midtnyota's 1981 longbed project
Nice work on plating the frame, looks good! Are you planning on building your own front bumper for it?
Edit*** Δ just saw your post, the first Gen flares aren't metal, they're rubber, or polyurethane, or something flex able, could n't weld them in.
Plan on making a plate bumper for a winch once I get the time and money lol I've got a few other things to worry about before I get to the bumper.
I didn't know the original flares weren't metal.I always thought they were for some reason. So I would probably be better off with aftermarket flares for an 84-88. Thanks rustED
Thanks for the clarification kawazx636, I was not aware that the 2nd gen 2wd and 4wd beds were that much different. But I know now lol another question tho, would I be able to take the factory rear flares from a first gen and weld them to my 2nd gen bed? Or would it probably just be easier to buy aftermarket flares for a 84-88?
A member on here has them on his truck and they look pretty good. Here's a link to his photo album:
https://www.yotatech.com/members/sha...ums-my+83.html
That would be awesome to have some fiberglass flares made, that's a good idea. I like those bushwacker flares, but I personally would like them to stick out about half as far. more like the factory flares. I wonder if Corey could make a mold from a factory flare if someone could find one? I'd be very interested if he could. I think I need to talk to him.
#25
You can check with Corey - you want to email him at CJ@toyotafiberglass.com or better yet give him a call. His user name on here is Slacker, but he doesn't usually like doing business inquires over the forum - he's a pretty professional guy when it comes to business, but really down to earth and easy to talk to. I have asked him about a fiberglass replacement factory flare, but if I recall correctly, he said that he can't get a good mold out of them due to the material. I have never actually touched a factory flare, but from what I understand they are a very soft and flexible rubber material.
#26
thanks kawazx636, I might have to shoot him an email. I may not even need to worry about it tho. I found an 81 parts truck not far from me and the owner said the bed is in good shape. plan to go check it out this weekend. would save me a lot of trouble to just swap beds, plus its from the same year as my cab. so it would cut down on my franken-yota status I got goin on now lol we'll see how it goes
#28
well I ended up not going to get that parts truck. I wound up having to put a new starter on my other truck and fix some wiring issues. I did get a chance to look over the yota a lil more tho to try to see what I need to fix next. I'm gonna have to do something about the brakes. the rear brakes are leaking down the inside of my tires and the front are weak as well. I read over kawazx636's build where he did the disc swap and I'm kinda leaning towards doing that instead of going back to drums.
"83 trail rig" I might be interested in your flares off your truck or your buddies. let me know if your serious about getting rid of them.
#29
well I ended up not going to get that parts truck. I wound up having to put a new starter on my other truck and fix some wiring issues. I did get a chance to look over the yota a lil more tho to try to see what I need to fix next. I'm gonna have to do something about the brakes. the rear brakes are leaking down the inside of my tires and the front are weak as well. I read over kawazx636's build where he did the disc swap and I'm kinda leaning towards doing that instead of going back to drums. "83 trail rig" I might be interested in your flares off your truck or your buddies. let me know if your serious about getting rid of them.
You may have to wait but there free and undamaged
#31
#32
well finally got my new alternator put on last night. I had to jump it to start it because the battery was dead again. it ran good until I unhooked the jumper again and it ran for a minute then died again. so I pulled the battery out and have it on a charger now and will check it when I get home to see if it held a charge. I plan on checking all my grounds too to make sure they are all good. I will probably end up re-doing a lot of the electrical connections because whoever had it before me didn't do a good job and some of the wires look down right scary lol
anyways while I was putting on the alternator I noticed I have an oil leak coming from what looks like right under where the distributor mounts. I also had a small drip of coolant coming off the oil pump cover. I'm guessing it is coming from my timing chain cover? I replaced the front main seal and oil pump cover seal early and that fixed the major leak I had before. but now I have this leak(s) anybody have any idea what it could be? or did I answer my own question.
I'll post some pics of the leaks to try to help. sorry they're not the best they're off my phone.
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
