87hillbillyoter's 87 slow broke build
#762
yea, sorry about the bandwidth guys, i have my build on here, marlin, and pirate so the pics get quite a few views. and chef, i dont know all the details on it, but its an awesome engine. and i dont know if ill need the ecu, pretty sure hes got one. ill let you know though.
ill be needing quite a bit of help as ive never done anything like this before, let alone pulled an engine. well see how it turns out
#763
You'll do fine, homie! Step by step and mark EVERYTHING, ...then follow instructions, and in a couple days, POOF, you're running!
No problem..... start off with a Titled Post, "Starting 22re into 22r swap, NOW...." lol....and keep it organized, list things by numbers and such, and we'll walk you right through it, no problems!
#765
little update here. sorry for the no pics, theyll be back in a couple days. anyways, i decided to swap a 22re into my truck. heres where im at
oops! missed a ground wire haha
by the way, this engine is for sale if anybody is interested
where im at on stripping the dash
more to come later
more to come later
#768
#773
My parents just had a bunch of tractor work done at their spot, I must say, big caterpillars are damn impressive. Knock trees over, rip their roots out and level the spot where they used to be in a matter of minutes.
#775
#776
Just looked like the FEL was trying to eat your truck...
And, the picture would have looked better if your truck wasnt red cuz red was pretty much the only color that looked good for the teeth and such...
#780
That's awesome that you got a hold of a 22re! 130,000 isnt too bad. Good luck with the build. I wish i had time to help, but i cant because i'm still working 40hrs a week. I'm having my crank reground, got new pistons, rings, new head from engnbldr. also getting new main and rod bearings and in a few weeks i should have my 22re finnished. A+ engine machine shop in Reno, is doing all the major work.
1. Engine Degrease
2. Magnaflux the block
3. Bore 0.020'' over & Hone
4. Regrind the crank
I'm just glad you went this route instead of doing what i did and went with a bad company like Attarco in Sac. Apparently my qoute on qoute "new engine" was merely just a used motor with a hone job and new head. My engine had cylinder bores were 0.012" over stock and the pistons were like 0.015" undersize from the stock specifications. So were in a race to get our engines put in. Lol
Nice engine Hoist by the way!
1. Engine Degrease
