93Xtra-Cab's 1993 Pickup
Old Dec 24, 2012 | 08:20 AM
  #221
racerflea's Avatar
The average battery is rated for 3 to 5 years ypurs was pushing 6 so thats my gues
Old Dec 28, 2012 | 05:49 PM
  #222
93Xtra-Cab's Avatar
I got my new battery yesterday. I ended up buying the Mega-Tron II with 600 CCA instead of the Mega-Tron Plus with 800 CCA. The Mega-Tron Plus wouldn't fit in the battery tray. It's 3/4" too long.
According to the Interstate catalog, stock Toyota Trucks/4Runners with the 3.0L came with a 380 CCA battery while the 22R-E equipped vehicles came with 580 CCA batteries. That seems kind of odd...
I also ordered some blue LEDs for my dash and dome light conversion.
I've also thought about doing an H4 headlight conversion with the wiring harness upgrade. If I were to do that, I'd also convert to HIDs, but I've read that HIDs in an H4 housing sucks. To do it right, I'd have to retrofit projectors. I'm not going to do anything just yet because I want to do more research. Plus, wiring diagrams make my brain hurt...
Old Dec 28, 2012 | 06:59 PM
  #223
racerflea's Avatar
I know the 22re cca is correct. But i would watch out putting blue lights inside the cab main lights the local police may not like that too much... as far as the H.I.D. make sure you use your existing low beam light as the "trigger " on a relay.. also H.I.D."s dont have a high and low beam just a single beam... just something to think about
Old Jan 8, 2013 | 06:45 AM
  #224
93Xtra-Cab's Avatar
I should have listened to jskijoe. It was the starter. The battery helped, but only a little bit. When I went to start the truck the past couple days, it clicked over 20 times before it actually turned over. So last night I bought a new starter and put it in.
If anyone with the 3VZE is reading this right now, you better hope that your starter never has to be replaced. If you do need to replace your starter, prepare to cuss...a lot! FYI, the FSM is incorrect. It shows both starter bolt are fastened from the rear, but the bottom bolt is actually fastened from the front. I had use 3 socket extensions with a swivel just to reach the bottom starter bolt. You cannot remove the starter from between the frame and fender, unless you want to remove the motor mount or unless you have a body lift. The easiest way I found is the ease it down and forward, out by the tie rods. You have to unbolt the steering stabilizer, slave cylinder, and remove the two small ADD vacuum lines (if you have ADD) to get it all the way out. I would have taken pics, but I was too focused on getting it finished. Pics always make things easier to explain.
Old Jan 8, 2013 | 07:16 AM
  #225
93Xtra-Cab's Avatar
Oh yeah, I also got some of my LEDs. I got my #74 bulbs and my dome light. I didn't install the 74s since I'm waiting for my 194s, but I did put in the dome light.
It came with these adapters that I didn't need
The one I did use was the festoon adapter that adjusted to most sizes
Before
After. It had some 3M adhesive on the backside so I just stick it across the opening.
Before
After
Pretty good for $0.99. I found one for $4.99 that had 48 LEDs on it instead of 12. I'm still not sure why I didn't get that one. Anyway, that's all for now.
Old Jan 8, 2013 | 07:30 AM
  #226
racerflea's Avatar
Thats insane output! !
Old Jan 9, 2013 | 07:01 AM
  #227
lil_red_yota's Avatar
I've been thinking about getting one of those LEDs for my dome but was worried about fitment now I know it'll work.
Old Jan 9, 2013 | 09:12 AM
  #228
willmasterflex's Avatar
Wow that dome light is actually... useful! I changed the contacts in my starter, and remember swearing.. a lot. That things a pain to get out! At least it's done now!
Old Jan 9, 2013 | 11:17 AM
  #229
93Xtra-Cab's Avatar
I saw some that had the LEDs built into the festoon bulb itself. But you have to measure what size you need. I didn't feel like doing that
I'm pleased with it. I think I'd go with white, instead of blue next time.
As for the starter...I hope I never have to do that again. I didn't replace the contacts, I just got a whole new one. Swearing, throwing tools...just part of the fun
Old Jan 9, 2013 | 12:48 PM
  #230
Teuf's Avatar
The festoon in the standard pickup is 31 mm, I got a 4 led lamp. I got a blue one.
Old Jan 9, 2013 | 12:52 PM
  #231
racerflea's Avatar
So jealous of u guys with bench seats lol...
Old Jan 9, 2013 | 01:23 PM
  #232
Teuf's Avatar
Why? Buckets are nice. Remove 1 and you have lots ah room.
Old Jan 9, 2013 | 01:43 PM
  #233
93Xtra-Cab's Avatar
^But then you can't carry a passenger.
I'm also going to change the bulbs in the map light/coutesy light/whatever you call it, just like you did. I have the SR5 model so mine has 2 bulbs, however I'm not sure if they're festoon bulbs or not.
Old Jan 9, 2013 | 01:44 PM
  #234
93Xtra-Cab's Avatar
Neither of us has bench seats
Old Jan 9, 2013 | 01:50 PM
  #235
Teuf's Avatar
I had one. I should have kept it. I swapped it out about 5 years ago.
Old Jan 9, 2013 | 06:58 PM
  #236
racerflea's Avatar
Look at teuf's picture again lol i wish my truck had them.... the again i wish my truck was finished lol
Old Jan 10, 2013 | 05:45 AM
  #237
matt18603's Avatar
Just a thought about your visor. You dont like the idea of drilling your roof full of holes, and I dont blame you. But I found 3M Panel bond. Its good for "non-structural" panels. Youd have to sand to bare metal, but not drill holes in your truck. It sounds like its pretty tough and strong, I looked on youtube for videos and liked what I seen. Just some input. Take it for what its worth, nice truck!
Old Jan 10, 2013 | 06:31 AM
  #238
racerflea's Avatar
Not to thread jack but teuf why is there a elephant humping ur transfer case stick
Old Jan 10, 2013 | 06:34 AM
  #239
matt18603's Avatar
wow,....good eye. What IS that ?
Old Jan 10, 2013 | 06:58 AM
  #240
93Xtra-Cab's Avatar
I didn't notice that at first! Now I'm curious
