ChildrenOfBodom's 1987 4Runner Build Up Thread
Old Mar 13, 2013 | 12:40 PM
  #41
kornhuskerwizard's Avatar
I bet that put a smile on your face when that truck pulled up with that!!
Old Mar 13, 2013 | 01:56 PM
  #42
93Xtra-Cab's Avatar
What, you haven't put it in yet? What's taking you so long? I'm starting to get antsy
Old Mar 13, 2013 | 11:25 PM
  #43
ChefYota4x4's Avatar
Hey! I saw red and thought of ya right off! Lol. ....
http://losangeles.craigslist.org/lac...679400711.html
Old Mar 14, 2013 | 09:22 PM
  #44
ChildrenOfBodom's Avatar
Haha its bittersweet, the headache of installing it begins
I have trouble getting it in... don't make fun of me!
Haha man, that red is something else
My friend John has an 85 pickup with a 22r-te. He's pretty knowledgeable about them. Nice to have the shop manual in human form.
I used one of John's extra trucks to take the motor down to his place.
Took the turbo off and over to the bench. I used a sandstone block to get rid of any high spots on the turbo manifold. These 22R-TE manifolds warp like crazy, this one is actually pretty darn flat.
Rear main seal is not the best brand, so I've got another one on order. Last thing I want to do is have to change a rear main after 6 months because of a dried up crappy HTC seal.
Can you guess which one of these I had to use to remove the crank pulley?
Another HTC seal. These black ones are notoriously bad
Oil pump had silicone on it too, should only be an O-ring. Some of the silicone made it into the little oil chambers. Some also made it between the gears.
Also performed a compression test. No leakage from any cylinders
Took off the valve cover. It's an aftermarket head. The cam is nice, but I have no experience with cams on these motors. It looks like the lift is a bit extreme, but I guess I'm speaking too soon
Right now I'm waiting on a new rear main seal, front crank seal, and oil pump O-ring. I'm likely going to be buying a new water pump, too.
Old Mar 14, 2013 | 10:31 PM
  #45
Lookin great man!
Ur right on the seals... I went OEM for that very reason. Wheel bearings, Wheel seals, caliper rebuild kits for the V6 upgrade, CV reboot and repack kit, trans-input shaft bearing retainer seal(good time to do that one on ......manuals, haha), front and rear mains, t-case, pinions, .... All OEM, and IMHO worth every penny of the extra cost over National or any other.
Keep killin it bud!
Old Mar 15, 2013 | 02:16 AM
  #46
Co_94_PU's Avatar
Well no wonder you can't get it in it's dry, not seeing any assembly lube dooesn't bode well hoping I just need glasses.
Old Mar 15, 2013 | 03:11 AM
  #47
Head studs as well...ARP??
Old Mar 15, 2013 | 09:03 AM
  #48
CO is right to mention that...... And I have some CRANE Cam lube, highly recommend it for cam break in procedure
Old Mar 15, 2013 | 04:05 PM
  #49
Lookin great man!
Keep killin it bud!
Yes sir, that's why your build is so popular! Great work using great products! OEM FTW
Thanks dude!
She's lubed up alright. Lubed up real good. Definitely gonna need some work in other areas before being inserted, though
Yep you got it
Haha nice, why do you prefer it?
The seals haven't come in yet, so today I had to find other things to do.
Took off the oil cooler. Sucker needs a 30mm socket. The seal against the block needs replacing.
This motor sat for a while after rebuild. The valve springs had some rust going. Had to use the air compressor to get that out.
I performed my first ever valve adjustment. Adjusted the intake valve clearance to .008", exhaust valves set to .011".
Monday is when the new seals should be in.
Old Mar 17, 2013 | 05:22 PM
  #50
Discombobulated's Avatar
Looks wonderful, the digital cluster is so frickin cool. Can't wait to see it running
Old Mar 17, 2013 | 06:18 PM
  #51
I use this lubriplate engine assembly lube on my builds. Withe tube with blue cap. Great stuff and decently priced.
Old Mar 18, 2013 | 04:09 PM
  #52
Thanks dude. I'll take a video of the first start and post it
cool, good info. Thanks
The seals came in today. I have replacement water lines for around the throttle body coming in soon, too.
Oil cooler seal
A closer pic of the ARP head studs
Old Mar 18, 2013 | 05:06 PM
  #53
Hey,
Well, I chose cam lube to break in the new cam coz it was recommended by my machinist and he had it laying around and gifted it. Buddy flecker have it to me as well.
