775Toy's 84 X-cab build Thread
Old Mar 13, 2012 | 07:18 PM
  #101
775Toy's Avatar
Broke down and rebuilt the carb today. Ordered the brand (standard)kit which was told the best most complete kit. It worked out good except the fact it didnt come with a bowl vent solenoid diaphragm ! Came with a gasket and rivets but no diaphragm. I air checked it and it works so o well it will do. Just need a fuel pump and fuel amd she should fire up.
Old Mar 13, 2012 | 08:09 PM
  #102
westjohns yota's Avatar
wow great looking build man! got my leafs and lift today and hopefully be putting mine on tommorow, hopeing to clear 36s atleast, like the hysteer but do you think its worth it?
Old Mar 13, 2012 | 08:16 PM
  #103
775Toy's Avatar
The hi steer I'm my opinion is a must with a lift , especially if you plan on crawling it's nice to not bash your tie rod and have a better turning radius. Lots of people run stock low steer but once they switch to hi steer , stock steering is a joke. What leafs did you get ?
Old Mar 15, 2012 | 07:17 PM
  #104
just 4in lift springs, prob gonna do a longer shackle up front, i refuse to block the front, i really hated blocking my back, but it was free.
Old Mar 19, 2012 | 05:56 PM
  #105
775Toy's Avatar
So I got my radiator back in and full of fresh coolant , new power steering fluid, front shock towers cut off frame , the rest of the frame wire wheeled & rattle canned , ebrake line mounted on gas skid , and fabbed up a quick coolant resivor mount. Ordered my fuel pump / pump spacer / fuel filter / motor oil & filter / PVC / air filter , should have it all tomorrow morning. Also placed a order for a few lil things from trail gear which should be here by wednesday. Getting pretty stocked to get this thing to move under its own power again. Although I still have lots of work before I actually wheel it. Heres a few pics nothing special.
Frame painted
The ebrake cable mounts on stock rear spring hanger , since I put the 63s in and cut out the old hangers I had to weld a bolt to the gas skid plate and use a nut to mount the hanger so the cable wouldn't be flopping around.
Since I cut the front rusted out inner fender , I had to make a bracket that holds the coolant resivor , with only the top bracket it moved around a lot , so I came up with this real quick . A cut down chevy cable shifter bracket and a skateboard bushing.
Old Mar 20, 2012 | 06:24 PM
  #106
775Toy's Avatar
Got these today.
So good and bad news. Good news first , she runs and motor sounds mechanically good , no tics / knocks / rattles ect . But it ran pretty poor. Idles half decent , but don't rev up too well. Got a huge vacuum leak under the intake manifold. I guess the 28 year old intake mani gasket threw in the towel. So looks like I'm gonna be getting a intake mani gasket kit. While I'm at it im gonna do the valve cover gasket and polish or paint the cover. Was kinda cool creeping across the back parking lot to actually drive it in the shop instead of pushing it. Although I had to use the ebrake as my brake cause all my lines are off. Hopefully my box from trail gear gets here tomorrow !!!
Old Mar 21, 2012 | 06:59 PM
  #107
775Toy's Avatar
My trail gear loot came. Extended brake lines , extra line mount and clip , and 4 frame bushings for front shackles.
Also ordered a intake manifold gasket set , valve cover gasket set , NGk vpower spark plugs , and thermostat. Hopefully have time this weekend to install all these things.
Old Mar 21, 2012 | 08:18 PM
  #108
again looking good! still have yet to get my lift on, need the one thing everyone else seems to have, time!
Old Mar 22, 2012 | 07:16 AM
  #109
775Toy's Avatar
Thanks
Old Mar 27, 2012 | 06:47 PM
  #110
775Toy's Avatar
Didn't get a chance to do anything this last weekend. But thankfully i have a cool boss who allows me to store my projects at the shop so i can wrench on them on my lunch breaks. I got the intake mani off yesterday , and cleaned up the surfaces to get ready to install hopefully tomorrow. The last owner obviously thought a hundred pounds of silicon would be better than a gasket lol. Also got my extended steel brake lines on and blead, no pics yet.
If all goes well it will be running again tomorrow , and hopefully better now without the huge vac leaks. Still gotta put new seals on valve cover and paint or polish it, and put in new thermostat and plugs.
Old Mar 29, 2012 | 10:12 AM
  #111
Boomtacoma01's Avatar
Good looking build. I would replace the strock front spring hanger while you at at it as well.
Keep up the good progress on the build!
Old Mar 30, 2012 | 07:48 PM
  #112
775Toy's Avatar
Thanks. Yes I do plan on building new front spring hanger. I plan on taking a leaf or 2 out of my front packs , then see where my ride height is also depending on height I may not build a drop hanger just build a new hanger in place of factory and push it forward a inch or 2 to prevent tires from stuffing firewall . I have plans on running 37s in the future once Tcases and axles are built. Then I'll have to drill frame and weld in new frame tubes to set my shackle angle. All in time. My goals are to just get it driveable for light wheeling this summer and continue building on as time and money permits. My second daughter will be here anyway now so time is tight. I should have named this the lunch break build.
Old Mar 31, 2012 | 03:52 PM
  #113
775Toy's Avatar
Got to the shop for a few hours today.
Adjusted valves
Parts washers make cleaning stuff easy
Plug wires , NGk plugs were installed, cap, rotor
Painted cover , new gaskets and grommets , pcv
Air clean assembly put back on with fresh filter
Few shots of the extended brake lines
Rear
Runs pretty good now . Just need to get a timing light on it and set timing.
Old Apr 1, 2012 | 06:39 AM
  #114
83Toyota88's Avatar
So you just rattle canned your frame? I dont really wanna do por15 or anything and was thinking about some rustoleum rattle cans for my frame
Old Apr 1, 2012 | 07:20 AM
  #115
yeah all i did is rattle can mine, just make sure you get all the surface rust off, so im guessing it runs now bud?
Old Apr 1, 2012 | 11:19 AM
  #116
775Toy's Avatar
My frame just had surface rust. I used a wire wheel on a air drill to get most off . The 1$ Walmart flat black paint. Rustoleum Is by far better than the cheap paint I used. After the wire wheel job I didn't feel the need to spend 4$ a can on it.
Old Apr 1, 2012 | 11:22 AM
  #117
83Toyota88's Avatar
Yea I may just get cheap paint and do several coats. What exactly do you mean by wire wheel? I think i know what your talking about but wanna make sure. Can you link to a pic of one?
Old Apr 1, 2012 | 11:29 AM
  #118
775Toy's Avatar
I can when I'm back at the shop tomorrow. You know how a bench grinder had 2 wheels , one stone wheel for grinding , and on the other side it has a wire wheel for cleaning / polishing ect. It's like that wire wheel but you can put it in a drill. I used it on a air drill but you can use it on any handheld drill. I got it from lowes for like 5$. Get a course one if your gonna use it on the frame. I got a course and a fine. The fine I use for polishing/ cleaning up stuff , and the course for heavy stuff like frames / differentials ect.
Old Apr 2, 2012 | 07:39 PM
  #119
775Toy's Avatar
Old Apr 2, 2012 | 07:50 PM
  #120
jessamiah's Avatar
superb. you put that togeather with lightning speed!!!
