87hillbillyoter's 87 slow broke build
#783
sorry guys, i been suuper busy, havent really had time to come on here. driving back from chico every weekend is wearing me out.
nice man, you get it running last weekend?
heres a little update.
empty engine bay
wiring
new harness
new engine
threw a little paint on it
cleaned most of the baked on mud off the header
engine bay cleaned and a little paint
wiring stripped
in with the new
old stuff
engine in
broke this in the process
also dropped a bolt in the bellhousing through the starter hole, so i had to unbolt the transmission and driveshaft and move it back a few inches just to get the bolt
thats where im at, lights, wipers, stereo, all that stuff works. turn the key, fuel pump, fuel gauge, gauge cluster lights work. but no crank. i still have to ground everything.
That's awesome that you got a hold of a 22re! 130,000 isnt too bad. Good luck with the build. I wish i had time to help, but i cant because i'm still working 40hrs a week. I'm having my crank reground, got new pistons, rings, new head from engnbldr. also getting new main and rod bearings and in a few weeks i should have my 22re finnished. A+ engine machine shop in Reno, is doing all the major work.
1. Engine Degrease
2. Magnaflux the block
3. Bore 0.020'' over & Hone
4. Regrind the crank
I'm just glad you went this route instead of doing what i did and went with a bad company like Attarco in Sac. Apparently my qoute on qoute "new engine" was merely just a used motor with a hone job and new head. My engine had cylinder bores were 0.012" over stock and the pistons were like 0.015" undersize from the stock specifications. So were in a race to get our engines put in. Lol
Nice engine Hoist by the way!
1. Engine Degrease
empty engine bay
wiring
new harness
new engine
wiring stripped
in with the new
old stuff
engine in
#791
well, came home, slapped the intake on, and it ran. didnt run all that great, but it ran. it had a huge stutter. but anyways, i tightened up the exhaust, and then it wouldnt start again. any ideas?
#792
Play with your timing and see what happens. When my buddy and I threw a new 22RE in his rig, it was hard to start and was stuttering, had to play with the gas to keep it running. Full throttle was 1000 rpms
Turns out his distributor was off by a tooth. Moved it over and it ran perfect. Truck is looking real good by the way!
#793
It sounds like your right there though. let me know if working on it sunday? I hope to have mine up and running, as soon as i get my fuel injectors seals from Toyota. I think i might in a new ignition or ingnitor. By the way your weld job on my stupid flowmaster cracked.
#795
Turns out his distributor was off by a tooth. Moved it over and it ran perfect. Truck is looking real good by the way!It sounds like your right there though. let me know if working on it sunday? I hope to have mine up and running, as soon as i get my fuel injectors seals from Toyota. I think i might in a new ignition or ingnitor. By the way your weld job on my stupid flowmaster cracked.
thanks man
#796
BOOM
http://www.youtube.com/watch?v=fiOmuNztgkM
kinda hard to tell but it sputters quite badly when you hit the gas
#799
Sputtering? I'd point to TPS first... Just MHO. Always check for codes first, after driving it around a bit..... Then test the 'FREE CHECKS' first, right? lol. ........>>>>> TPS, AFM, 02, CTS, Timing, Unmetered Air.... etc.
Best wishes, and GREAT JOB, HB!
#800
thanks guys, space i dont know, i still gotta get the front driveshaft made, and i actually have to find somewhere to go wheelin. chef, i got it figured out, shes purrin now. only thing is is my charge and brake light are staying on, so ive been playing with all the grounds, wires and evertyhing. im pulling the positive cable tomorrow to see if the alternator is good to keep it running. im prayin that i dont need a new one
hahahaha)
.... OH< and nice B-day gift! SCORE!
