1986yota4x4's 1986 Pickup Build-Up Thread
Old Mar 4, 2012 | 04:20 PM
  #321
RMP8080's Avatar
now the cab will smell like gear oil........
Old Mar 4, 2012 | 04:22 PM
  #322
1986yota4x4's Avatar
never thought of that, well ill just relocate it to the gas tank fill
Old Mar 4, 2012 | 07:39 PM
  #323
ChefYota4x4's Avatar
Good idea! ...........Hmmmm, unless, of course, you JUST LOVE the smell of Sulfuric Rot in the Morning! hehehee.
Hey, ....... GREAT JOB, MAN! Looking good... i can't BELIEVE you pulled all that mess outta there!
Keep up the good work!
Old Mar 4, 2012 | 07:43 PM
  #324
Thanks chef, I didn't think it was that bad until I got it all out and looked at it and thought how I could think that it was a good idea to wire it like that, learned from that mistake for sure
Old Mar 5, 2012 | 01:17 AM
  #325
Terrys87's Avatar
Got rid of alot of wiring. Get the wiring harness for the stereo. Makes life alot more simpler. When I get a chance, I will look at my truck and see what those plugs are for.
Old Mar 5, 2012 | 09:06 AM
  #326
thanks terry, gonna make my own stereo harness and hook it up to a fuse block
Old Mar 5, 2012 | 10:45 AM
  #327
86.... The plugs LOOKS like the Diagnostic Plugs I've seen on some 'Carb'd' models. I know Brandon(XXXtreme) and I were going over this with a guy... But the fact that they're on the Pass. side,...that seems 'OFF' to me. I think the diagnostic plugs are on the driver side by the coil, against the fenderwell area. I'm EFI, so this might be irrelevant; The two plugs that are active that I DO have in mine, which look like that, are the Coil/Ignitor plug and the Distributor plug...both green.
Best wishes. Hey, don't you have a buddy with a 22R? I thought you did.... If so, just scope his out, ya know? (Sorry, I'm sure you thought of that.... just in case though! hahaha.)
Old Mar 5, 2012 | 12:17 PM
  #328
86YodaForce's Avatar
Not sure if Carb'd has a solenoid resistor, but mine looks like that, except its yellow. What about your windshield washer resevoir? Mine has a connection that looks the same also
Old Mar 5, 2012 | 08:50 PM
  #329
I do have a buddy with a 86 4runner but he moved away, and plus his was efi converted to carb so he has a lot of plugs going to nowhere. Also got my fuseblocks today, 2 4 fuse fuse blocks, gonna soder them together with a hot leading to one side on each fuse, so instead of running 8 wires I only have to run one. And gonna have 8 spots for accesories. Also started the pickup tonight and it has a misfire now
Old Mar 6, 2012 | 04:36 PM
  #330
got the fuseblock made today, 6 bucks total, hell of alot cheaper than getting one from anywhere else.
Old Mar 6, 2012 | 09:19 PM
  #331
RMP8080's Avatar
Good job, just remember to label them
Old Mar 6, 2012 | 10:46 PM
  #332
Nice work, 86! I didn't realize it was your kick panel fuse box! lol.... Did you think about grabbing one from the yard? (NOT saying you need to... just wondering if you had thought about it, lol).
X2 on the label well! haha.
Old Mar 7, 2012 | 08:51 AM
  #333
i have the original fuse box, this one is just for accesories, and i labeled them hence the 1-8
Old Mar 7, 2012 | 10:49 AM
  #334
Are you moving the orig. fuse block? Or does it not go there, like my rig? I'm sure you'll post all that up, just curious, lol.
Old Mar 7, 2012 | 12:19 PM
  #335
in the pic of my new one mounted you can see the original right above the green flasher relay, ill post more pics tonight
Old Mar 7, 2012 | 12:32 PM
  #336
Ahhhh, yes. derr! lol. Ok, see, mine has a cruise control module, etc., ...all kinds of crap there, IIRC, lol. Sorry man. Great job, seriously! If you ever want a really nice box, the DelTech one I have is great, and the Blueseas blocks are fantastically built! But this WILL work..... Nice work.
Old Mar 7, 2012 | 12:36 PM
  #337
There are cheaper prices out there, just an example and for future reference in case you ever want to....
http://www.boatersplus.com/blue-sea-...campaign=pgrab
Old Mar 7, 2012 | 04:57 PM
  #338
thats the one i really wanted chef was the bluesea one, but couldnt justify the $40
Old Mar 7, 2012 | 05:00 PM
  #339
got my tach all wired up and my lights for my aftermarket guages. started wiring up the stereo but i broke the plug so i need to order one
Old Mar 7, 2012 | 07:13 PM
  #340
Had a good talk with terrys87 and still can't figure out what those plugs are for, but got a lot of info and ideas from him
