Outsane's 1984 4Runner Build Thread
Old Jun 22, 2011 | 08:40 AM
  #101
RBX's Avatar
RBX
Outsane,
My A/C diode failed recently and would stick the fan on all the time, mine is connected to the battery not the ignition, so it can run whenever it feels like it(MD doesn't get too many days over 100*f). DCC told me that the A/C clutch can stick and it will backfeed the line, IDK, he said it could have been a diode failure on the A/C, they have a new chip for my controller that doesn't let this spike affect the controller....don't know if this could have happened to yours also.
Old Jun 22, 2011 | 01:29 PM
  #102
Outsane's Avatar
yeah something is screwy with my fan set up...
going to rewire it all when I get a new continuous solenoid relay deal make for glow plugs..
Old Jun 22, 2011 | 05:39 PM
  #103
Terrys87's Avatar
Other then vacuuming the system, were you able to do it yourself? I will need to convert.
Old Jun 23, 2011 | 07:01 AM
  #104
Outsane's Avatar
Terry are you talking about converting the AC to R-134a... I had some help..
I vacuumed myself, picked up the vacuum from harbor crap
Old Jun 25, 2011 | 04:17 AM
  #105
Terrys87's Avatar
Yeah I was.. I was hoping it was a do it your selfer. I enjoy driving my 4Runner, but not a sauna on wheels. It is something that is going to start gettting attention soon.
Old Jun 25, 2011 | 06:29 AM
  #106
Outsane's Avatar
It's not a hard job, give it a shot. Just be gentle on the aluminum fittings.
Old Jun 25, 2011 | 03:31 PM
  #107
Outsane's Avatar
New battery from Napa, and swapped out the relays in Parrallel one that is a little more stout to switch on the villager fan, still need to find some kind of a cap for the open terminals
Amazon Link
Old Jun 26, 2011 | 10:29 AM
  #108
Terrys87's Avatar
Dont know if one of the big home stores might have something to cap those off. Never run into that. But I would want ot get them covered also. Somehow I would find away to short it with a wrench if it was uncovered.
Old Jun 26, 2011 | 03:07 PM
  #109
windedwalrus's Avatar
If you can't find caps for those treminals at any of the auto or home stores you could try an electrical whole sale place like C.E.D, ESSCO, or WESCO.
Old Jun 26, 2011 | 05:23 PM
  #110
Outsane's Avatar
Yeah just need to make the trip out there
Old Jun 28, 2011 | 04:59 AM
  #111
RBX's Avatar
RBX
You will find caps for those at a boating/marine supply store.
Old Jul 5, 2011 | 11:13 PM
  #112
Terrys87's Avatar
Hadnt seen you on in awhile. Hoping everything is going ok for you.
Old Jul 6, 2011 | 07:20 AM
  #113
Outsane's Avatar
Thanks Terry... just busy at work
and the new continuous solenoid relay melted.. so I am back to three relays in parrallel until I can find a better set up..
Old Jul 6, 2011 | 07:31 AM
  #114
RBX's Avatar
RBX
from Amazon:
150 Surge Amps, 75 Amps Carry for 5 Minutes....
What is that suppose to mean on an advertized continuous duty solenoid...doesn't continuous imply ...uh... continuous?
Is that the one that melted? I'd try to get a refund for misleading information.
The Nissan Quest/Mercury Villager fan i use, had 20amp relays attached to them. Now those relays IIRC are rated for 65amp surge, then 20amp constant.
i hope you get that sorted out, i know the feeling of wondering if the efan is going to kick on or not.
good luck
Old Jul 6, 2011 | 08:20 AM
  #115
irab88's Avatar
could have sworn i was subscribed. now i am!
Old Jul 7, 2011 | 01:47 AM
  #116
Terrys87's Avatar
I just love electrical. NOT.. Hope you find something that works. I cant help you there, even though I have had my fair share of electrical problems.
Old Aug 11, 2011 | 07:24 PM
  #117
Outsane's Avatar
Started to tear out the carpet, to dye and insulate the floor board and found I had a clutch master cylinder leak..
Ordered a new Master cylinder that night.. drove to work..and it was hard to shift..
got home.. and the slave was leaking bad...
So I have now replaced the master and slave cylinder, I bought a new rubber clutch line to replace the old one.. .. but the old one didn't look bad and it would be a pain to replace..
Old Aug 12, 2011 | 02:42 AM
  #118
RBX's Avatar
RBX
hate when that happens.
Old Aug 15, 2011 | 07:54 AM
  #119
Terrys87's Avatar
I got to change the Master on my runner and slave on my flat bed. Not a bad job, on the Master Cylinder, make sure and keep the collar/ "O" ring under the fluid tank. It can be easy to miss and will leak.
Bench bleeding it makes it alot easier before installing it.
I just used some soap and water and got the metal cleaned before putting Peel and Seal on. It makes a difference. I think before I am all done with it I will use a total of 4 rolls. It made a big difference.
Old Sep 28, 2011 | 12:48 PM
  #120
Outsane's Avatar
I must have done all this several months ago...
Pulled the carpet and power washed it
Here is what it looked like after the first coat... I ended up using 3 cans
the Booger helped me out a bit, mostly by not crying and being a good boy
Starting to lay down the peel and stick after wiping down the body with water and simple green
More peel and stick I used a razor blade to make my cuts
Starting to lay down the carpet
Back carpet all in and I tossed a seat in to drive to work for the week
Front end
Front Carpet in
Passenger side
I am not a fan of dying carpet, much of the dye has already worn off.
going to have to buy new carpet..
I am a fan of the Peel and stick
