All Other Toyota Swaps I4, I6, Lexus V8
Tach resistor mod
Old Mar 18, 2012 | 08:09 AM
rokblok's Avatar
Tach resistor mod
I need some info regarding the tach mod. I have searched a lot, but no one shows an '84 sr5 tach. All the mods I have seen have been on different circuit boards from what mine looks like. My tach board is mounted horizontally just above the needle. The board itself is only about 1.25"X 2". And the are no descriptions about which terminals (circuits) actually get the resistor, so I can't just apply the resistor to my different board... Any help is much appreciated.
I just swapped from an '84 22R to a '98 twin coil 3RZ...
Old Mar 18, 2012 | 09:27 AM
xxxtreme22r's Avatar
Huh? The only thing you should have to change is if your going from a 4cyl cluster to a v6 cluster. And an 84 sr5 tach I know 100% is going to be a 4cyl cluster. And the truck in your avatar I know 100% would have a 4cyl in it. Unless you've done a motor swap. SO not sure what you are trying to accomplish. Only thing resister related I have seen is the adjustable dashpot but that's on the 89-95 clusters not he 84-88 clusters.
Old Mar 18, 2012 | 09:49 AM
waskillywabbit's Avatar
He just did a motor swap
:wabbit2:
Old Mar 18, 2012 | 09:50 AM
Sorry, couldn't tell.
Old Mar 18, 2012 | 11:05 AM
rokblok's Avatar
I edited my original post to clarify engine change...
Old Mar 18, 2012 | 11:21 AM
racerflea's Avatar
I know when i put my sbc in to get tge tach eight ill need to hook a 10k ohm pot on it to dial it in
Old Mar 18, 2012 | 11:35 AM
rokblok's Avatar
What is a "pot"? A potentiometer? Mine has a small potentiometer on the board, but my tach doesn't even move at all. And from what I have found researching, this is only for fine tuning..
Old Mar 18, 2012 | 11:54 AM
racerflea's Avatar
Yeah thats it!! Couldnt think of full word! But that is for a chevy 350....think it was a 10 turn to be exact..
TheBFA
Feb 15, 2020 06:55 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
