84 4x4 lwb I'm in love
Old Feb 10, 2016 | 05:24 AM
  #141
Gizler00's Avatar
Seat covers look great.
Old Feb 13, 2016 | 05:00 PM
  #142
84maroonsolidaxle's Avatar
Thanks!
Old Feb 13, 2016 | 05:13 PM
  #143
.50 cal console
After driving around with different combos of stacked box/single box I decided the best option would be to add a little height to the single .50 cal ammo can.
(Also borrowed my dads Tuffy cup holders for a test fit)
Old Feb 13, 2016 | 05:27 PM
  #144
2x4 box
I guess it is no coincidence that the height I found to be most comfortable is very near to the factory sr5 console.
I needed about 8" on top of the can to get a comfortable level for an arm rest.
I removed the top handle and front latch mechanism. The lid stays put without it.
Built a 2x4 box to sit on top and store a small amount of cargo.
Bolted to the lid
The top will be getting some hinges and a pad
Old Feb 13, 2016 | 05:34 PM
  #145
Finishing touches
My mom volunteered to add a 2" pad and some material to the lid and something to cover the rest of the wood. I have graciously accepted and am looking forward to seeing what she comes up with.
I will also add some hinges to the box lid and a few bolts through the floor to hold it in place.
Old Feb 15, 2016 | 08:41 AM
  #146
tyrelephant's Avatar
NICE truck man! I really liked the expedition style thing you had going on. I have to agree with you on the OME springs. They ride GREAT!! And they only get better the more broken in they get! That ammo can console is a great idea, ill have to look into doing that myself...
Old Feb 16, 2016 | 03:07 PM
  #147
Thanks dude, like your 4Runner too!
I love expedition style builds but it's a little tricky with these trucks because you have to watch the overall weight.
Mine didn't do well with the tent on top so I'm building out a camper shell.
Old Feb 18, 2016 | 12:35 AM
  #148
rustED's Avatar
Just finished reading through your build thread, nice work, your truck looks sweet!
Old Feb 26, 2016 | 01:37 PM
  #149
Gizler00's Avatar
I always contemplate doing the Ammo Can Mod to mine and removing the Rear heat console. There really is not much storage with my current setup and I would love more.
Looks great man. How are the springs settling in? Mine are still getting there. I need to go flex it out.
Old Mar 10, 2016 | 03:08 PM
  #150
Thanks, love the 4Runner
Old Mar 10, 2016 | 03:13 PM
  #151
Springs
In the process of deleting the rear heat in my dad's 4Runner for that reason.
My front springs are good but the rear was too stiff without a load.
I took out 2 springs and it softened up a lot.
Also my rear OME shocks were completely extended at ride height with no load so I removed them.
Rides better now. Front is a little flat. Thinking about adding my rear leaf to the front if it will fit.
Probably eventually get longer shocks all the way around.
Old Mar 10, 2016 | 03:26 PM
  #152
Messing with springs
Shackle closest to the camera in the pic above is the full medium leaf pack. <br/>Shackle in the background has 1 overload leaf and the 3rd leaf from the top removed. Little better angle.
Old Mar 10, 2016 | 03:31 PM
  #153
Springs cont
Taking it apart.
It was surprisingly easy.
Big one on the bottom and third from the top. Might reinstall the overload when I get longer shocks.
Old Mar 10, 2016 | 03:33 PM
  #154
I took the whole pack out on the driver side to disassemble and remove 2 leafs.
After doing that I realized the springs could be removed while still installed in the truck.
Saved myself some time and work on the passenger side.
Old Mar 10, 2016 | 03:35 PM
  #155
Easy way to remove springs
Old Mar 10, 2016 | 03:39 PM
  #156
Before and after
First pic is full pack
Seconds has 2 removed
Old Mar 10, 2016 | 03:42 PM
  #157
Measurements
Old Mar 10, 2016 | 03:44 PM
  #158
End result
Lowered 1.5" and much softer.
I think it will sit fine and maybe be a little softer with my camper shell and some tools in the back.
But I usually drive around unloaded.
Old Mar 10, 2016 | 03:52 PM
  #159
Flex pics
Testing out the new set up on a log.
Rear shocks are not installed in these pics. They are too darn short and constantly top out after bumps. And completely restrict droop.
Old Mar 10, 2016 | 05:48 PM
  #160
Motor noise
I've seen it coming for a while and it finally happened.
On the road about 2 weeks ago and my motor started making a loud clunking noise.
I pulled into a parking lot and towed it home the next day.
I don't have any experience rebuilding motors but I also don't have any money so I guess I'll learn!
