4RunnerKid's 1993 4Runner Build-Up Thread
Old Oct 28, 2007 | 07:58 PM
  #181
4RunnerKid's Avatar
friend's ex...
anyways, update for the day: flywheel and Marlin clutch are in, manual trans is in, starter is in, pedals are mounted, and master is mounted. had to order a new mount from work (Napa) since the first one i got was wrong, so once that's here i can bolt everything up for good. gotta pick up some hardlines and run those, get the wiring sorted out, trim the floor for shifters, bleed the clutch, fill up the trans and t-case, and possibly pull the axle forward an inch on the perches. later on i'll get the console all figured out and looking nice again, not really an issue right now. only took a few pics... gotta get my camera working and i'll post them up.
by the way, here are few sites i used for info on the swap... might help others in the future.
http://bbs.off-road.com/ubbthreads/s...ue#Post1262965
https://www.yotatech.com/forums/f116...on-swap-79842/
https://www.yotatech.com/forums/f116...-runner-82939/
Old Oct 29, 2007 | 10:46 PM
  #182
Blizzard's Avatar
Nice! Those duals must be sex... But I think they'll be overkill in my diesel hehe, maybe two stock cases...
I'm starting my SAS in 5 days! Will look for sure to this thread when I'm in doubt hehe
David
Old Oct 30, 2007 | 12:44 PM
  #183
bigarms23's Avatar
looks good you can still keep your auto trans and still run dual cases just get the adapter from inchworm.
Old Oct 30, 2007 | 04:51 PM
  #184
LTrunner's Avatar
i'n gonna keep wacthing as i'm hoping to do a 5spd swap on my runner next year. i'm planing on using a turbo trans, with t-case and 4.7s as it would be cheaper than using a v6 trans with the adapter,t-case and cross member...but anyway keep up the good work
Old Oct 31, 2007 | 10:32 AM
  #185
4RunnerKid's Avatar
well the new tranny mount worked, and everything is solid finally. gonna measure for the hardline tonight, pick that up at work tomorrow, and get as much done tomorrow after work as i can... ran into a little bit of a problem though. driveshaft is way too short, like 3+" too short... so that's gotta be taken care ASAP. i'll keep you guys posted on what i do.
Old Nov 3, 2007 | 10:09 AM
  #186
4RunnerKid's Avatar
swap is done, for the most part. waiting on my driveshaft still... but once i get that it's test drive time. still need to put the dash back together today, and figure out the console. can't wait to drive this thing.
Old Nov 3, 2007 | 03:47 PM
  #187
LTrunner's Avatar
so what did you do for wiring to make the reverse lights work, also so that it idlos right???
Old Nov 3, 2007 | 05:12 PM
  #188
Spinnbait's Avatar
wiring
There are only three wiring issues that MUST be accounted for in an auto to manual swap. The neutral/start, ADD, and reverse lights. The neutral/start is the most straight forward. To get it running, connect the two biggest wires that run into the lever select on the auto wiring harness. The reverse lights are as simple as putting the tranny in reverse and touching the wires together until they come on. I still have not figured out the ADD, so I bypassed the ADD sylenoid/vacuum system and have my ADD flange constantly connected. This is fine for me because I have manual hubs.
Old Nov 3, 2007 | 05:18 PM
  #189
LTrunner's Avatar
what's ADD i don't think my truck has that? is that the auto locking font thing for the newer trucks???
Old Nov 4, 2007 | 05:10 PM
  #190
WCorbett's Avatar
have you gotten any crap about not having mudflaps?
Old Nov 4, 2007 | 05:19 PM
  #191
CASTAIC 4RUNNER's Avatar
sweet ride
Old Nov 8, 2007 | 01:13 PM
  #192
4RunnerKid's Avatar
drove it last night...
pics once all the little stuff is done.
Old Nov 12, 2007 | 02:42 PM
  #193
4RunnerKid's Avatar
a few pics from Hollister... met up with Joey (UKMyers) and checked out his rig, which is awesome by the way. hopefully more pics show up, but these are all i've got for now.
poser shot:
mine and joey's 4Runners (sorry Joey, i stole this pic):
de-bending sliders after my attempt at Squeeze Rock:
Old Nov 13, 2007 | 12:33 PM
  #194
4RunnerKid's Avatar
more pics that hav popped up:
buddy's chebby
buddy's bronco
buddy's yota on tank trap
my other buddy's mostly stock yota on tank trap (rear locker, bald MTs, sliders, rear bumper)
Old Nov 13, 2007 | 12:42 PM
  #195
idayota's Avatar
looks like a lot of fun...how'd you get the chevy out of the bar pit?
Old Nov 13, 2007 | 03:02 PM
  #196
yotasavg's Avatar
nice pics. looks real good.
Old Nov 13, 2007 | 05:15 PM
  #197
4RunnerKid's Avatar
actually not sure how the chevy got out... i was at camp. i know he blew a bead (with beadlocks) and bent his rim, so i think he just aired it back up and backed out. i could be wrong though.
Old Nov 13, 2007 | 06:12 PM
  #198
slosurfer's Avatar
Your 4runner is looking really good. I can't believe it is almost as tall as Joey's. I just talked to Guy, any pics of them rolling in the S10?
Old Nov 13, 2007 | 07:29 PM
  #199
4RunnerKid's Avatar
it's a little lower than Joey's... but still on the tall side. it's suprisingly stable though.
here's a pic of the S10 in Tank Trap. i'll see if i can find a better one...
oh Chris, you know Guy?
Old Nov 13, 2007 | 07:45 PM
  #200
slosurfer's Avatar
He works for my dad and actually he is going to be working for me doing tile work tomorrow.
Joey's rig is tall! You should have seen it when it still had the rack and everything on top. I was following him through stuff at hollister and his hi-lift kept snagging everything.
