FS[PacSouthWest]: 1987 4runner parting
Hi i'm in yuma, az
I'm parting out only the listed items and nothing more. If it needs a pulley to operate then it stays with it. Reason for parting out,i have a 95' ls400 i paid $1160 and plan to swap the 1uz-fe. So the stuff i'm selling is what i won't need and is what will help me buy some of the stuff i need for the swap, like a adapter to my W56-B, exhaust piping/flanges, etc.
Thanks for looking.
22re__Asking $700
You get with is the Distributor, Taylor 8mm spark plug wires, Starter, Factory header, fan, water pump belt, Bosch o2 sensor. And 2 new coolant temp sensors for the computer and cluster temp gauge. Was rebuilt a little over 2300 miles ago, on the last oil change replaced timing chain, oil pan gasket, NGK iridium spark plugs.
A/C Compressor__Asking $80
Retrofitted for 134a freon, clutch engages normally.
8/5/14-Item is packaged already, i put a bottle of ester oil 100 and the used belt that can be used as a backup. Fedex weighted it a little over 16 pounds in a 9x9 box i used. o-rings replaced on it.
Alternator__asking $50
Always fully charged my battery, had to jump a few friends in the past was quick because of it doing its job perfectly.
Power Steering Pump__asking $40
Plenty of flowing pressure.
Brackets for alternator, A/C compressor, and power steering pump.
Open to offers.
Ignition control module__asking $150
Module mark '53', new cost 390-500. Put electrical grease inside to help protect from elements.
Ignition Coil__asking $15
no issues.
Air Flow Meter__asking $100
Modified by 3 gear slots to suck in more air, marked factory location if you want to put back. Comes with plastic pipe.
Also have another AFM that i modified too, same price.
Sun Pro temp sensor__asking $20
Gauge Cluster__asking $100
Does not have tac.
Exhaust__asking $180
Welded a 50 state legal magnaflow cat, and has new factory muffler.
Pipe front to back.
17.4 Gallon gas tank__asking $170
Comes with the fuel level sensor.
I would like to sell the engine first since it's my daily driver. I can sell the A/C though. If the item is small i'm willing to ship, but the rest you will have to come and pick up.
Prefer calls or texts 928-750-6774
Also i don't do any kind of payment that i can get scammed with. I've been dealing with a lot of spammers in my area, so i know well then enough on how to deal with it.
Thanks
Any
is appreciated.
Thanks for looking.
22re__Asking $700
Open to offers.
no issues.
Does not have tac.
Pipe front to back.
Thanks
Any
is appreciated.
Very interested in the motor. Are you able to send me a video of it running? Also, what would I have to do to get the radiator from you, or do you need to keep that? My 4Runner finally had enough last night with 328k on it. Not too bad.
Was only able to upload on youtube, so here's one of 2 videos.
Excuse my child like voice, and seemingly lake of knowledge. But i know more then it may seem. Even though i'm 22 people say i look 18.
the second video will be posted later, takes 45-55 minutes to upload.
Usually runs from 158-162 degrees in 100 degree weather, 140-150 cold weather, and 150's in 70-80 degree weather. Hasn't had a thermostat since rebuild, last weekend put the new temp. switch in. Average miles i've been getting is in the low 17's, when putting my foot down here and there 15-16's.
Thinking of doing another valve adjustment, just to make sure each rocker is nice and snug, before it tapped more but now it's less because i adjusted it when the engine was cold, 0.008 intake, 0.012 exhaust.
https://www.youtube.com/watch?v=B5TV...ature=youtu.be
Other parts i'm selling, most of interior, not the second row seats.
Raybestos sway bar bushings, little over 2k miles on.
Old sway bar bushing metal parts, just need new bushings.
Also, the engine will be sold with all little vacuum components.
More to be added in a later date.
hi looking for the front passenger seat reclining handle and rear handle that release the seat foward on the same seat for the 1 st gen 4runner how much shipped to 90278 thanks.
91toybeater
Dec 27, 2015 07:46 PM
