33x10.5s on stock 90' pickup?
I have a stock 1990 toyota pickup xtra cab v6 5spd and i was wondering if 33x10.5s will fit on my truck without rub, i have the stock rims, and would i be better off changing gears? if so which ones? thanks
You should be alright, I'm running 31x10.5 and have plenty of room. I have 33x12.5 on my runner and they rub a wee bit when flexed (well as much as an IFS will). They do tuck in the rear and plenty of room in the front.
Check these out:
https://www.yotatech.com/forums/f116...-guide-155339/
https://www.yotatech.com/forums/f116...inside-182510/
Check these out:
They will fit on stock rims.
The problem is your rim spacing. If you keep your stock rims, or rims of the same backspacing (4.75") then the wheel sits inside the wheel well. Now if you go to an aftermarket wheel with a spacing such as 4" bs, then the tire will stick out of the wheel well and contact the inner fender pinch weld.
I rub heavily on that area because of my rims being 3.5" backspacing...
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
Aug 30, 2016 01:03 PM
Sep 4, 2015 09:27 AM
