Bunch o' 22ret and 3.4 stuff...Downey headers too.
Ok, here's the final list of all my spare stuff...all the prices are off the top of head so make offers if you think I'm too high...or just high.
22RET Airflow meter: $50
22RET charge pipe from Turbo to TB $50
22RET turbo oil feed/drainback line $40
22RET injector resistor pack $30
22RET coil w/ ignitor, $40
22RET Distributor w/ newer cap/rotor/wires $50
22RET 4x4 oil pan and pickup $20
22RE/T crank pulley/balancer, new from dealer $75 (paid 160)
22RE/T balancer, no groove on seal surface $40
22RE/T rocker assembly. good shape, $40
22RE valve cover, $10
22RE starter, used $30
22RE starter, rebuilt, never used $75
stock SA L and R inners, $50
R151F turbo bellhousing $200
Front IFS diff w/ 4:10 gears and a trutrac $250 SOLD
Trans to engine brackets $10 each
A/C bracket w/ idler $20
A/C compressor (minus the fittings) $50
PS pump, used $25
PS pump, new ATSCO reman, $100
PS high pressure line (turbo specific) new $75
Lower turbo radiator hose w/ header hose tee, newer $40
Newer 22RE GMB waterpump, 8K miles on it. $25
2" tube OBD 1 cat, less than 1000 miles on it, $30
2.5" tube OBD 1 cat, new $50
From the 99 Tacoma prerunner doner rig
99 3.4L 4x4 A/T ECM - $100
2001 3.4 M/T 4x4 ECM - $130
Early 3.4L cast exhaust manifolds, no crossover $50
Downey 3.4L headers with crossover $350
Underhood fuse box w/ cut harness $20
interior fuse box $20
ECT switch $10
PS pump, used $25
ECT switch $10
Hey would you happen to have the cylinder heads themselves for sale? I'm looking for the passenger side cylinder head for a 3.4L.
Thanks
Thanks
Headers still available?
Hi, still have these? If so could you send picts via PM or email? Thanks.
Got a pic of the 3.4 header cross over? I need one or at least an idea what it should look like if I have to build one for mine.
DiggnDeep
Sep 3, 2015 02:45 PM
dlaiben
3.4 Swaps
Sep 3, 2015 09:57 AM
