SPC Mike's 1985 Toyota Pickup Build Up Thread
Old Mar 11, 2011 | 12:33 PM
spc mike's Avatar
SPC Mike's 1985 Toyota Pickup Build Up Thread- 3/11/11
Well, i guess i will do a build up thread starting now, because i am going through a motor rebuild for a second time and i plan on making future trail/rock crawler mods soon after, so what a better time than now to document it! My truck is a mostly stock 1985 Pickup with 22r, 33's, ARB front bumper, 10k winch, Marlin rear bumper, and other little stuff like Mar-Link steering rod, V6 brakes and booster, 140 amp Power Master alt, Taurus E-Fan, yellow top optima ect. let the pictures begin...
Truck before new rims and tires.
Truck as of today.
Shattered Exhaust valve in cyl #2 is what caused the pre mature rebuild.
Old Mar 11, 2011 | 12:46 PM
spc mike's Avatar
SPC Mike's 1985 Toyota Pickup Build Up Thread 3/11/11
Motor is out of the truck and block should be back in my hands by early next week. Big Thanks to Couger69 for letting me borrow his cherry picker!
Piston # 2 actually cracked all the way through from the force of it smashing the valve pieces into the head!
Trans is out and getting a good cleaning or maybe even a soda blasting to get it really clean.
Old Mar 11, 2011 | 12:52 PM
spc mike's Avatar
Since i have all that free room under the truck right now i decided to get under there to shave the Torque rod bracket off the axle along with the steering stabalizer and sway bar tabs. Now it will be ready for when i brace it later on.
Also shaved the torque rod bracket off the frame because that will be in the way of the high steer box and plating later.
Old Mar 15, 2011 | 06:53 PM
twistedyota's Avatar
truck looks great, tht sux aboiut the valve breaking. good luck
Old Mar 15, 2011 | 08:11 PM
c0ugar69's Avatar
lookin good man, did you get my message about the axle housing, i think mines gona be good the way it is after the repair, so you can use the housing to modify it. it may not have the lower truss but with the upper welded on it would be good.
good thing you decided to rebuild, would have never seen that piston crack. I am gona get some gears and have my elocker regeared soon!!!!
Old Mar 28, 2011 | 02:13 PM
spc mike's Avatar
Oh and i picked up some Marlin high steer arms on Thursday! :thumbs: They were used, so i had to clean them up a little but i cant wait till i get started on the steering. :willynilly:
After the sand blasting and ready for paint....
Old Mar 28, 2011 | 02:14 PM
spc mike's Avatar
OK, got my block and crank back on Friday from Ron's Machine shop. I ended up picking it up from Auto Machine Specialties and taking it to Ron's because they were slacking big time on the machine work :nonono:....they had it for almost three weeks! :tantrum: and Ron's finished it in about a day and a half! :clap2: but anyways.... i Painted it and pressed the new freeze plugs in today so i am just waiting on my new King bearing for the bottom end and my head to ship out from Putney's Next week Then we can really get roll'n :wink2:
painted with fresh freeze plugs
Bored .030 over and decked the block as well as the timing cover so the head gasket sits flush on both.
Valve cover soda blasted and masked
Valve cover Painted with VHT Wrinkle Black paint and fresh 22r decal.
Old Mar 28, 2011 | 02:15 PM
spc mike's Avatar
Got my Yukon 5.29's & setup kits for my 2 e-lockers! :circle: Now i just need the time to set em up.....
Its a good sight!
Can't wait!
Old Mar 28, 2011 | 08:20 PM
c0ugar69's Avatar
need to compare gears. take a couple close ups of your gears. how much was the elocker setup kit??
Old Mar 28, 2011 | 09:15 PM
spc mike's Avatar
Ill take some pics pretty soon. But the setup kits are just the v6 setup kits...still need to order those big "locker side" bearings from that web site you were talking about. Did you ever get yours in the mail?
Old Mar 28, 2011 | 10:51 PM
86 TOY's Avatar
THAT LOOKS AWESOME! Great choice! Good luck with the build, looking forward to your updates...
Old Mar 28, 2011 | 11:19 PM
spc mike's Avatar
Hey thanks 86 toy. I hope it hold up and doesn't start chipping. But right now it looks awsome...and C0ugar69 here are some pics of the markings that are on the gears..... They are Genuine Yukon's, not like some that have said they got some with questionable markings in a Yukon box.
pinion
heres a couple shots of the different markings on one ring.
Old May 14, 2011 | 06:40 PM
hows the gears?
Old Jul 29, 2011 | 03:17 AM
warbirdghost's Avatar
Man I need to quit looking at trucks like yours. It makes me feel like mine's a POS. lol. nice truck
Old Jul 29, 2011 | 05:21 AM
c0ugar69's Avatar
You think thats bad I Have to see it up close and watch as he does all the things I want to do to my rig Its a pretty sweet rig. should be working on getting one e-locker in the rear maybe he will get on here and update this thread!!!
Old Mar 28, 2012 | 05:20 AM
skilled4reel's Avatar
wheres the finished product?
Old Mar 29, 2012 | 09:51 AM
Boomtacoma01's Avatar
Good looking truck. I like that you are starting off with some quality parts.
6th Gear
19
Dec 10, 2019 07:31 AM
puddlepirate
Jun 30, 2015 05:08 PM
zytra
Jun 24, 2015 08:14 AM
Eagle564
Jun 23, 2015 11:29 PM
JaredL
Jun 16, 2015 04:47 PM