Curious, u said 8 an 11... stock turbo cam? Couldn't remember, sorry. My 261 crawler cam is 7 and 9 thousandths....
That thing has me excited! Nice, nice, nice!
Old Mar 21, 2013 | 08:44 PM
  #54
Hey,
It's either a 270 or a 280. Seller told me both numbers so I am not sure exactly. The numbers were provided by my friend who showed me how to adjust them. Can always adjust them later at least.
The motor:
There was an oil pan gasket. Ripped that off, oil pan is now installed and sealed with permatex silicone. The seller forgot to send the oil pickup tube and oil pan bolts, so I had to source those. New gasket for the pickup tube and another for the oil drain plug.
Water lines, PCV grommet, distributor o-ring. Also got a 22re turbo thermostat.
It's back at home and will be installed soon. Waiting for some things to arrive in the mail.
Old Mar 21, 2013 | 10:51 PM
  #55
Philbert's Avatar
Great work!
Looking forward to following this build!
Old Mar 23, 2013 | 02:35 PM
  #56
Originally Posted by Philbert
Great work!
Thanks bud, I look forward to your comments too.
About the motor and it's current stage - it's in my garage, ready to be dropped in. The only setback is the oil lines from the CT-26. Those lines are the last thing I want to install inside of an engine bay. Once I can get those on the motor, I'll drop it in.
Also stopped by autozone. Bought two radiator hoses, Duralast Gold cap and rotor kit, STP drop in air filter, PCV valve, and thermostat gasket. My friend from NY also sent me an OEM battery tie down.
In the meantime, I'm cleaning up other things. The old motor was nastier than I have ever seen a motor get. Anything cooling related is drastically nasty. Too bad I need to use some of it! Can't believe this thing ran!
And last, can anyone identify this item, please? A vacuum solenoid for something. I broke the vacuum leads off and want to replace it. Thanks!
Old Mar 23, 2013 | 05:32 PM
  #57
Co_94_PU's Avatar
Idle up VSV. for P/s and A/c
It's my understanding the VSV are pretty much interchangable. There are maybe two types one applies vacuum the other applies atmospheric pressure when active.
Here is photo picture, can't make out the part number
https://www.yotatech.com/forums/f123.../#post50849156
Old Mar 26, 2013 | 05:41 PM
  #58
Thanks for the help. I was able to find a replacement for it today.
Not much progress to post. I cleaned up the thermostat housing and installed it, along with 82 degree thermostat and new seal. Also installed the 3 main water lines and some more vacuum stuff (including VSV). Also got my cap and rotor ready.
Ordered these items:
- Bic Performance CT26 outlet flange 3/8"
- CT26 inlet and outlet MLS gaskets
- Innovate MTX-L Wideband Kit
- 2ft. black silicone vacuum tube 10mm (PCV, breather)
- DENSO Oxygen sensor, upstream
- LC Engineering weld in O2 sensor flange (2-bolt)
- NGK Spark plug wires 8mm
- spark plug wire boots (black)
- 10 brass nuts 10x1.25mm for turbo manifold
- Oil pan drain plug
- All new belts
- Front sway bar bushings
- Monroe steering damper
- Coolant temp sensor
Old Mar 30, 2013 | 05:45 PM
  #59
[YOUTUBE]kbF-EajO_O8[/YOUTUBE]
Did some more cleaning of the engine bay.
Ordered 2 feet of 10mm silicone vacuum line... they sent me 10! Replaced vacuum hoses for brake booster with silicone.
PCV hose replaced with silicone
Coolant temp sensor
As she sits now.
I have some new factory parts that came with the truck when I bought it. Gotta install the coolant hose next to the intake side of the turbo. Going to order up some ebay silicone couplers and intake tubing and mock something up.
Oil lines for the CT-26 arrived. Still trying to get the old ones from the old turbo off. I'm going to do my best to see if I can use the CT20 oil line, but I need a closer look with the line off. Ordered a set of gaskets for the turbo lines.
Still waiting for the wideband and CT26 outlet flange.
Old Mar 30, 2013 | 07:23 PM
  #60
Dude,.....looks excellent! OEM coolant temp sending unit? How much? Looks aftermarket..... but cany tell as I know they update em.
Motor is nice man.
