90 Runner sas f/R leafs vibration driving me nuts.
Old Jan 24, 2011 | 07:32 PM
noclinkers's Avatar
This is the culprit. Picture make it look taller than it is for some reason.
History is, I bought it for 500.00 as a non running project. Cut out both front and rear stock suspension and converted to leafs.
Converted the auto to 5spd and dual gear drive cases. The rear case is 4.7 w/twin sticks.
Diffs are both 5:29's with Detroit's (new)
Has new drive line 43" long w/cv
Here is the pinion angle with a cv drive line.
I have a vibration that I feel in the seat under load at mostly 50mph and faster. When I say load I mean when accelerating and decelerating. I can cruise on flat ground with no real noticeable problem.
I think it is coming from the rear because the front end is unlocked so that shouldn't come into play.
Front springs are 3'TG with anti death wobble 41/2 shackles
Rear springs are 5" allpro with the anti wrap leaf with 41/2 shackles.
I have tried the following;
Different tires
Stock rear third
New drive line That makes two with no change
Took the transfer cases out and rechecked them and they seem ok.
Any Ideas? All Help appreciated
Old Jan 24, 2011 | 08:22 PM
matt1992's Avatar
You have a modded drive shaft? it kind of sounds like unbalanced driveshaft or something close to that...
Old Jan 24, 2011 | 08:30 PM
MaK92-4RnR's Avatar
Sounds like an unbalance drive shaft.
Old Jan 24, 2011 | 09:27 PM
noclinkers's Avatar
I had the front IFS cv re tubed to make it fit the rear. It has been to two shops and they both say it is balanced? I am thinking about realigning the perches and putting a non cv shaft on?
Old Jan 25, 2011 | 09:35 AM
matt1992's Avatar
hmm, you mean a propeller shaft right? and your cv mounts at both ends are both put on exactly at the same angle? n how come you chose to use the front shaft 4 the rear/?
Old Jan 25, 2011 | 10:54 AM
noclinkers's Avatar
I don’t know what a propeller shaft is, but mine has a double cardain? (Spelling) on the tcase side with a regular u joint at the pinion. It was my understanding they ran smoother.
Old Jan 25, 2011 | 05:50 PM
noclinkers's Avatar
so everyone think it is drive line?
Old Jan 26, 2011 | 05:47 AM
waskillywabbit's Avatar
Bad ujoints or dshaft not balanced.
:wabbit2:
Old Jan 26, 2011 | 07:26 AM
noclinkers's Avatar
I've tried two drive lines both totally rebuilt.
Old Jan 26, 2011 | 07:47 AM
Snug up all the suspension bolts/nuts, especially on bushings.
:wabbit2:
Old Jan 26, 2011 | 07:53 AM
noclinkers's Avatar
:wabbit2:
Yep, all new bushings in springs, anti death wobble shackles.
Old Jan 26, 2011 | 08:01 AM
All new doesn't mean tight enough.
Try some balanced street tires.
:wabbit2:
Old Jan 26, 2011 | 08:07 AM
noclinkers's Avatar
:wabbit2:
There're tight and I've tried other tires. I'm thinking maybe rear tcase output.
Old Nov 26, 2013 | 07:20 PM
matt1992's Avatar
so did you ever fix your vibration issue? another thing i thought about is when the driveshaft was re assembled that slip joint could or one of the u joints were put out of phase... i hope you were able to fix it already though
Old Nov 26, 2013 | 10:03 PM
noclinkers's Avatar
Yep, got it fixed. Third driveline was the charm.
Hatch man
Aug 25, 2021 12:54 PM
MudnBullets
Oct 28, 2018 07:00 PM
stagger_lee
Mar 29, 2016 06:27 PM
duckhead
Jul 17, 2015 04:45 AM
camdenbuck
Jul 7, 2015 07:33 AM
