ccraviotto's 1987 4Runner Long Travel Build-Up Thread
Old May 22, 2012 | 02:11 AM
  #221
B-yodaful's Avatar
Awesome cant wait to see the vids of those bad boys
Old May 22, 2012 | 07:03 PM
  #222
ccraviotto's Avatar
started to build the other side after work .A pic of the arm bolted to my jig.Name:  P4140605.jpg
Old May 23, 2012 | 09:32 PM
  #223
ccraviotto's Avatar
i finished welding up my right side upper tonight.I took a few pic of what it looks like befor i weld on the top plate.Just a bunch of scrap welded together.Name:  P4150620.jpg
Old May 23, 2012 | 09:35 PM
  #224
ccraviotto's Avatar
underside.Name:  P4150623.jpg
Old May 23, 2012 | 09:42 PM
  #225
ccraviotto's Avatar
Hope it holds!Name:  P4150627.jpg
Old May 24, 2012 | 01:56 AM
  #226
B-yodaful's Avatar
CC that looks awesome.. Does this mean your old blaze kit will be up for sale?
Old May 24, 2012 | 02:34 PM
  #227
ccraviotto's Avatar
Yes it is.
Old May 24, 2012 | 03:12 PM
  #228
B-yodaful's Avatar
Pm me lets talk parts
Old May 29, 2012 | 10:20 AM
  #229
BlazeN8's Avatar
Interesting evolution of your build. How much wider are you now? Are you still going to be able to get enough spring rate out of the aftermarket Torsion Bar (25-26mm) with the added fulcrum length or are you going with a coil over conversion?
What remains from the Blazeland LA kit that hasn't been modified, welded on, or cut up to sell? Who ever ends up buying feel free to contact me at the Blazelandn8 at yahoo e-mail account if your wanting alacarte items.
$500 LCA's
$200 UCA's
$200 UCA Extension Brackets
$100 SS Brakelines
$100 Tie Rod Adj. Sleeves
$999 Complete Long Arm Kit
Old May 29, 2012 | 10:24 AM
  #230
B-yodaful's Avatar
I'm hoping its going to be be me Nate so thanks I will for sure be hitting you up for the rest of the kit.
Old May 30, 2012 | 08:14 PM
  #231
ccraviotto's Avatar
$500 LCA's
$200 UCA's
$100 SS Brakelines
$999 Complete Long Arm Kit[/quote]
I shorted up the upper arm from + 5.25 to +4.50.My thoughts, it might handel better with the top arm shorter and help with the torsion bars.I also moved the top balljoint back 1 inch for added caster .37-14.50 tire needs more caster than a smaller tire to dive down the road good. I rolled the cams in on the lower a arm and was able to get the tire staight up and down. I am happy with how it drives although the steering fills slightly heavy when turned.
Old May 30, 2012 | 08:33 PM
  #232
ccraviotto's Avatar
My scrap yard freebee arms are looking like they need some help.I Started to clean them with a grinder and flaper wheel.On my second arm I built the top plate small so when i welded it in my weld would penaetrate down the the side so i can smoth the weld .Name:  P4210639.jpg
Old May 31, 2012 | 09:45 AM
  #233
BlazeN8's Avatar
Your scrapyard UCAs look super beefy! I like the design of adding / welding on an extension section the way you did. I have a few sets of scrap UCAs from core returns that customers sent me over the years that were rejects because they were hacked up for BJ spacers or such. I was revisiting the possibility of cutting and lengthening in a way that would allow running a coil over conversion through the pocket rather than behind the UCA. Running the coil assembly behind the UCA (like a J-Arm) works fine but adding a secondary bypass shock would be a nice feature. I was also trying to incorporate some improvements for caster / camber adjustment. It just seems to be over engineering a simple solution; the bolt on UCA extension brackets have been working so well. But then again everything has room for improvement. Good stuff!
Old Jun 12, 2012 | 05:49 PM
  #234
ccraviotto's Avatar
Old Jun 12, 2012 | 07:08 PM
  #235
xxxtreme22r's Avatar
Freakin sweet !!!
Old Jul 17, 2012 | 11:09 PM
  #236
herocopter@gmail.com's Avatar
Pretty cool, nice work. I'm surprised I didn't find this thread when I was researching my own project. I really like the MK3 supra diff, that's what I used. Still looking to lock it. I also forked over the $$ for RCV axles, although I thought about sleeving the stock axles like you did. I'm curious as to how the 1/4 wall sleeve is holding up?
build thread:
http://www.ttora.com/forum/showthread.php?t=183890
PS: Sorry to thread jack for having a different model, meant only for comparison of center diff
Old Jul 18, 2012 | 09:10 PM
  #237
Numbchux's Avatar
Originally Posted by herocopter@gmail.com
Oh man! I just did something involuntary.......and messy
I think I'm about to loose some time reading your thread now.
Old Jul 18, 2012 | 09:21 PM
  #238
ToyoTech559's Avatar
+1. looks like a sweet set up. wonder how many more are out there running a center diff
Old Jul 19, 2012 | 10:36 AM
  #239
BlazeN8's Avatar
HeroCopter has a sweet ride! I am going to read more about it on the TTORA link he provided. As for how many folks out there are running a center mount diff I know of only three. Cassidy, Arron, and myself are the only ones I have information on but I know there are a few more out there. I have heard there are a few in Australia doing it with stock length control arms. Arron also has the Supra 8", which reminds me I need to get an update. If I can get them I'll post some photos!
Old Jul 19, 2012 | 07:51 PM
  #240
ccraviotto's Avatar
PS: Sorry to thread jack for having a different model, meant only for comparison of center diff[/QUOTE]
i am still running 120 wall dom for axle sleeves.I twisted one but i was being overly hard on them.I will build a set out of 250 wall soon i hope.I was thinking when i built my first set that the week point would be at the welds connecting the axle to the sleeve.now that the welding Has proven to be strong it time to up grade the sleeve materials.
