Outsane's 1984 4Runner Build Thread
#441
Having all kinds of issues with the mill
dropped the rear diff and put back in the 4.88 with soft locker...
the old one was starting to grenade itself, lots of metal chunks..
put in a new 1" master cylinder
Also mounted some power mirrors, still need to wire up and power them..
#442
thinkin about doing this, where'd you buy it from?
noticeable performance difference? kinda weird for me reading about all the brake upgrades people do, with my manual trans i've never got my brakes hot, or had any trouble stopping....even with the 35s. let me know if you see a huge difference
#443
Lowrangeoffroad
Trailgear
Etc..
Made a big difference in mine but I also added the v6 calipers. Pedal feel is hard but manageable. I have the single diaphragm booster which I think is why it is hard
#445
You're gonna love the mod!
#448
pulled it out last week
First pattern from last night
backside
seems a little shallow...
then we had an issue with the Solid Pinion spacer not fitting on the Pinion..
this was a New G2 pinion solid spacer and a new Yukon gear set... sucks..
backside
#449
Outsane - just did my gears not long ago. I agree with you, that's a tad shallow. Do you mind sharing what your backlash and pinion shim value is? I'm pretty sure if you ask ZUK, he will tell you that is shallow as well, he seems to prefer slightly on the deep side for strength. That stinks on the solid spacer (maybe they sent you the wrong one?), but good choice on the Yukon gears.
Here's my final pattern:
#450
Thanks cory, I had a buddy help set up my gears and the patter is much better..
I got some leaf springs from Redeth, and threw them in the front to replace the old downeys.....
the bushings on the old springs were pretty shot... but the height is just about the same, I am hoping to put the rears in and not have to use the Zuk mod..
#452
kornhuskerwizard
soft is supposed to be quieter...
https://www.yotatech.com/forums/f31/...-locker-50332/
I swapped in the rear and front leafs from Redeth going to need some more poly bushings.
New Springs mean I could remove the zuk mod
#454
The rig sits pretty slanted with the springs in... I may have to try and swap them left to right to try and fix that..
I picked up a 8274 Warn winch off a friend with a steel cable..
It will not mount in the Addicted to Offroad bumper I have on the rig...
going to have to either build a new one or modify this one...
#455
Lee if it continues to sag you might want to try adding one or 2 leafs from your old stock ones.
I had to do that with the first set of AllPro springs I got before I returned them for a bigger lift. That trick seemed to even out my rig perfectly. Look through my thread from when I SAS'd and you'll see how I did it. Although I don't think I had added springs to the set I sold you. I just used them the way they were. They sagged a little on my truck too but I was okay with it.
#459
Redeth I'll take a look at your thread on adding leafs.
8274 is about 8.5 inches deep, while the space in the bumper is about 6.5 or so..
Also the upper mounting bolts are 4.5 inches high...
there will be lots of modification needed to get this bad boy in..
#460
Holly Molly I haven't updated since 2013...
Well we had another kid... the first one got older...
Not much has happened with the rig...
I put an LCE header on... any body want to buy the old Downey?
I just got the AC to finally work... so excited about that..
