ChefYota4x4's 1987 4Runner Build-Up Thread
#261
Donno...well I look at it like this. It might be easier to see if it was running. Not going to hurt anything running on 3 for a bit while you take a gander at the blinky light or lack there of.
#263
Ya, have some one crank it over to test it while idling. I'd start at 20DC, might have to go lower than that to get a good read. You really need an analog meter for this not a digital the digital will not read fast enough.
#264
I do things different sometimes. I just might be weird...
#265
If the NOID seems to be alright try that wiggle it around a bit. I'm not saying one is better than the other. It's just that I have a meter and not a Noid tester so that's what I'd use first.
#266
Lumpy, Rob, Joe, 92 ............
The noid LIT; Low light and flashing at idle, then sped up to almost staying lit(couldn't tell it was flashing so fast I guess, when going to 2000 to 2500 rpm.
HOLY CRAP, DOES THIS MEAN THEY GAVE ME A FAULTY INJECTOR BACK??????
#267
Either that, which I doubt, or the terminals are not pushing onto the injector good. I would push the terminals out of the front of the plastic connector & put the 2 terminals on the injector individually so you can make sure they are connected good. Then slide the plastic connector back over the terminals. If the noid light flashes then the wiring is good.
#268
Forgot to mention.....
Ohm tested the Injector, with the Multimeter set on 20K(is that right?), and it read-while jumping around- anywhere from 1.5-3.7ohms....The book says 3.0, but could that be negligible? Which, if it's proven that my injector is working properly, .....WHAT, EXACTLY?
#269
^^2X on this one...
Sounds like out getting power to the injector and you had the injector rebuilt. So it's very possible the plug and the injector are not playing nice.
#270
Ok, Rob, so the wire is hot, CHECK.
But, why, then, would #2 pipe be cold, other than no fuel to that injector or could this be more valves? I read someone say that good compression on that cyl. doesn't mean that the valves are set right. Supposedly, they triple checked that, and set them to the RV Cam, told me I was good to go. Now, when I initially had the firing order wrong, could that have damaged the camshaft or valves?
#273
If you have spark to that plug and it's still missing then it's a fuel issue. You said that you checked for spark and also changed plugs right? Maybe swap wires between 2 & 3 and see if you have the same issue.
#274
I'm not sure, I'd have to take a look to see what mine look like. I's been a bit since I have paid that much attention to the injectors.
You can do that just be very careful that the wires don't come off and short out somewhere. If you are able to modify butt connectors they might fit tightly on the injector and the wires on the other end go into the plug. Might be worth a try.
#275
#276
K, crimping now. But, if I get good power to it, and it's still running on 3....I'm really lost, man!
I also didn't think that, maybe, in the process of man-handling the wire connector, I regained connection?
This is really frustrating, being so close and it's still sitting here in the driveway!
#278
#280
