Toyo OPEN Country M/T's
Old May 26, 2007 | 08:21 AM
deSCHUTTER's Avatar
Hey there,
I'm running a 91 toyota pick up V6 3.0L with 4.56(for now). I got a 4 inch lift and 33/12.5/15 Tsl swampers for now and I'm wanting to pick up another set of tires for a majority of driving i do around town. Any of you ran the Open Country M/T's with this set up, or any set up for that. And anything else you have to say about them. Better or worse tire then the BFG M/T? Keep in mind this tire is more for road use and going camping down dirt roads as I got my swampers for when i go into the bush!
Old May 26, 2007 | 09:29 AM
91muddog's Avatar
if you will be on the road most of the time you will want to go with BFG All Terrains.
Old May 29, 2007 | 02:40 PM
tombothetominator's Avatar
Hmmmmm.... daily use (on asphalt i assume), with a set of swampers for when you go off the asphalt. Whats wrong with a good set of Dueler H/Ts? The noise difference will blow your mind.
To actually answer your question though: no experience with Toyos. I have the BFG A/Ts which work fine for my daily driving (no spare sets of tires for me..)
Old May 29, 2007 | 02:54 PM
Tofer's Avatar
Sponsor
my brother is running 35x13.5 toyo open MTs.... so far hes liked them, they seem to have worn nicely...
Old May 29, 2007 | 03:03 PM
tc's Avatar
tc
Toyo MT's are an awfully expensive and HEAVY tire to use for DD'ing.
I would look at an AT - like the BFG, or the Toyo (Nitto TerraGrappler is the same, and usually cheaper)
Old May 30, 2007 | 06:14 PM
jetblack1's Avatar
I used Toyo open country ATs on my lifted explorer for two years and then transferred them to my wife's rodeo. She ran them for over a year, and when we sold hers, they still looked/rode perfect. I would buy them again over any AT tire out there, hands down. And that's having run a set of BFG ATs on our other explorer.
In any event, I agree with whoever said it above, get some ATs, and pick up a set of used MTs and cheep steelies for rims as a second set for when you go out and get hard core.
Old May 30, 2007 | 06:17 PM
91muddog's Avatar
if its soley for on road, find some cheap-o's!
hello costco
Old May 30, 2007 | 06:43 PM
GenXr's Avatar
I've run BFG AT's on my Nissan and can't say enough good things about those tire in all conditions except mud. I have the Toyo Open Country AT's on my Isuzu Trooper and they are much quieter than the BFG's but are a very good tire. I would consider the Toyo MT's as a good tire........I did not know the NITTOs were cheaper. I thought they were more expensive.
Old May 30, 2007 | 06:45 PM
91muddog's Avatar
my cheap Baja A/t's are really great tires too, not too expensive for dd use.
they dont do too bad in mud either!
Old May 30, 2007 | 07:00 PM
INFINITY's Avatar
easy solution. go on craigslist and find some cheap ($50) spare toyota or chevy rims and put the MTs on the spare set or whatever. then keep some normal street tires on the others and swap wheels when u hit the trails and not just dding. that what i would do
Old May 30, 2007 | 07:01 PM
dijlop's Avatar
if ur rly going to use them for mostly dding just get something small and chill. u dont need mt's to drive around on road. yea u may look cool, but hey, wait till someone tells u that u need bigger tires, then challenge them to an offroad adventure. thats when u swap. hehehe.
Old Jun 1, 2007 | 03:04 AM
vwfastg60's Avatar
My buddy has been running his Toyo m/t's all winter and now in to the dry on and off road. He loves them. He gets stuck 99.9% more then i do with swampers but on road his truck drives like stock(or as close to stock as it can with a 6inch lift). They seem to wear pretty fast tho. He had baja claws before that and said they suck.
Its a tough call. I loved my dualer a/ts on the street and light trail.BFG a/t's wore nice in dry conditions but snow they were the suck!
Old Jun 3, 2007 | 11:28 PM
weakyota91's Avatar
unless im 100% blind which im reading this just fine lol i cant not find toyo m/t in a 15 inch wheel anywhere. Do they make those tires for anything less than a 16 inch wheel. If so somebody let me know pm me or just write it in this tread. im not trying to steal this thread but im wondering if deSHUTTERS 91 p/u has 15s or 16 inch wheels. as far as your question I personally never ran them but have searched and found that most people prefer bfg over open country just because there a little less aggressive and dont wear as fast when used as daily driving.
Old Jun 4, 2007 | 05:22 AM
Alex 400's Avatar
here is the list of sizes that toyo makes for the m/t
http://www.toyo.com/docs/tires/produ...?&category=lgt
they come in 15" wheel sizes 33 and up
Old Jun 5, 2007 | 07:29 PM
killa66cam's Avatar
I haven't used any of the Toyo's; but I have run some BFG AT's, and I'm using the Nitto Terra Grapplers now. I love the Nitto's on the road. I haven't had them off-road as much as when I had the BFG's (I kept breaking the seal on my passenger side, front BFG). I'm also using 17" rims now as opposed to the 15" I was using with the BFG's. I'm sure the rim size helps with the ride as well. I would definately suggest the Nitto's over the BFG's for mostly on road driving. The Toyo AT's look to be the same design as the Nitto Terra's. I would imagine that they should drive and ride alike. I like the price on the Nitto's better too though!
Cam
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
dbollier123
Sep 29, 2015 05:23 PM
PNW94Runner
Sep 29, 2015 02:55 PM
Odin
Sep 26, 2015 06:56 PM
