dakotawho's 1987 Pickup Build-Up Thread
Old Dec 10, 2012 | 08:20 AM
dakotawho's Avatar
That woulda helped on the first dashpad, i destroyed it haha, you live and ya learn it was rough anyway, this will make it a lot easier the second time!
Anyways yesterday i removed the seat and carpet, vacumed it out, lot of misc stuff under the carpet, found a little rust in the firewall prob gonna do some sort of repair there and a few small not so bad places, just gonna grind those out and put some sort of rust inhibitor on them. For the time being i just hit the carpet with the air compressor, cleaned up pretty good for that little effort, cant wait to see what it looks like when i put some time into it. Seen where someone took theres to the car wash, might try that.
Old Dec 13, 2012 | 11:23 AM
Cyberhorn The Dragon's Avatar
subscribing
from the looks of things your doing great with things
as for rust holes you can do two things after derusting the area
weld or fiberglass
dont put bondo directly on bare steel it will rust out as bondo actually absorbs moisture if your patching a hole with the fiberglass type its okay as the resins are waterproof
etching primer can be used on cleaned previously rusted metal an will make a much better seal preventing further rust then painted over with other primers prior to painting
actually know a guy that recovered an abandoned boat from a river fixed the huge hole in the bottom using bondofiberglass repair an still uses it for fishing
Old Dec 13, 2012 | 05:56 PM
dakotawho's Avatar
Well got the dashpad off the other truck, still broke the stupid brittle vent! Oh well Anyways today i got the dashpad all off,(deep well sockets help) i put in a oh crap handle in on the drivers side. I also swapped the grab handles you use to close the doors, apparently there interchangeable from door to door, so two perfect door grabs! Whoop Whoop
Another project i did today was work on my grill, it's definitely 25 years old, but i tried reviving some luster from her
All i did, was goes over it with some steel wool, cleaning up areas where some algae like thing had gunked up and just going over the whole gril. Then i went over it all with a wet rag and let dry. Then i used some turtle wax chrome polish. I put it on a cloth, rubbed it all over the grill and let sit for a couple minutes. After a few minutes i went over it with a wet rag. Then finally i went over it with a dry rag, it definitely brought stuff off because i had to change my spot on the rag occasionally because of how much dirt was on it.
Before
Finished product
Probably can't tell too much from the pics but its definitely different in person. It shines a lot more! haha my sister is modeling the grill.
Old Dec 13, 2012 | 07:01 PM
definitely lookin better!
Old Dec 13, 2012 | 07:18 PM
  #25
dakotawho's Avatar
Its coming along, tomorrow i'm going to go bleed the slave cylinder and brake lines hopefully(was the plan today but didn't have enough brake fluid) and snag the corner lights up front so i can clean the chrome on them.
Cant wait to hear it crank again!
Old Dec 25, 2012 | 09:02 AM
  #26
Terrys87's Avatar
Looks like you are still getting things done. Wont be long and you will have it started.
Old Dec 25, 2012 | 10:20 AM
  #27
dakotawho's Avatar
Well merry christmas everyone, it truly was a good christmas for my 87 she got two new front fenders, a cd organizer thing and a gallon of por 15! And possibly seat covers?(guessing)
Old Dec 25, 2012 | 10:22 AM
  #28
dakotawho's Avatar
Just an update, the slave cylinder has been bled. Consulting with terry about a few things. Hope to have it wrapped up real soon, as long as this snow doesnt stop me!
Old Dec 26, 2012 | 01:24 PM
  #29
Terrys87's Avatar
Just checking in and seeing how things are going? You running the wheels off of it yet??lol.. Hope the weather isnt holding you up.
Old Dec 26, 2012 | 02:30 PM
  #30
dakotawho's Avatar
Well i have a few tedious thimgs left. (bleed brakes, drill out a few bolts, bleed power steering, finish the dash but im waiting to drive before i do that.)
But with probably 4 inches of snow on the ground/truck im kind of at a stand still. But yes i did want to.run the wheels off of it....especially in this snow:/
Old Jan 2, 2013 | 05:40 AM
  #31
dakotawho's Avatar
Well yesterday was interesting...haha
Got all my broke/stuck bolts out! Thank you pb blaster! and my step dad, he's good at things like that
Hooked everything up in the engine compartment, all done up there except bleeding power steering bleeding.
Finally got around to sticking the battery in her....ssssssssss POP....rut ro.
My 80 amp fuse blew....looked at the harness to the fuse, looked homemade, ended up swapping the harness out of the old cab, went and got another fuse. No pop this time!
Go open the door and hear the wonderful wwwwrrrrrrreeeeeee noise. Go to start it and all i hear is click. Swap all my fuses and relays over, swap starter relay. Still clicks, investigate a little bit and evidentally i knocked the plug off the starter when swapping out that harness. Got in it.....crank crank crank! woo hoo! Which is a start, i know its gonna be hard to start, always has been and its been sitting 2 and a half months over the span of this project. Gonna put some gas in the carb here soon and try and get it started.
Keep hearing a clunkish noise, Think maybe its the exhaust backfiring? Gotta have someone start it, while i attempt to find the noise.
Old Jan 2, 2013 | 11:23 AM
  #32
cranking is a good sign!
Old Jan 2, 2013 | 11:41 AM
  #33
dakotawho's Avatar
definitely I'm going to try and put some gas in the carburetor today and get it running
Old Jan 2, 2013 | 12:09 PM
  #34
Terrys87's Avatar
Will be checking in to see what your results are. Carbs do like to evaporate the fuel after such a long time sitting. Once you get it running, my old 22r, I would give 3 pumps of the gas pedal and it would fire right off. One fast starting little truck.
Old Jan 2, 2013 | 02:20 PM
  #35
dakotawho's Avatar
Well didnt get to mess with that too much....stupid battery died when trying to start. Got the hood put on, swapped the wiper arms and few other random things
Not an expert on carbs....far from it
When putting gas in the carb, where do i put it?
I have everything stock, do i just take that pan off and put it down in there, if so which side there, the one on the left....if you were looking towards the back of the truck appears to be maybe cold start? Only works when pumping pedal near floor. Im assuming the other one is just for normal operation
Old Jan 2, 2013 | 03:57 PM
  #36
Terrys87's Avatar
What I do is put a little on each side or where the butterfly flap is. That will actually flood it. The way you unflood a carburator is to hold the accelerator pedal to floor and crank it.
You may have some fuel lines empty as well so it may start and then die, but the fuel pump will start pulling fuel from the tank. May need to do this a few times to get fuel flowing.
Old Jan 2, 2013 | 04:06 PM
  #37
dakotawho's Avatar
Okay im in the right place, couldnt find my haynes book thid evening.to.save my life.
And you said only a few teaspoons right?
Old Jan 2, 2013 | 05:06 PM
  #38
Terrys87's Avatar
I always go with 3 to 5 or so. If everything is timed right and just needing fuel, you will know right off as it will try and start.
Old Jan 2, 2013 | 05:21 PM
  #39
dakotawho's Avatar
Should i put the metal.cover back on before i try to start it
Old Jan 2, 2013 | 07:38 PM
  #40
absolutely
it prevents an airhorn fire which can damage the carb so definately put the air cleaner back on when priming a carb or doing this kind of starting
