cr@ves4wheelin's 1991 Hilux Build-Up Thread
Old Feb 23, 2012 | 04:38 PM
  #161
ToyoTech559's Avatar
could be your suspension parts loose or worn out. maybe ball joints?
Old Feb 23, 2012 | 05:42 PM
  #162
cr@ves4wheelin's Avatar
It's weird, it'll make that noise with tire rotation. Not engine speed, doesn't matter if I hit the brakes, I even greased the drive shafts.
Old Feb 23, 2012 | 09:21 PM
  #163
lift up the front end and spin it by hand and see how it sounds. do a side to side and up to down shake on it and look for loose parts. maybe even put it up on all 4s might be dangerous without using an actual lift and put it in 4wd
Old Feb 23, 2012 | 09:54 PM
  #164
MaK92-4RnR's Avatar
Uhh... your false water pump is failing. thats why you're having fan problems. You need to replace this as soon as possible before the shaft comes out completely and jumps into your radiator and grenades everything.
When you pulled your fan clutch, theres 4 studs it attaches to. that is the False Water Pump. you need to pull the radiator, hoses, belts, fan, fan shroud, fan clutch, timing belt cover, and you'll see the False water pump. all it is is a Cover for the water pump, with a few bearings and a shaft. its more of less used for a guide for the belts. ) but I can almost guarantee this is the culprit.
Old Feb 23, 2012 | 10:12 PM
  #165
If you're talking ball joints and tie rods, then I probably just need to grease them again. I replaced them not too long ago. I'll do that tomorrow and see how it goes.
I've been researching about the fan bracket for the past couple days. The only reason I'm in denial is because the pulleys don't wobble with the fan. Looks like I'm wrong about it being the fan clutch, I'll replace it when I get a chance and see how it goes. Doesn't look difficult to do at all.
Old Feb 24, 2012 | 06:43 AM
  #166
MaK92-4RnR's Avatar
Better safe than sorry, The false water pump is like 60 bucks. better than having the fan grenade and launch large ABS plastic into your hood, radiator, and hoses. I have a NAPA one, and it seems to be holding up. the first one I bought had a defect and the entire assembly pulled out and knocked all my belts off.
I think AISIN ones are 130 ish from the dealer.
Old Feb 24, 2012 | 10:44 AM
  #167
Okay, well I called up NAPA today and had them order me up one. I got the NAPA one which was around $114. I asked if they had an AISIN part but it was about $2xx. Money that I don't have right now. What sucks is I got laid-off a couple days ago, haven't been compensated as of yet. I haven't even got my student loan yet which makes things even worse. So if this doesn't work I'm just gonna run it, because I don't have much of a choice.
I'll see what happens. The guy that I know pretty well from NAPA says he's sold a few and haven't heard of any trouble with the part.
For now I greased my ball joints, unfortunately my cheap ways got me unserviceable tie rods lol. Hopefully the metal to metal sound goes away even if it's for a little while. When I go to NAPA tomorrow to pick up the part I will listen for it. Ever since I started college I've been a little neglectful then I used to be when I was in high school.
Old Feb 24, 2012 | 03:15 PM
  #168
the AISIN ones from dealers are like 600+ i know because i needed one as well and was gonna bring this up about your fan issue since i just remember at work today.
i got one only for much cheaper. i dont know where you can get one for $60 tho.
Old Feb 27, 2012 | 01:21 PM
  #169
Got a new fan bracket, but it didn't fix the problem. I don't really know what it can be. Either I got a faulty part or something else is wrong. Either way, I've run out of funds for the time being, so I'll just have to run it as is for now.
Write-up on how to replace: https://www.yotatech.com/forums/f116...ite-up-250004/
Old Feb 27, 2012 | 02:02 PM
  #170
that only leaves on thing, the fan?
Old Feb 27, 2012 | 03:00 PM
  #171
Yep, I just went over to take a good look at the fan, and there's some weird bends to it as I was rotating it. I'd be really mad at myself right now, but it was kinda cool getting behind the timing cover. Who'd of thought that the fan would be bent, the last thing on my mind.
I'm just tired of dealing with it already, it will be the third time once I dive into again. Time to look at cooling fan prices.
Old Feb 27, 2012 | 03:14 PM
  #172
MaK92-4RnR's Avatar
Look into a 94-95 fan conversion. 3vz V6s came with bladed fans and not the circular funnel ours has on it.
Old Feb 28, 2012 | 08:09 AM
  #173
racerflea's Avatar
The best way to check wheel bearings is to lift the truck and try to move the tire pulling and pushing from top if u get a "clunk" sound then their bad
Old Feb 28, 2012 | 08:14 AM
  #174
racerflea's Avatar
Or maybe u bolt chatter which then just oush on drive shaft any movement is bad .. but nice truck man makes me almost wanna post not sas mine!! I just like the looks of a sas personaly
Old Feb 28, 2012 | 08:52 AM
  #175
Thanks man, the noise was actually because there was little to no grease in the ball joints. Fortunately, after I greased them up and installed the new fan bracket to go take it for a drive, the noise was gone.
Old Feb 28, 2012 | 08:53 AM
  #176
Okay, I'll look it up
Old Feb 28, 2012 | 09:07 AM
  #177
Cool, I found a '94-'95 Fan here for $107.27.
http://www.trademotion.com/parts/199...iagram=E809045
I'll see if I can find any that's cheaper than that. As soon as, probably, next week rolls by, I'll be having one shipped here overnight.
Old Feb 28, 2012 | 09:13 AM
  #178
racerflea's Avatar
I bekive my stock 22re fan is bladed like that (89 pick up base model)
Old Feb 28, 2012 | 09:21 AM
  #179
I wonder if a 22re fan will bolt to the 3vze fan location. Just in case I order the wrong one. The diagram from the link I posted where the fan is sold, looks like it's not a 3vze. It says 6 cylinder though.
Old Feb 29, 2012 | 05:19 AM
  #180
grks96@yahoo.com's Avatar
That's a nice truck it looks like mine exept mine is extended cab!
