85 toyota tires
Old Jul 14, 2010 | 06:25 PM
skaz85's Avatar
85 toyota tires
hey guys need some help, is there any rims like chevy dodge ford etc. that will fit on my 85 ?
Old Jul 14, 2010 | 07:16 PM
85gijunk4x4's Avatar
as far as i can think, no...only because the 6 lug rims on the above listed manufacturers are for heavy duty use wich usually means the lugs are spread out farther, im not 100% sure but maybe something like a geo or suzuki will fit...do you have a pickup?...2wd or 4wd?
Old Jul 14, 2010 | 07:32 PM
ehh...after rethinking this i may be wrong, ive tried a ford f250 diesel rim and the lugs were spread out farther, that may not be the case for all ford dodge and chevy though..
DeathCougar's Avatar
Wrongo
Toyota's lug pattern is 6 on 5 1/2", as are many chevies.
Time to start doing some searching, its been covered before.
Old Jul 14, 2010 | 07:35 PM
whats the 4x2 lug pattern? i was just under the assumption his rig was 4x4
Old Jul 14, 2010 | 07:38 PM
waskillywabbit's Avatar
Older 2WD Toyotas are 5 lug. 4WD 6 lug.
My Tundra is some screwed up 5 lug 150 mm crap. What dilbert dreamt that one up...and an 18" rim to boot.
Old Jul 14, 2010 | 07:45 PM
My Dodge, a REAL fullsize truck with a DIESEL, is 8 lug.
Just sayin
Old Jul 14, 2010 | 07:49 PM
awsumfn's Avatar
I swap tires and wheels between my 83 Yota and 79 Chevy Blazer all the time.
Old Jul 14, 2010 | 11:55 PM
skaz85's Avatar
yeah i have an 85 pickup 4x4 im looking to buy some new tires and just want to pickup a cheap set of rims and just paint them black nothing fancy, just was curious if anyone knew any other rim that would work.
Old Feb 2, 2011 | 10:58 AM
CTACKETT998's Avatar
Any one know what 5 lug rims will fit my 94 2wd?
Old Feb 2, 2011 | 11:59 AM
swampfox's Avatar
The chevy wheels have the same 6 lug patern but the center hole is to small for the rear if I remember right.
The ford ranger wheels will fit the 5 lug trucks, the 70's/80's dodge car wheels might also fit.
Old Feb 2, 2011 | 03:10 PM
thanks.
Old Feb 2, 2011 | 05:14 PM
wvboy's Avatar
If I remember right, the ranger and jeep wheels have the same pattern as the 2wd.
Old Feb 2, 2011 | 05:48 PM
BoredOutnJackdUp's Avatar
1/2 ton chevy's. newer toyota's as well as old.
Nissan pick ups, path finders ect...
If i remember right also the full size wagoneers.
and yeah wvboy you remember right!
Old Feb 2, 2011 | 06:25 PM
i tried a set of jeep rims and the pattern was too spread out, going to try ranger wheels next
Old Feb 3, 2011 | 12:49 PM
85TurboRunner's Avatar
The dodge d50 wheels will also fit, as will the mitsubishi mighty max.
Old Feb 3, 2011 | 01:05 PM
swampfox's Avatar
I am assuming that the rangers kept the same 5 lug pattern , a 86 Toyota 2wd I owned had a set of ranger wheels on it. It would be a good idea to check the pattern before buying.
Old Feb 3, 2011 | 01:21 PM
anglosaxon's Avatar
Chevy 6 on 5.5 will work but watch the offset if you have big tires 33 or bigger you will need spacers cause the tires will rub on the suspension arms
Old Feb 7, 2011 | 09:34 AM
6th Gear's Avatar
^^^ especially on 84-85 trucks. 86+ have a wider track
Old Feb 7, 2011 | 02:37 PM
wvboy's Avatar
The wheels off of an older CJ would have a big pattern but the wheels off a wrangler or cherokee will fit.
Jun 1, 2021 01:51 PM
crashburnoveride
Aug 28, 2015 09:20 PM
skoti89
Jul 8, 2015 12:05 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
