Bone Collector's 94 xcab 3.0 build thread
Old Sep 24, 2013 | 01:11 PM
  #141
kornhuskerwizard's Avatar
So was the cruiser wire with the fusible links a factory peice you had to get or could you get an aftermarket one.Reason i ask is because the starter wire on our 97 4runner is messed up on the end that goes to the battery post and it looks like the factory one but all ive found to replace it is a factory one, no aftermarkets.
Old Sep 24, 2013 | 01:28 PM
  #142
bone collector's Avatar
Autozone sells fusible links in the electrical section. About 4 bucks a piece. Comes with ends. That what I used and it worked great
Old Sep 24, 2013 | 06:06 PM
  #143
When I got home from work I put a third coat of paint on the rims and went to dinner.
After dinner it was time to install these bad boys. I pulled the first tire off and compared them side to side.
I like the way they look on the truck. I wish my truck sat these high but alas it is still on the jack.
I did have to do some "adjustments" to the fender wells to prevent rubbing the tires at full turn. Some persuasion with a BFH and all was well.
In other news...... I have a few friends coming over to help me bob the bed on Saturday. I'm trying to get ahead of the rust monster before it completely takes over.
Attached Thumbnails Bone Collector's 94 xcab 3.0 build thread-forumrunner_20130924_215836.png   Bone Collector's 94 xcab 3.0 build thread-forumrunner_20130924_215903.png   Bone Collector's 94 xcab 3.0 build thread-forumrunner_20130924_220116.png
Old Sep 24, 2013 | 06:30 PM
  #144
cdcrone123's Avatar
Okay sorry if it appears I'm trying to thread jack but this is urgent.
I have a 1995 4runner 3.0 stock. I was having problems with the egr system via a code 71 this being my daily driver I'm in a rush to get it fixed. I'm stumped howevef. I removed the pair and egr valves. Blocked both the ports in the engine they left. I sealed it with rtv and used the gaskets I saw on another thread (done this way). I put a 10k resister in and car will attempt to start but die within seconds. At first I thought maybe I didn't have vacuum lines connected correctly and started moving them around with no avail. Im stuck and she's been sitting for 3 days. Somebody help!
Old Sep 24, 2013 | 06:31 PM
  #145
julsruls's Avatar
Looks great. Im not a huge fan of silver but when you have a touch of it in there like you do, snazzys it up some without making to much bling.
Old Sep 24, 2013 | 06:38 PM
  #146
Ya I'm not much of a bling bling kind of guy. That's why painted them black. And yes I agree that just a touch looks good
Old Sep 24, 2013 | 06:41 PM
  #147
There is a bolt hole in the upper intake that everyone forgets to seal. It is on the left side of the motor as you are looking at it. Put a bolt in the hole with some rtv. Good to go
Old Sep 24, 2013 | 06:43 PM
  #148
cdcrone123's Avatar
Hey bone collector , did you have any problems with the egr mod you did such as not holding idle and dieing right after you start it. On mine i can hear it ignite on my 4runner 3.0. I've resealed the block off plates with rtv. Sealed off the intake hole that was left with a pvc cap and like 99% sure I put the right vacuum hones where their supposed to be. I'm stumped. I even put the 10k resistor in. I'm at the wtf do I do now stage
Old Sep 24, 2013 | 06:46 PM
  #149
cdcrone123's Avatar
I have a bolt in that hole. I just put that one yesterday. :/
Old Sep 24, 2013 | 06:47 PM
  #150
cdcrone123's Avatar
Still dies when I start it every single time
Old Sep 24, 2013 | 06:48 PM
  #151
Any check engine light codes? Did you read my previous post about the intake hole? All I can say is slow down, take a deep breath and keep calm. Triple check everything
Old Sep 24, 2013 | 06:51 PM
  #152
Pull the efi fuse and count to 30. Slowly. Reset the computer and give it a try. I would guess you have a vacuum hose backwards or not blocked off somewhere
Old Sep 24, 2013 | 06:58 PM
  #153
cdcrone123's Avatar
Okay I'm doing the reset on the ecu. That's what that does right? Its to dark to check for hoses ill do that tomorrow morning im off and getting my big ole red runner running is the goal.but do you have any pictures or anything you took as you went along.? Thanks for the feedback!
Old Sep 24, 2013 | 07:02 PM
  #154
Do some searching on this site for 3.0 egr delete. You will find some diagrams and pictures. I can take some in the morning if you need me to
Old Sep 24, 2013 | 07:07 PM
  #155
cdcrone123's Avatar
I have quite a few pictures but it would be helpful if you took some. Particulary the where your pvc cap is basically everywhere you've had to seal and such. After you took the pair off that hose in the back of it. Its a larger hose. What did you do with that. I haven't sealed it off or anything. Thanks again !!
Old Sep 24, 2013 | 07:18 PM
  #156
What PVC cap?
Old Sep 24, 2013 | 07:27 PM
  #157
cdcrone123's Avatar
I used a pvc cap seal off a hole that was left over by the air intake. On my truck when you take the silencer box off you are left with a hole that your supposed to seal. I used a pvc cap to plug that hole. Its about two inches big.
Old Sep 24, 2013 | 07:34 PM
  #158
I have an air box from a supra so I can't help you much. I deleted my intake silencer. Scroll back a few pages and you can see most of my setup
Old Sep 24, 2013 | 07:37 PM
  #159
cdcrone123's Avatar
I was wondering where you got that from! That's a way better idea then a white pvc cap. Looks very clean in there. Every post I sed about egr removal there's always a 10 page agruement over how bad it is for the enviroment. Etc. Its been difficult to find someone who has actually done it step by step.
Old Sep 24, 2013 | 07:40 PM
  #160
Search for a thread called " pair delete" it has lots of pictures
