Outsane's 1984 4Runner Build Thread
Old Aug 15, 2012 | 09:12 AM
  #401
Outsane's Avatar
received this in the mail
replaced Torsion bar bushings, I had to use the old inserts, as the ones supplied had a ID that was too small
cleaned up
painted
Old Aug 15, 2012 | 01:43 PM
  #402
RAD4Runner's Avatar
Originally Posted by Outsane
Bought this on friday night Hoist a top
Mounted a 2x6 to the ceiling with 12 4 inch lag bolts, and mounted the hoist to the wood.
Nice, outsane!
Guys, Would you know how heavy the top is? Need to see if possible to make manual hoist OR simple have help lift it off or on.
TIA,
RAD
Old Aug 15, 2012 | 02:10 PM
  #403
Outsane's Avatar
I have seen reports of it being between 125# and 150#
several guys do the manual method, including 4crawlr Roger
Old Aug 16, 2012 | 11:11 AM
  #404
Outsane's Avatar
ah crap
measured and I need alteast 24" extended length shocks... these are too short...
ordered some shock mounts and a flip kit. should make up the difference and give me some time to save some money and get some new Blue and golds... I have some new spares to toss in....
http://www.doetsch-shocks.com/
Old Aug 16, 2012 | 12:24 PM
  #405
JAvendan's Avatar
wow!
at least you know what you need to do... i'd bring it/tow it to a shop - lol.
btw, i saw you rolling down SM blvd the other day
joel
Old Aug 17, 2012 | 06:35 AM
  #406
Outsane's Avatar
nice Joel...
next time honk!!
Old Aug 20, 2012 | 06:44 AM
  #407
Outsane's Avatar
welded on the shock mounts..still need to paint and move the shock..
maybe put on the rear flip kit
Old Aug 20, 2012 | 09:04 AM
  #408
RAD4Runner's Avatar
Thanks!
Thanks, outsane! and greetings from North County I notice your work on the suspension bushings. I'm hearing squeaks on mine. Might have to replace them.
Outsane and folks,
May I have your recommendations for where to get suspension bushings? Got stock suspension soon to be Zuk'd. Not for hardcore wheeling, just taking me to trailheads.
-RAD
Old Aug 22, 2012 | 12:32 PM
  #409
Outsane's Avatar
Marlin has some bushings...
or Energy suspension... not sure on what is best..
Old Aug 22, 2012 | 02:27 PM
  #410
JAvendan's Avatar
... greetings from North County
[snip]
-RAD
where in north county are you?
i have some coil springs from a jeep (?) that you could have if you want to try them out.
joel
Old Aug 23, 2012 | 07:09 AM
  #411
Outsane's Avatar
Found an exhaust leak in my header
Added a ground loop isolator for the stereo..
Old Aug 24, 2012 | 10:12 AM
  #412
Outsane's Avatar
Here is an image of the leak..
I threw a puddle weld on it... so glad I have a welder in the garage.
now that I am looking at the huge pic.. I can see a crack forming...
great... guess I'll have to remove the header and fix that some day..
Old Aug 24, 2012 | 12:53 PM
  #413
Philbert's Avatar
Hell, I thought it was 200! My wife helped me take mine off this summer, so yes it can be done with a helper. Just know the rear end is much heavier (wiper motor).
10 years ago, the week I picked up my truck, I somehow, alone, removed the top without dropping it or damaging anything. I would never try that again!
Old Aug 24, 2012 | 12:55 PM
  #414
Philbert's Avatar
Sorry, what is that?
I imagine it eliminates a "whine" from the stereo right? But what is it and how do you do it?
Sorry for the distraction
Old Aug 24, 2012 | 01:04 PM
  #415
Outsane's Avatar
no worries phil..
I bought
http://www.amazon.com/Audio-Systems-...+loop+isolator
$7.85 free shipping (Amazon Prime member)
just connects inline for RCA connectors..
And yeah its there to cut down electrical noise, it was worse when I had my iphone, then it is now with the Samsung Galaxy III
My phone is connected through the headphone jack to the AUX on a really old alpine head unit..
One of these days I would like to go bluetooth... If I can get an amazing deal on a head unit..
Old Aug 25, 2012 | 12:58 AM
  #416
Terrys87's Avatar
You mind telling me what brand of header that is and overall with the luck you have had with it? Crack like that wouldnt worry me so much. I have a tough time getting them to seal to the head. I use Toyota exhaust gasket. I personally prefer the stock manifold just so as I can get a good seal, but those are getting harder to find.
Old Aug 25, 2012 | 05:19 AM
  #417
Outsane's Avatar
Terry It's a Downey header I have had no issues with sealing.
Oh and I got 18 mpg at the last fill up. I think the bikini top helped aero a little.
Old Aug 25, 2012 | 01:16 PM
  #418
JAvendan's Avatar
sweet.
i have a downey header and intake. the previous owner installed those.
does your header have the CARB number on the header?
i have a sticker that i stuck under the hood and have had no problems with smog.
joel
Old Aug 25, 2012 | 02:26 PM
  #419
Outsane's Avatar
I don't have a carb plate or sticker
Boo
Old Aug 26, 2012 | 08:39 PM
  #420
RAD4Runner's Avatar
Springs for No-Cut/Weld Zuk & Stock Lift
i have some coil springs from a jeep (?) that you could have if you want to try them out.joel
Marlin has some bushings...or Energy suspension... not sure on what is best..
Thanks Guys!
Joel ,
From what Jeep are your springs?
Guys,
What springs do you know that will not will not lift too much beyond stock, and could be used on no-cut/weld Zuk?
I already got Black Magic 12", 3-inch ID, 125#/inch, but am holding off because:
  • I might find springs that will not require lifting fronts.
  • Need to order polyurethane (hard like skateboard wheels) inserts to eliminate metal-to-metal contact between spring, frame and lef pack U-bolts.
