle hangers final welded
i also reinforced some rotted body mounts i trimmed
Old Oct 3, 2020 | 01:14 PM
  #139
de6w6it's Avatar
i also final welded the lower shock mounts
Old Oct 3, 2020 | 01:17 PM
  #140
de6w6it's Avatar
i also bent two plates to reinforce the bumpstop mounts
