93Xtra-Cab's 1993 Pickup
Old Jun 7, 2014 | 05:38 AM
  #581
Gizler00's Avatar
Bumper looks great! I used the same D rings on a support I welded in the back frame on my old 90 regular cab.
Old Jun 7, 2014 | 08:52 AM
  #582
93Xtra-Cab's Avatar
Thanks guys! My dad actually shot a coat of clear on it yesterday while i was at work and then we installed it this morning. I'll have to take some better pics. They never come out good in direct sunlight.
Right now the only thing I'm waiting for is some tag lights. Usps tracking said they were delivered to my house two days ago, but i havent seen them.
Old Jun 7, 2014 | 12:59 PM
  #583
89pickup-pablo's Avatar
Very nice man! Clean and simple. Looks pretty bomb proof.
Old Jun 7, 2014 | 03:45 PM
  #584
Teuf's Avatar
Very nice bumper. I like the simplicity. Makes me want to get going on mine.
Old Jun 10, 2014 | 11:19 AM
  #585
Nervo19's Avatar
[QUOTE=93Xtra-Cab;52200951]
Also, i bought some D-ring shackles from Tractor Supply for $10 a piece. They also contain chemicals that are proven in California to cause cancer...
So you can't drive it in California?
I really like the new bumper. You should do your dad a favor and make us bumpers from the rest of his hoard/pile.
Old Jun 12, 2014 | 09:02 AM
  #586
93Xtra-Cab's Avatar
I guess I can call this the bumper build wrap-up. I finally got my license plate bulbs in on Tuesday, I believe. In the 3 1/2 years I've owned the truck, the lights that were already on the truck never worked and I never got pulled over for it, but I figured its better to be safe than sorry. Plus for $7 or so, why not?
Anyways, the first thing I did was fasten the bolt to the bumper. I had to re-tap my existing holes to 1/4"-28, which I thought was so stupid. 1/4"-20 is a much more common size. Then to get both lights to aim down, I had to try a couple different washer combinations.
After that, I figured out why the original lights wouldn't work. Turns out both bulbs were burnt out and the drivers side socket wasn't getting any power. It also had some hackjob repair by the PO. As you can see, it looks like the original wire broke, so he tried to use one of those cheesy blue wire splices to fix it. I didn't want to even touch that, so I felt the easiest thing to do was just wire both LEDs in parallel to the passenger side socket since they draw such low current.
All cleaned up
Click image for larger version
The finished product
Attached Thumbnails 93Xtra-Cab's 1993 Pickup-forumrunner_20140612_125555.png   93Xtra-Cab's 1993 Pickup-forumrunner_20140612_125621.png
Old Jun 13, 2014 | 10:24 PM
  #587
Roark's Avatar
I hate hack job PO work.. Good stuff to clean up her rear!
Old Jun 14, 2014 | 11:55 AM
  #588
93Xtra-Cab's Avatar
Friday, I bought and installed a new distributor cap and rotor to fix a misfiring issue. The old rotor wss basically non-existant.
I took the truck to a local car show kind of as a joke and I ended up coming home with a trophy To make it sweeter I won a trickle charger as a door prize. Well worth the $10 registration fee lol.
Old Jun 14, 2014 | 09:40 PM
  #589
84 yota dude's Avatar
Haha that's awesome!
Old Jun 15, 2014 | 08:46 PM
  #590
WVYOTABOY29's Avatar
Sweet deal! Bet that show was fun
Old Jun 26, 2014 | 02:51 PM
  #591
93Xtra-Cab's Avatar
I got bored today and decided to clean up the hackjob of vacuum lines I created when I did my ISR mod. There are three lines, but the kit I bought only had two ports in the intake tube, so I created this contraption of hoses and reducers and crap just to get it running so I could take it to school the next day.
Now, three years later I finally fixed it. Not bad for an hour or so of work. Now I can remove my oil cap without having to remove the one hose.
Old Jun 27, 2014 | 05:08 AM
  #592
kornhuskerwizard's Avatar
Nice work!!Bumper looks great!!Trophy has dino on it!!Dont see to many sinclair stations anymore.
Old Jul 6, 2014 | 11:02 AM
  #593
LolaL's Avatar
[QUOTE=Nervo19;52202297]
seconded. I'm enjoying following your thread. Everything looks awesome and well done!
Old Jul 10, 2014 | 08:43 AM
  #594
93Xtra-Cab's Avatar
Thanks! I didn't get a good look at all the trophies, but I know they had different logos on them. I do remember seeing a guy get one with an Amoco logo.
Thanks! I try my best!
Old Jul 19, 2014 | 09:15 AM
  #595
93Xtra-Cab's Avatar
Yeah...I'll just leave these here...
I did feel finally remove the stripes. It felt wrong...now the truck is like a cobra without any venom lol
Old Jul 19, 2014 | 09:51 AM
  #596
Roark's Avatar
Are you starting some body work?
Old Jul 19, 2014 | 03:35 PM
  #597
bone collector's Avatar
Nice job on the bumper and the truck show!! keep up the good work
Old Jul 24, 2014 | 03:53 PM
  #598
93Xtra-Cab's Avatar
Today, I built my headlight relay harness for my H4 swap. I bought the housings and bulbs on Sunday and they have yet to arrive, so I figured I'd get the harness done so I can just throw it all in at once.
This would have been the post where I had differences between sealed beam vs. sealed beam w/ upgraded harness, but I couldn't get my harness to work.
I built my harness, plugged it all in and I got nothing. I used the passenger side headlight plug for the switch to turn the relays on and off, so I put both relays behind the battery on the fender so you can't see them. In testing and checking, I must have removed the battery AT LEAST 15 times and I have used over 5 schematics from the internet, just to check everything. I am 1,000,000% sure this thing is wired correctly.
5 hours into all this, I decided to throw in the towel for the day as I was just getting more and more PO'ed. So I put everything back to normal and I turn the lights on and I get this.
As you can see, the passenger light is very dim. At this point, I wanted to just pour gasoline over the entire truck and garage and just burn it to the ground. So I pull the battery out, yet again , to check the plug for damage. None. Then I FINALLY think to check the fuse. I took it out and it looked like partially blown. I throw a new one in and it's fine again.
So, my guess is that the fuse blew the very first time I plugged the harness in and there wasn't enough current to turn the relays on. I'll have to test it all again tomorrow. Right now, I'm done with it today.
Old Jul 24, 2014 | 06:03 PM
  #599
irab88's Avatar
hint: the high-beam indicator backfeeds to the low-beam filament. normal h4 relay harnesses don't support this. i drew up a schematic that works with our toyotas' circutry. i'll find it in a bit
Old Jul 24, 2014 | 06:13 PM
  #600
irab88's Avatar
https://www.yotatech.com/forums/f116...88/index9.html
