ChefYota4x4's 1987 4Runner Build-Up Thread
#222
Yeah, sorry it's post #195, the 3rd & 4th pics are of the wires for the injectors. It fires 2 injectors at the same time & they share wires from the ECU & split at the crimp on splices. My bet is the #2 wire has pulled out of the splice, or the injector connector is loose & the terminals are pushing out the back.
#223
very plausible theory (stealing that phrase from Mythbusters).
when we remodeled our bathroom in our old house...after it was done, noted a water leak not even near where we had worked....but still the same pipes...we had cut pipes and soldered in new ones about 10 feet away, but just the vibration and or movement we did caused a failure.
i know how much man-handling i did with my wires, so it's completely understandable that could happen to your's too CHEF.
#224
RIGHT ON! That's what I'm talking about, guys! I really appreciate you spending the time to find some other resources, guys, ....I looked for 'LONG TIME', ..LOL, but 'no luck'. Sure, I found things that might have been the issue, but haven't been able to get out there,...until now, I'm heading out.
MAN, this kinda thing just gets to me, ...keeps my mind on it for HOURS, figuring this or that out in my head........problem is, I DON'T KNOW ENOUGH about this stuff, so it's really fruitless until someone says, "hey, what about this, I've seen this happen"....ya know?
Ok, so, the prongs in the injector, itself, are fine....but the female slots where it inserts(The connector) can push out the back? DANG, I never thought of that. Mine is all wrapped up on the back, so first, I'll look inside(IF I CAN GET THE DANG THING OFF! LOL) and press on it with a small screwdriver to see if it pushes back(away from the injector end)......RIGHT?
Of course,whether or not that's the case, I need to NOID it, if possible, then if still no results......start tracking the wiring back?
Rob, if it's the 4 into 2 connection for that set of injectors......I need to pull back all the tape-wrap, and about where is that connection? Or, should I just tear it all the way back to the firewall? THEN.........WRAP IT AGAIN WITH WHAT? Oi vey, ......what a pain, lol.
You know, .....I REALLY doubt it's a problem with the ECU, and YESSSSSSSSS, I did man-handle the wiring loom, etc. Noticed those connectors, where they join furthest forward, are REALLY brittle, too. Figures, 270K Miles of Jarring around drama.....HEAT, ....elements, ...no wonder.
OK, GUYS, I'm on it, and again, THANK YOU!
M.W.M., C.E.C.
M.W.M., C.E.C.
#225
You don't need to go as far as the firewall with unwrapping the harness. Just start at the injectors and work your way towards the under hood fuse box. You will find the splices.
#226
http://forum.ih8mud.com/79-95-toyota...lem-i-had.html
Here is another good link Chef. Good luck man, I really hope this helps you out. Sorry again that I was away from the forum over the weekend, I have a feeling I could have saved you some headache.
#227
ROB......YOU ROCK! lol. Jerry too, of course! Ok, so, what do I rewrap it with? I've heard ppl say that once you get it dry, cleaned up, sure you have no more ROT, ....wrap it up, TIGHT(MEANING NO SPACE for water to get in from the sides through a seam of wrap) and then use RTV at the top of the wrap, to keep moisture out?
#228
NAHHHHHHH, don't be sorry, how could you have known? More so, THANKS, for showing up to my drama! lolol.
How did you cut back the harness? X-acto? Nail Scissors?
#229
#231
HAHAHAHA, how funny....that's one that I found yesterday, then bookmarked it! Just checked my bookmarks again to make sure, lolol!
#232
#233
No, not been out there yet to figure it out, Rob....been planning dinner, getting out of doing lunch, and well, pretty much on here, looking for answers(You know, ...I just don't know enough about this stuff to just go tearing things apart...so I'm a bit nervous, and I wanted to be sure what the 'likely suspects' were, eh?)
#234
Rob, 92, moze, lumpy, bleeder, & everyone else who's shooting me nuggets......
THANKS, MAN!
Ok, I think I have a good idea as to what to look for. I'll check that connector, first, then if it's 'no go', I'll start pulling the upper intake, ...yadda yadda yadda!
Thanks, guys, I'll have my laptop out there, so I'll check in for more input!
Mark
, Ok, I think I have a good idea as to what to look for. I'll check that connector, first, then if it's 'no go', I'll start pulling the upper intake, ...yadda yadda yadda!
Mark
#235
I would do the noid light first & be sure it was a wiring problem before you take the harness apart. Like I said that is also how I figured out that my injector terminals where pushing out the back.
#236
THANKS, MAN!
Mark
Mark
#237
Right
But, how can I be sure one of these noids will work? Is there a toyota-denso one? Somewhere? I've even had trouble finding them on line. Seen some universal ones, but just wondering if these plug in types will work since they're for GM and Fords
#238
one more thng, I pushed the terminals out the front of the the connector (plastic piece) & pluged the wires in by hand then slipped the plastic connector back over the terminals to be sure they where not pushing out the back.
#239
Making you hungry? OHHHHHH, lol, sorry! hahaha.
Well, for dinner they're having Grilled Kansas, Creole Rubbed Lamb Chops, Grilled Yukon Potatoes smothered in Garlic and chives, Grilled Asparagus wrapped in uncured thin-Bacon and Andoullie Soup with Swiss Chard, Baby Fingerling taters and Cajun-Tomato Base.
Dessert; Creme Brulle with fresh Strawberries from my Garden(I have 82 fruit Trees, 50+ Herbs, 30+ Veggies, 4 Tubors, 6 Legumes, 15 Tomatoes(fruit, yes, but they DESERVE THEIR OWN CATEGORY, HAHAHA), and many edible flowers, including my favorite, "Strawberry Guava Flowers"....which also gives me KICK ARSE FRUIT!
Ok, well, I'm off to try and pin this down.
Thanks, again,
Mark
Thanks, again,
Mark
