1985 4runner Build
Old Nov 11, 2013 | 06:33 AM
  #81
Philbert's Avatar
Great attention to detail on this build - subscribing!
Old Nov 16, 2013 | 03:08 PM
  #82
julsruls's Avatar
pretty cool
Old Nov 17, 2013 | 01:10 PM
  #83
NIGHTMARE's Avatar
DDDAAAUUUMMM, and I thought I was picky. Great work! Keep the pics coming.
Old Nov 17, 2013 | 02:59 PM
  #84
Jacob13's Avatar
Originally Posted by Jebriel
Wow! Nice job! The engine and trans look super clean-
Nice work, keep posting!
Originally Posted by julsruls
pretty cool
Thank you for all the complements on the truck. It has been a lot of hard work to get to the point we are at right now and more hard work to come.
But here is an update.
We got the Eastwood internal frame coating done on the frame.
This is before we got it done.
We will start to put on the new OME suspension kit that we got after it all dries.
Also we have started to clean the underbody for the Eastwood undercoating which will hopefully be on by the end of the week.
And that is all the pictures I have so far, but will update again soon.
Old Nov 19, 2013 | 07:46 AM
  #85
Gizler00's Avatar
Great progress. You are really going all out on that thing. I wish I had the time to do that to mine. Maybe someday with my kids.
Keep up the great work!!
Old Nov 21, 2013 | 11:16 PM
  #86
Dirty2286's Avatar
man that is gonna be one sweet runner when it's all said and done!
Old Dec 17, 2013 | 06:36 PM
  #87
Jacob13's Avatar
Another update
Okay I haven't updated in a while so here is where we are at.
First we started to install the ome suspension.
This is before any of the weight is on the springs so the shackle angle is pretty steep.
Once we get everything together put back together we will take the wheels off and paint the rims black in tell we get the money for new tires and rims.
Next we undercoated the underbody with this rubberized undercoating.
And these are the results.
We now have that all done and ready for the frame to under it.
Now we have moved to the front axle but got stuck when we where putting on one of the brake calipers and the bolt stripped so we haven't done anything in a while. Will have another update in a while.
Old Dec 17, 2013 | 08:20 PM
  #88
84 yota dude's Avatar
Looks, awesome and the frame looks really good too! Those red brake drums are bright.
Old Dec 17, 2013 | 08:36 PM
  #89
dsal_86Yota's Avatar
Awesome build. Great your starting this stuff at ayoung age and doing it with your dad. It will give you more respect for your rig when your driving it. My dad helped me while I was younger on all my trucks. He didnt like working on them cause I had Broncos and he hates Ford haha Great memorys. . Keep up the great work bud.
Old Dec 18, 2013 | 12:02 PM
  #90
Gizler00's Avatar
Seriously awesome build!!! I love how the frame and the Undercoating turned out. Its really really looking great.
Old Dec 20, 2013 | 08:11 AM
  #91
whirlybird's Avatar
Yes...the undercoating looks great...I was on the fence about using it but I think you have me convinced!
Old Dec 22, 2013 | 09:19 AM
  #92
Jacob13's Avatar
Thanks and I know they are bright but that is the color I wanted them and they will look better once I paint the rims I have.
Thanks. Me and my dad have already have some good times. But my dad was the one that gave me the idea of getting a 4runner because he used to have a 1985 Toyota pickup.
Thank you very much. The frame did turn out petty good.
Yea the undercoating turned out pretty well. I think you would be happy with it.
Now we have fixed the stripped bolt on the knuckle we put it on the frame and got all the suspension put together. Now we have a rolling frame. Will have some pictures up soon.
Old Dec 23, 2013 | 07:21 PM
  #93
Jacob13's Avatar
An update
We started to put the front axle back on the frame.
First we had to fixed the stripped bolt hole on the the knuckle for the caliper.
Then we put on the wheels so we could roll it under the frame to attach the leaf springs and the shocks.
That is where we are at the moment, but is actually starting to look like a truck again. Also had a few questions. When we went to put on the sway bar it wouldn't reach the frame because we put the ome lift kit in their. What do you guys think we should do just try to find a longer bolt or something else? Also do you think we should change the tie rod ends? They felt a little sticky and how hard would it be to do?
Old Jan 18, 2014 | 10:47 AM
  #94
timtoyo's Avatar
tie rod ends should be pretty easy, as far as the sway bar goes you dont need it, leaf springs support you enough and dont allow you to lean in corners much like coil springs do so youll be alright without hooking it back up
Old Jan 18, 2014 | 10:51 AM
  #95
timtoyo's Avatar
if you have the clearance i would also recommend switching to histeer crossover steering, its much more stable and you wont have bumpsteer like you do with the push-pull steering. to do histeer you need about 3 inches of lift so the ome kit might give you enough clearance for it
http://www.lowrangeoffroad.com/index...ering-kit.html
Old Jan 18, 2014 | 10:55 AM
  #96
Discombobulated's Avatar
Looking pretty meticulous.......LOVE IT(:
Old Jan 21, 2014 | 07:10 PM
  #97
Jacob13's Avatar
Thank you for the info. We ended up changing out the tie rod ends and leaving off the sway bar.
Thank you.
Now for an update i haven't posted in a while so here it goes.
We cleaned the gas tank. Also took off the fuel pump and still looked good and the tanks was very clean.
Before we cleaned.
After
Then we put on the engine and transmission.
The new slave cylinder compared to the old one.
The drive shaft.
Put one of the brake lines along with the fuel line.
We only put on one because are going to change out to a manual lspv.
Also put on the emergency brake.
Also we cleaned the engine.
Before
After
I think the paint job turned out pretty good.
We don't have much more to do in tell we put the frame under the body other then cleaning up the firewall and painting it.
Old Jan 22, 2014 | 05:44 AM
  #98
Gizler00's Avatar
Wow great progress!! Looking amazing as usual!!
Old Jan 22, 2014 | 04:37 PM
  #99
Jacob13's Avatar
Thank you very much. It has been a lot of work.
Old Jan 22, 2014 | 05:15 PM
  #100
CHEEZE's Avatar
When can I drop mine off that thing is gonna be clean when your done. Awesome work!!!
