ccraviotto's 1987 4Runner Long Travel Build-Up Thread
Old Jun 2, 2011 | 04:44 AM
  #121
xxxtreme22r's Avatar
are those just for the center diff/BLT setup right? Either way they look sick.
Old Jun 3, 2011 | 08:34 AM
  #122
BlazeN8's Avatar
The axles I am showing are the ones I designed to work with the the Blazeland Long Arm kit and a 7.5 Center Mount Differential with a 4" Drop Bracket kit. I also built a prototype bracket kit to bolt the differential into place. Its still in the testing phase, but so far things are looking good.
Old Jun 3, 2011 | 10:40 AM
  #123
Numbchux's Avatar
7.5" supra diff? or is it possible to modify the truck IFS diff for center mount?
would those axles work with an 8" supra diff?
Old Jun 3, 2011 | 05:35 PM
  #124
corax's Avatar
How did I miss this thread?!? Time to add another thing to the to do/dream list . . . great work guys
Originally Posted by motorhead
Something like this might work well on a 5m/7m swap with a cressida pan without a bracket lift, as the pan sits in front of the ifs diff ...
Yep, plenty of room for the diff with my 7MGE. Here's a pic from my swap thread
Old Jun 6, 2011 | 03:30 AM
  #125
ccraviotto's Avatar
took my good old 85 out for a work party Name:  brownscamp005.jpg
File Type: jpg
Old Jun 6, 2011 | 03:45 AM
  #126
ccraviotto's Avatar
OREGON DEPONENT OF FORESTRY AND tRASKMOUNTAIN TRAIL RUNNERS open a black diamond trail [IMG][/IMG] trail
Old Jun 6, 2011 | 03:49 AM
  #127
ccraviotto's Avatar
the lower trail head Name:  kids018.jpg
File Type: jpg
Old Jun 6, 2011 | 11:06 AM
  #128
ccraviotto's Avatar
Size:  149.7 KB kinda tight hear.
File Type: jpg
Old Jun 6, 2011 | 11:09 AM
  #129
ccraviotto's Avatar
[IMG][/IMG] lots of work .
Old Jun 6, 2011 | 11:11 AM
  #130
ccraviotto's Avatar
my good old 85.[IMG][/IMG] ODF trail machine.
Old Jun 6, 2011 | 11:34 AM
  #131
geronimojaldin's Avatar
2 words for that 4runner TOTALLY AWESOME!!!!!
Old Jun 16, 2011 | 08:52 PM
  #132
ccraviotto's Avatar
started working on a upper a arm jig. I am going to build a + 5 upper arm. My first attempt will be to build off of a factory arm. i did a mock-up using some random pieces of plywood.[IMG][/IMG] .
Old Jun 16, 2011 | 08:57 PM
  #133
ccraviotto's Avatar
figuring how much lift i need to get the ball joint at proper angle.[IMG][/IMG]
Old Jun 16, 2011 | 09:09 PM
  #134
ccraviotto's Avatar
using the arm as a temp-let to drill the jig makes life easy.[IMG][/IMG]
Old Jun 16, 2011 | 09:13 PM
  #135
ccraviotto's Avatar
first hole.[IMG][/IMG]
Old Jun 16, 2011 | 09:17 PM
  #136
ccraviotto's Avatar
I found that my mock up plywood jig worked well for some more drilling.[IMG][/IMG]
Old Jun 16, 2011 | 09:35 PM
  #137
ccraviotto's Avatar
my jig will not match my existing a arm . i was maxed out on my alignment cams with the top of tire still tipping out very slightly.So i am going to shorten the a arm by 3/8 of an inch. All-so i am going to add some more caster <move the ball joint back about 1/2 inch>. [IMG][/IMG]
Old Jun 16, 2011 | 09:40 PM
  #138
ccraviotto's Avatar
ball joint spacers make a nice temp-let.[IMG][/IMG]
Old Jun 19, 2011 | 10:50 AM
  #139
BlazeN8's Avatar
Its fun designing new stuff, keep up the good work! I am interested in seeing how you will interface the factory crossshaft with the poly bushings into your new arms. The way the bushings fit into the factory steel shells is unique. Creating custom bushings may not be an option. I approached energy suspension to have some reproductions made for the discontinued Rancho arms and unless I was ordering them in the thousands it was a dead end. You might want to press the steel shells out of a pair of factory UCAs and weld them into some tube? Or find some universal bushings and design the fitment around the universal bushings. Maybe forgo using the factory crosshafts and use some some hiem joints and weld some tabs to the frame? I was wanting to tear into the Downey or TC design and see how they did the bushings on the factory crossshafts but decided to stick with the factory bushing design to keep cost and ease of servicable / replacable componants user friendly.
Old Jun 20, 2011 | 07:54 AM
  #140
BlazeN8's Avatar
I was looking at my CADD file of the UCA Extension Brackets and could revise it to meet your specifications. I drew a +4" UCA a while back that turned out nice. Drawing a +4.625" with a .500" back and a 2.000" drop shouldn't be a problem. I would charge you the standard $200 for the brackets themselves and a CADD drafting fee. My CADD rate is $85 an hour. It should take me about an hour to draw it up and another hour to convert the file to work with the laser cutter and to do the coordination.
