Domestic Swaps Chevrolet, Ford, ect
drivetrain strength?
Old May 6, 2014 | 01:44 PM
ryan12's Avatar
I have a 1988 Toyota pickup 4x4 and I want to put a factory powerd 351w or 302 in it. im wondering if the stock drivetrain is strong enough for a351w or 302? I got 4:10 gears and 32 inch tires. plan on using it for hunting and mild wheeling. If not.. what axels would be close to Toyota width. I plan on doin a SAS at the same time.
Old May 7, 2014 | 12:15 AM
rustED's Avatar
The drivetrain will hold up. I'm running a 302 with 4.10 gears and 35" tires.
Old May 7, 2014 | 05:25 AM
nothingbetter's Avatar
its very dependant on how you drive, I'm putting roughly 300hp at the crank through mine and the only thing I've hurt was 5th gear in 2 transmission from pulling steep hills under lots of boost. If your trying to drag race every little car with shiny rims and stickers you see you're bound to break stuff. If you respect the fact that your driveline was designed for 100hp and your putting triple that through it you won't have problems.
Old May 7, 2014 | 05:28 AM
JasonYota's Avatar
I would worry more about a toyota transmission holding than the axles.
Old May 7, 2014 | 10:27 PM
ryan12's Avatar
ok I plan on using Toyota axels and maybe transfer case. But what do ya'll recommend for tranny? I would prefer a 5 speed.
Old May 7, 2014 | 11:48 PM
rustED's Avatar
For the type of wheeling you said your going to be doing and your tire size a Toyota 5 speed will be fine. You never mentioned what engine you currently have in your 88'. If you have a 22re then you probably have a W56 trans or if you have a 3.0 V6 then you probably have a R150, both are good trannys and should hold up fine if you drive normally, like nothingbetter mentioned. I'm currently running a weaker G52 trans for almost 2 years, with no problems. If this trans ever grenades I want to go with either a W56 or a R151F turbo tranny.
If you have the money Marlin builds some Heavy Duty trannies, but they're spendy.
Old May 8, 2014 | 07:35 AM
ryan12's Avatar
yea its a 22re. thanks for the info.
Old May 8, 2014 | 10:34 AM
ryan12's Avatar
Would I be able to mount a c6 and np205 under there fairly easy?
TheBFA
Feb 15, 2020 06:55 AM
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
sonorn67
Sep 19, 2015 05:39 PM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
