93Xtra-Cab's 1993 Pickup
Old Oct 23, 2012 | 10:53 AM
  #201
93Xtra-Cab's Avatar
Oh yeah! I have used that stuff before. There was a sale at Advance Auto Parts once so I bought a quart just for kicks to see what the deal was. I put the recommended dose in my tank and then let my friend borrow the bottle to use some. Haven't seen the bottle since. I can't even remember if it helped or not because that was back in June or July. I'll have to give her a call and see if she still has some left
Old Oct 23, 2012 | 10:57 AM
  #202
Redeth005's Avatar
Yep that's the one I use too. Only I buy the bigger bottle because I use it on both my 4Runner and my Corolla.
Edit: I noticed a difference in my mileage when I began to use it. i used to get 13-14mpg and now I'm up to 14.8-16.4 or so. And that's also with driving less aggressive too.
Old Oct 24, 2012 | 07:55 PM
  #203
Bucholz24's Avatar
About where at does your oild pressure run on the gague? I havee a feeling mine is a little low
Old Oct 25, 2012 | 04:04 AM
  #204
93Xtra-Cab's Avatar
When I was driving this morning, the oil pressure gauge was at the second line to the right when I was traveling at about 60. I'm not sure if that's low or high. I'll have to look at the manual or something.
Old Oct 25, 2012 | 01:06 PM
  #205
93Xtra-Cab's Avatar
All this talk about 33s have me wanting to throw on a set to see if they rub and how bad they are on factory gears. We had two in the bed of our plow truck that's in the woods behind our house. Oddly enough, they're Sport Kings. I'll have to throw them on at some point. I don't think they should rub since they're a 15x8 rim with a bit deeper backspacing than my rims. We'll see...
Oh, and I took this pic this morning at college. Thought it was worth sharing.
Old Oct 25, 2012 | 07:49 PM
  #206
Bucholz24's Avatar
I think mine might be low then. It runs in the middle tothe first line by the L
Old Oct 26, 2012 | 08:53 AM
  #207
Redeth005's Avatar
Nice man. So did they rub after all?
I have those same tires. Mine are 33/12.5/15 on stock SR5 rims. They rub on my truck so I have them set aside for when I get my SFA and 4" Lift installed to finally put them on.
Old Oct 26, 2012 | 10:38 AM
  #208
ChefYota4x4's Avatar
Lookin good, man.... Love that 'Sexy Chica de Roja' hahaha. RUBBING?????
Old Nov 23, 2012 | 10:43 AM
  #209
93Xtra-Cab's Avatar
Well it's been almost a month... and I finally got around to putting a 33 on. They look weird, but maybe that's because I'm used to a 10" wide rim.
I really didn't learn anything from it. They were so worn that they were actually slightly smaller in diameter than my 32s. They also stuck out roughly the same amount.
I also discovered this:
I wasn't really surprised, but this WILL be fixed in the spring.
Other than that, nothing else is really going on. I'm still looking for roll bars, hella lights, roof mounted light bars...just trying to figure out a direction
Old Nov 23, 2012 | 10:54 AM
  #210
willmasterflex's Avatar
I'm a fan of the red truck/black wheel combo.. lookin good!
Old Nov 23, 2012 | 11:43 AM
  #211
93Xtra-Cab's Avatar
Thanks! I actually can't stand black rims. If I were to get another set, they'd be 15x8" polished aluminum rims.
Old Dec 11, 2012 | 10:39 AM
  #212
racerflea's Avatar
I think black just makes it look mean!!
Old Dec 15, 2012 | 04:37 PM
  #213
Hellvision251's Avatar
Wow. Just spent the last hour reading through your thread. Truck looks great. I have a 92 V6 pickup . About to install leaf spring blocks and depending on how high i raises it over the front i might put ball joint spacers. Anyway nice looking truck..
Old Dec 17, 2012 | 10:20 AM
  #214
93Xtra-Cab's Avatar
Thanks! I myself prefer to have the front maybe a half an inch higher than the rear. I don't really know why.You can't really go wrong with ball joint spacers. Other than the fact that they change steering geometry and that some shops won't do an alignment on trucks that have them, they're great. The blocks on the other hand...
Make a build thread if you get a chance.
Old Dec 17, 2012 | 10:48 AM
  #215
racerflea's Avatar
Blocks areol until you start upping the power main thing to watch out for is axel wrap
Old Dec 17, 2012 | 02:56 PM
  #216
1986yota4x4's Avatar
good lookin pickup dude!
Old Dec 17, 2012 | 03:27 PM
  #217
Holy Rustoleum! lol... I had no clue you had any rot. Still a SICK RIG! lol....
I miss the Outlaw2's on there... BUT, ......... it does look pretty good, man NICE SHOES SHE'S WEARING.... :whistleswithcatcall:-smiley! hahaha.
Old Dec 23, 2012 | 04:53 PM
  #218
93Xtra-Cab's Avatar
For the past few weeks, my truck has been hard to start in the mornings. When I would turn the key, the starter would just click. I would keep turning it and it would be like the 8th or 9th turn that it would actually start. Last year, I added water to it to solve the problem. This year I had to do the same and it took 5 1/2 cups. Is that a lot to be putting in the battery? I definitely don't remember putting that many in last year. But it's still hard to start in the mornings now, even after adding the water. My guess is that I added so much water to it that the acid is too diluted. Also, I checked the manufacturer date and it was November, 2006. So I decided to order in a brand new Interstate Mega Tron Plus from work.
Boring update
Thanks!
Most of the rust was on the frame, but it's minimal now. That's the only rust I have on the sheet metal that I know of (I still haven't removed the bed liner to know what's under there).
If I were to get another set of rims for this truck, they'd definitely be another set of Outlaw 2s. I love them, but a friend of mine says they look like trailer rims.
Old Dec 23, 2012 | 08:14 PM
  #219
jskijoe's Avatar
Can't believe I've missed this build thread for so long! Good stuff you're doing there. My truck started it's life out in MD but is living out its years in SoCal. It doesn't miss the rust for sure..
I'm curious to see how your 33s look all the way around with the lift you have as I'm considering dumping my bracket kit for that mild of a suspension lift but I'm interested in keeping that size.
On your starting thing, have you changed out the starter contacts? It's a common and cheap fix if you haven't done it yet.
Old Dec 24, 2012 | 07:34 AM
  #220
93Xtra-Cab's Avatar
I figure if I hear the starter clicking then the contacts are fine. There just isn't enough power to turn it.
