91 pickup build
Old Mar 1, 2014 | 05:30 PM
ncarman91's Avatar
91 pickup build
I just bought my first toyota pickup. It is a 2.4L single cab. I drove about 2 hours to go pick it up and I'm sure glad I did.
Old Mar 1, 2014 | 07:19 PM
Gizler00's Avatar
Glad you started a build thread! Going to have to upload all the pics on the progress you have been making so far.
Old Mar 2, 2014 | 06:57 PM
Gizler00's Avatar
Here are a few pic I took for you.
Getting ready to fix a broken exhaust stud, compliments of the previous owner.
Old Mar 2, 2014 | 06:58 PM
Gizler00's Avatar
Still cannot believe how clean this thing is!! No rust or rot anywhere on the frame or body.
Old Mar 4, 2014 | 06:01 PM
kornhuskerwizard's Avatar
Very lucky to start out with something so clean. take care of it young jedi!!
Old Mar 4, 2014 | 07:29 PM
Gizler00's Avatar
I'll post some pics since you're being lazy.
Put an AAL in
Old Mar 4, 2014 | 07:56 PM
Roark's Avatar
I'm guessing you guys know each other?? That's one clean truck.. I'd be almost scared to touch it! Good find!
Old Mar 5, 2014 | 12:31 PM
Nice work!!! I like its stance. gonna look mean with some different tires!!! But the ones you have on there now should get good mpg. I like the blackouts on the lights as well. Only a matter of time before its sitting higher and looking more like Marks!!!!YAY!!!
Old Mar 23, 2014 | 02:10 PM
Gizler00's Avatar
Ill help you out with an update here.
Decided he wanted to change out the rear main, new clutch, and a new to him transmission that we got from 283yotacrawler.
Upon dropping the tranny and front diff to access the oil pan removal, we found bits and pieces of the timing guide in the pan. So I suggested that while we are this far, we just pull the engine.
Now we are going to tear it down and do the timing kit, oil pump, water pump, head gasket, head bolts and any other odds and ends that it will need.
Painting the front diff.
Old Mar 24, 2014 | 11:10 AM
ncarman91's Avatar
Dropping the transmission to replace my rear main seal.Name:  9AD8B0B0-AB7F-44AE-81B7-051C845C9606_zpsasxmhlkc.jpg
Found a part of my timing chain guide shredded up and sitting in my oil pan. Luckily we fought it before the chain rubbed a hole in the timing cover.
Decided I am this far into it, might as well pull the engine out and see what I'm working with beings I just got the truck, who knows what has/has not been done to it in the past!
And she's heartless
Got the engine on a stand and started tearing it down to access the timing cover
Getting the block all cleaned up for the new head gasket. Also going to tap out the threads for my new bolts.
And a table with all of my stuff in order and in labeled baggies.
More to come soon!
Old Mar 24, 2014 | 12:22 PM
Roark's Avatar
This build is looking good! What AAL did you go with? I'm looking to fix my own saggy butt.
Old Mar 24, 2014 | 04:09 PM
Gizler00's Avatar
Glad you were able to get the pics figured out. We will have the timing kit and head back on tomorrow. I will order more paint for the VC, water pump and oil pump.
Old Mar 26, 2014 | 05:30 AM
Gizler00's Avatar
Here are a few more pics of the engine that I took for you.
Old Mar 27, 2014 | 05:42 AM
Gizler00's Avatar
Heres a few pics for you kiddo.
Nick torquing the head bolts
All torqued down
Old Mar 27, 2014 | 08:40 PM
ncarman91's Avatar
Tapping out the holes for the head bolts.Name:  583EE3C1-65A6-4CAC-B385-A7766B2D2AB0_zpsjlkauumr.jpg
Making sure the head and block aren't warped
Primed the oil pump by packing it with vasoline
The whole reason behind this heart transplant, the rear main seal.
Flipped it around to seal up the oil pan
Machined flywheel and new AISIN clutch kit
More to come
Old Mar 28, 2014 | 05:32 AM
Gizler00's Avatar
Looks good! We should have it all back together and test run it before day is out.
Old Sep 26, 2014 | 01:53 PM
Gizler00's Avatar
Post up those pics!!
Jun 1, 2021 01:51 PM
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
toyoda8488
Jul 5, 2015 10:18 PM
