The OFFICIAL IFS "What size tire will fit" thread
Old Mar 9, 2009 | 10:27 AM
  #41
east_texas_yota's Avatar
go with 33 9.50
Old Mar 9, 2009 | 11:06 AM
  #42
DeathCougar's Avatar
Every day 4-5 new threads are started on "what size tires can I fit without rubbing" etc etc.
This thread will encompass this question, and the several thousand times it has been answered. If you ask the question, your post will be moved to here, regardless of forum origination.
Old Mar 9, 2009 | 11:15 AM
  #43
dropzone's Avatar
Fossilized
hats off to the new mods doing a killer job on stuff like this
Old Mar 9, 2009 | 11:53 AM
  #44
Windsor's Avatar
Old Mar 9, 2009 | 04:05 PM
  #45
hjkmotor's Avatar
how about this. i have a 88 4runner sr5 with ifs and no lift except lift shackles in the rear to get rid of sag and i was looking at 15x8 rims with 2.25 bs with 33x10.5 bfg a/ts. will there be much rubbing? how will this look?
Old Mar 9, 2009 | 04:10 PM
  #46
4Crawler's Avatar
Likely will rub up front:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
You'll be about 3.5" wider on each side up front compared to stock wheels and wider = more likely to rub:
- http://www.4crawler.com/Diesel/Tires...ningTrackWidth
Old Mar 9, 2009 | 04:26 PM
  #47
hjkmotor's Avatar
well the wheels i want come with different backspaces of 2.25, 3.50, and 3.75. which would be best? i like the look of the thinner tires that kinda stick out.
Old Mar 9, 2009 | 04:28 PM
  #48
4Crawler's Avatar
Your stock wheels are approx. 4.75" backspacing:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/24.html
Old Mar 9, 2009 | 04:39 PM
  #49
hjkmotor's Avatar
thanks. srry about all the questions im kinda new to this. so from the info you gave me the 15x8 with 3.75 bs will stick two inches out farther than stock? so that might look pretty good but do you think it rub much?
Old Mar 9, 2009 | 05:14 PM
  #50
4Crawler's Avatar
Measure and see. How? Make up a small block of wood that is as much wider as the new setup will be wider than what you have now and as tall as 1/2 the new setup height will be over what you have now and then run that block around the face of the tire in various states of compression and turning and see if the block hits the fender.
Old Mar 12, 2009 | 12:27 AM
  #51
StangBanger's Avatar
I wouldnt be asking this if i had the truck with me but since i dont..ill just use that as my excuse..lol I wanna run 33's either dunlop mud rovers or something in that price range. Does anyone one the wheel width of the wheels on this 4runner? Theyre stock wheels I know they are 15" but no clue on the width and how wide car i go on the tire with this rim?
Old Mar 12, 2009 | 07:06 AM
  #52
Those are factory 15"x7" Offset 8 wheels
Old Mar 12, 2009 | 10:38 AM
  #53
i ran 33 11.50s kumho mud on the same rims
Old Mar 13, 2009 | 04:54 PM
  #54
ohiobenz's Avatar
does anybody know if the 6x5.5 17" Chevy steelies will fit an FJ? i want some cheap steelies to throw mud tires onto - nothing oversized cos no lift for now.
Old Mar 16, 2009 | 02:41 AM
  #55
Damn! 11.50's on my 7" wide wheels. Bet that was fun to put on. Im hearing 10.50 is the way to go with there wheels. I plan on getting some 33x10.50x15 Dunlop Mud Rovers. Anyone know where i can get a good deal on those?
Old Apr 2, 2009 | 04:55 PM
  #56
4runner114's Avatar
how big a tire can i go on 17" rims with 4" of lift?
Old Apr 2, 2009 | 05:35 PM
  #57
josh88's Avatar
ok... can some one help me out.. i have a 93 Toyota PU.. and i want to know what it will take to put some 33 14.00 15s boggers on it.. as i found a set cheap from a friend.. will 10 inch rims and a 2 inch body lift be enough?
Old Apr 2, 2009 | 06:44 PM
  #58
Dan.3's Avatar
i have 33x12.5 ATs on the stock rims. a little rub
Old Apr 13, 2009 | 02:09 PM
  #59
Yukon's Avatar
285 75 16 BFG AT owners
Will these tires rub on the A-arms, on the 5 spoke rims. 1999 limited.
Planning on an OME lift all around, and the 285 75's.
I searched a lot, and seems pretty consistent that these will not rub after a bit of trimming, but I want to check before its too late to get 265's.
Wanted a tire specific thread because it seems that some tires rub A LOT, and others not at all.
Thanks.
Old Apr 22, 2009 | 01:17 PM
  #60
taco47's Avatar
Biggest Tire Size on a 04 Tacoma
New here to the forum, just installed bilstein 5100s set at 2.5" and a rear 2" AAL in the rear, i was wondering if i could get 285/75/16s under it or am i stuck with 265s? some have said that it will rub on my UCAs and body mounts.
